Go to Post But their robot puts its wheels on one at a time just like ours, so we can be a HOF winner too! - Foster [more]
Unread 11-04-2013, 12:44
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
PWM cables type
Hi CD,
This year my team moved from using only jaguars to victors and talons.
We had a problem with the victors and the talons PWM connection.
In the talons, not all the PWM cables fitted in the connection, I don't know why. It seems like the talons has different connection shape.
In the victors, we had to take the cables in and out many times until it worked.
Most of our PWM cables are from the KoP's.
Is there a specific PWM cable type we should use?
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
Unread 11-04-2013, 12:49
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Re: PWM cables type
All of the KOP PWMs should fit. Iirc, (I'm not by a talon right now) but the talons are slotted so the PWM only goes in one way. As well, victors have a tighter fit around the male end but it's unfortunate that you can insert a PWM both ways into a victor.
Academic Student (Forever)
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: PWM cables type
I'm not sure what problems you had with the Talons... all of our PWM cables fit in them without any issues.
Victors, however, can be tricky. The way it's assembled, it's pretty easy to insert the PWM into the housing and miss the actual connector on the circuit board. Thus removing and inserting it several times until it magically works!
2016: Lake Superior WFFA
Unread 11-04-2013, 15:10
404'd's Avatar
404'd 404'd is offline
Lead contributor of sweg
AKA: Josh
FRC #0967 (Iron Lions (9-sits-7))
404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all
Re: PWM cables type
Same here, we didn't have any trouble with KOP PWM cables this year. But regular hobby (R/C) male ends didn't fit too well into victor 888s or talons. I remember "adjusting" the hole with a big screwdriver to make it a little bigger and that seemed to fix the problem. But having a tight fit isn't a bad thing either when ramming or getting rammed by other robots.
Driving "Career":
2012 GKC: Quarterfinals w/ 6th seeded alliance | Wisconsin: Quarterfinals - 3rd seeded alliance captains
2013 GKC: Quarterfinals w/ 5th seeded alliance | North Star: Regional winners, 2nd seeded alliance captains
2013 CMP: Curie Semis w/ 2056 + 3990
Unread 11-04-2013, 16:50
Itay's Avatar
Itay Itay is offline
(ง'̀-'́)ง
AKA: Itay Nevo
FRC #1577 (Steampunk 1577)
Team Role: Electrical
Itay is an unknown quantity at this point
Re: PWM cables type
For your talon problem, only the cables from the KoP's fit.
For your victor problem I'm not sure, just try to put it in gently.
Unread 11-04-2013, 17:06
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: PWM cables type
Every PWM cable I've worked with fits the Talons fine. It's designed to be a slightly tight fit so they don't come loose easily.
Some RC type cables have an alignment tab that's designed to make sure the cable can only be inserted one way. The VEX cables (the entire Vex system actually) has this feature for correct alignment. The Talon has a slot for this alignment tab, the Victor (at least the 884, I haven't checked the 888) does not have a slot. I usually cut the tab off with small side cutters when I need to insert the cable into a Victor. The KOP cables (at least from this year) did not have this feature and should have fit the Victors.
Kettering Motorsports
