Go to Post Just remember that you can get just as much inspiration from making a simple system's details work really well as you can from just making a complex system work... - Rob [more]
Unread 29-01-2003, 13:34
Dave Kempskie Dave Kempskie is offline
Dave Kempskie is an unknown quantity at this point
Post SMC Double Solenoid Valve Assembly
The SMC (5) port (2) position, double solenoid valve assembly consists of the following components:
- Main valve body with double solenoid pilot operators
- Valve sub-base
- Gasket
- (2) screws
- (2) electrical connectors
(The SMC portion of the kit includes (2) valve assemblies)
To assemble the valve:
1) Insert screws in through holes of main valve body
2) Align gasket onto bottom of valve
3) Align and install valve body onto valve sub-base tightening screws evenly
4) Attach solenoid electrical connectors
Fittings and tubing will be connected in the following manner:
P-port = Supply pressure
A-port = Cylinder
B-port = Cylinder
EA-port = A port exhaust
EB-port = B port exhaust
Air supply pressure must be a minimum of 15psi in order to properly shift the internal spool of the valve.
SMC Double Action Valve. Josh Hambright Pneumatics 2 14-02-2003 10:24
multiple cyclinders from one double solenoid Ed Crammond Pneumatics 1 07-02-2003 18:49
SMC valve leak? inwoodraider Pneumatics 1 02-02-2003 01:04
Will trade for double solenoid valve archiver 2001 2 24-06-2002 00:33
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
