Go to Post my least favorite thread is that one just hanging from my favorite shirt. - Stuart [more]
Unread 11-04-2013, 09:24
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
PWM Testing Equipment
One item of electrical testing we seem to be at a real disadvantage with is our ability to test PWM signals.
I've been there all too often blindly swapping PWM cables and motor controllers in order to get to the bottom of a problem that all too often is not electrical.
I've seen postings here on how to build your own Arduino based PWM generator, but building DIY test equipment is not the route I'd like to go.
What I'm really looking for is a test box that:
1) can accept any PWM signal and display what it is receiving
2) generate a PWM signal based on some "hand control" input
Does anyone have any idea if such a thing exists and if so, where to get it?
Jim
Unread 11-04-2013, 09:32
Re: PWM Testing Equipment
If you have an old junker laptop (or desktop PC), you can do both.
#1 You can use a free program like Audacity as a simple oscilloscope. Connect the PWM signal to the "line in" input of the sound card. Use a simple resistor voltage divider to reduce the signal voltage to 1 volt.
#2 Read this paper. It shows how to generate PWM signals with an old computer.
Unread 11-04-2013, 11:54
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
We use the small circuit linked below to generate motor controller PWM signals. At the moment it works with Talons and Victors. The timing would need a tweak to run a Jaguar.
The potentiometer is mounted on a joystick with a spring return to center. We like that arrangement because the motor always returns to OFF when the stick is released.
The code is in PIC assembler and anyone who wants it can have it.
https://docs.google.com/file/d/0B6MH...it?usp=sharing
Unread 11-04-2013, 12:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
maybe something like this?
http://www.hobbyking.com/hobbyking/s..._select .html
Unread 11-04-2013, 12:01
There's lots of devices that can do #2. In hobby circles, they are called servo testers. If you don't want to dedicate a computer like Ether's suggestion, you can buy or easily make one. Here's one made by a mentor of 987: http://robotlogic.com/product_servotester.html. You can also make one using 2 555 timers. Here's a schematic http://www.seattlerobotics.org/encod...Excerciser.htm. You can also easily make one with a microcontroller, like an arduino.
We needed to do this to test our shooter prototype. We had one team start working on an arduino to do it, while another team started working on a 555 timer version. In the end, the Arduino team won, by several hours, but now we have two.
It would not be hard to make a microcontroller read a PWM signal and display the value. I haven't seen any off the shelf solutions that do it, however. Here's one example of doing it on an arduino. http://diydrones.com/profiles/blog/s...BlogPost:38418
Unread 11-04-2013, 12:04
Todd's Avatar
Todd Todd is offline
Software Engineer
FRC #1071 (Team Max)
Todd is just really niceTodd is just really niceTodd is just really niceTodd is just really niceTodd is just really nice
I realize you already mentioned that you've seen Arduino samples on how to make a PWM generator, but just for reference, we made one following the example at
https://sites.google.com/site/0123ic...arduino_jaguar
and it works splendidly. Having a test harness with something simple like a power gauge indicator for PWM lines would be really worthwhile in on the spot diagnosis, maybe we'll look into making one this year.
Unread 11-04-2013, 12:22
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
I have an Arduino based tester like what you described in prototype mode right now. When I get further I will try to post something. But I may be wasting some time on one aspect of it by including both powered and un-powered PWM outputs. I know that the digital side car has jumpers to allow you to power the center pins for driving both servo's motor controllers. Does anyone know what the common motor controllers we use do with that center pin? Can I just provide power to the center pin all the time, or will that create a problem with some motor controllers? Since the motor controllers are powered separately and that pin is not needed, why would it just not get connected inside the motor controllers?
This is the zeroth day of the rest of your life.
Unread 11-04-2013, 12:36
The above method is admittedly clunkier than a nice compact hand-held unit that gives a digital readout or an LED pass/fail indication, but it does have one advantage: You can see the actual waveform, and you can record the waveform over a period of time.
This means that in addition to measuring the pulse width, you can also:
- see any noise or improper waveform
- see what the period is, and if it is consistent
- see if there are intermittent dropouts
Plus it just might inspire a student or two. I still remember how inspiring it was the first time I built a simple RC circuit and saw the waveform on a glowing green oval CRT screen. It made physics come alive for me.
Unread 11-04-2013, 12:38
It's not even connected (at least according to the Jag schematic).
Unread 11-04-2013, 12:48
It's also not connected on the Victor. http://www.vexrobotics.com/vexpro/mo.../217-2769.html
The red wire (center pin) on the 3-wire cable connected to the Victor is an open circuit.
There is no reason to disconnect the red wire in the cable.
The Victor does not source or draw power on the red wire.
Unread 11-04-2013, 13:00
MrForbes's Avatar
AKA: Jim
My brother manning the scope, me on the probe.....circa 1974 (I might have us confused, we look alike). We built the scope, using surplus parts, 4 tubes plus the CRT. Non-linear (and dangerous) as heck, but it made wavy green lines!
Unread 11-04-2013, 13:20
Love that picture! The hair looks about right for 1974. How did you dig it up so fast? Do you keep it in your wallet :-)
Unread 11-04-2013, 14:34
tsaksa's Avatar
Great. That makes it easier to use the standard PWM servo outputs as found on an Arduino development board for the requested capability. The tester I have been working on uses an Arduino Uno for both PWM signal generation and monitoring, along with a few other functions. But I needed to do a lot of extra work to build an interface board for it. If there is no need to have the power pin disconnected, it opens up the possibility of using a development version of the board (with and LCD shield) for the tester. This reduces the amount of custom wiring needed to get to a useful configuration. You would still need to wire a power switch, a few buttons, and one or two potentiometers, but I think it would be a relatively easy tester for most teams to build. As I said, I have a prototype version working, and I will try to provide more information and code after I test it and clean it up a bit more.
Unread 11-04-2013, 14:45
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
I had a "pong" paddle on my green phosphors. Never got a full game going though. Shifted over to turning a B&W Sony portable TV into a TV Typewriter. I think that beast may still be in the cellar somewhere, much to my wife's justifiable chagrin.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 12-04-2013, 02:38
ablatner ablatner is offline
AKA: Andrew Blatner
FRC #0100 (The Wildhats)
ablatner is on a distinguished road
For what do you need to test PWM signals? I have never needed to do that as part of any troubleshooting. Usually, PWM problems can be diagnosed otherways: through the dashboard on the driver station, the lights on the motor controllers, etc.
2009-2013: Student, Team 100
2013-????: ?
