The SMC (5) port (2) position, double solenoid valve assembly consists of the following components:
- Main valve body with double solenoid pilot operators - Valve sub-base - Gasket - (2) screws - (2) electrical connectors (The SMC portion of the kit includes (2) valve assemblies) To assemble the valve: 1) Insert screws in through holes of main valve body 2) Align gasket onto bottom of valve 3) Align and install valve body onto valve sub-base tightening screws evenly 4) Attach solenoid electrical connectors Fittings and tubing will be connected in the following manner: P-port = Supply pressure A-port = Cylinder B-port = Cylinder EA-port = A port exhaust EB-port = B port exhaust Air supply pressure must be a minimum of 15psi in order to properly shift the internal spool of the valve. |
| SMC Double Action Valve. | Josh Hambright | Pneumatics | 2 | 14-02-2003 10:24 |
| multiple cyclinders from one double solenoid | Ed Crammond | Pneumatics | 1 | 07-02-2003 18:49 |
| SMC valve leak? | inwoodraider | Pneumatics | 1 | 02-02-2003 01:04 |
| Will trade for double solenoid valve | archiver | 2001 | 2 | 24-06-2002 00:33 |
| Single Solenoid Valve SMC | Chubtoad | Technical Discussion | 3 | 20-01-2002 15:16 |
