Go to Post Either way, FIRST works. You just have to keep the big picture in mind. - Lux [more]
Unread 11-04-2013, 14:33
1683cadder 1683cadder is offline
FRC #1683 (Techno Titans)
Team Role: CAD
1683cadder is on a distinguished road
custom wheels
I noticed that a lot of teams are using custom wheels this year. Is there any advantages? What about costs? And what is needed when designing a wheel?
Unread 11-04-2013, 15:43
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: custom wheels
We almost made our own wheels this year, unfortunately we had to return our 3D printer before we could finish them. Some advantages would be that you can make the wheels any size you would like as long as they remain within the constraints of the 3D printer. You can also change the structure of the wheel potentially saving weight.
When designing a wheel you would need a CAD software compatible with your 3D printer as well as some tread to attach to the wheel once they have finished printing. If I have some time later tonight I will upload an image of our CADed wheels.
Cost wise, you have a pretty large start-up fee. A 3D printer can cost you more then an entire team's budget for one year.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 11-04-2013, 15:54
FRC #1836 (MilkenKnights)
Re: custom wheels
Custom wheels are usually made in two ways: 3D printing or CNC machining. The 3D printing method tends to be the easier method. I've heard they can be really strong if made right, so you probably want to experiment before the season if you chose this method. From what I've heard, CNC'd wheels tends to be resource consuming, but you come out with a strong, light wheel.
Unread 11-04-2013, 16:10
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: custom wheels
COLSONS FTW!
Mentor 2415
Unread 11-04-2013, 16:37
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: custom wheels
Find a sponsor with a CNC mill (thanks GEMS!).
Shamelessly borrow AM's 6" performance wheel CAD design (the old one without the big hole in it for the zip-tied tread) minus a few features.
Buy 5.75" aluminum wheel blanks for about $9.50 each.
Turn your sponsor loose.
Finish up the tread grooves and rivet holes yourself.
Save lots of money.
Unread 11-04-2013, 16:38
AdamHeard's Avatar
Lead Mentor
Re: custom wheels
Save lots of money.
This is really inefficient.
Sure, you save money, but at the expense of sponsor's time.
I'm sure that sponsors time could be better spent on other robot parts.
We run COTS wheels now, after machining aluminum solid wheels for years.
Unread 11-04-2013, 16:44
O-H
Re: custom wheels
I'm sure you know nothing about our program or our sponsor.
I'm sure they are happy to save us money doing a part they can setup once and make repeatedly and relatively quickly, giving them more time to handle their very busy workload on all that fun stuff that *actually makes them money*.
I'm sure they are also happy that they saved 3193 money as well making the same wheels.
I'm sure we had another local CNC sponsor who is more flexible in making a variety of parts for us.
I'm sure COTS wheels weren't something we wanted to use on the competition robot this year.
Unread 11-04-2013, 17:12
Chinmay's Avatar
Chinmay Chinmay is offline
incurable FIRSTaholic
FRC #0846 (Funky Monkeys)
Chinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant future
Re: custom wheels
I'm sure you know exactly how to save your sponsors time and money and maybe I'll get to hear that someday....
Regardless, I agree with Adam that making your own wheels can be a resource hog for a lot of teams. Sometimes, it is feasible for a team to machine their own wheels, but even if I had the time/materials, I'd still think twice about doing it unless theres a significant advantage.
Some significant advantages can include the method of tred attachment, the way you attache sprockets for chain/belt, the exact diameter of the wheel and the width of the wheel. I dont think weight savings would be too big a motivation for making custom wheels. It really just depends on your teams resources. There are a lot of good wheels that are cots parts so i wouldn't worry too much about custom ones.
Member 846 Funky Monkeys 2007-2011
Mentor 558 Robosquad 2012
Mentor 846 Funky Monkeys 2011-Present
http://www.becauserobots.org
Man is a robot with Defects
Unread 11-04-2013, 17:38
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: custom wheels
Saving money is a significant advantage in my books.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 11-04-2013, 17:40
Re: custom wheels
Versa traction wheels are cheap.
Unread 11-04-2013, 17:43
Gregor's Avatar
Re: custom wheels
Read Travis' list again.
A lot of people in this thread are assuming that what works for their team works for every team.
<Since 2011
Unread 11-04-2013, 18:13
Re: custom wheels
I realize what works for one team doesn't work for every team. That said, for the majority of teams the time to make custom wheels is not worth it(as Chinmay perfectly stated).
Your point was that custom wheels have a significant advantage price wise. I was just pointing out that there are COTS wheels that are just as cheap.
Unread 11-04-2013, 18:15
Chinmay's Avatar
Re: custom wheels
He has legitimate reasons for machining his own wheels. Power to him. I'd hardly call it a "list"
I'm trying to provide a set of reasons why teams may want to machine wheels. I don't think cost for the teams I've worked with would be a good reason because its nearly impossible to save cost on custom wheels.
Edit: Also I don't think I mention saving money as not a legitimate reason...
Unread 11-04-2013, 18:24
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: custom wheels
If anything, what I'm seeing here is that, like everything on your robot, the efficiency and "worthwhileness" of custom wheels is something that is completely relative to your team. If you have all kinds of machining sponsors or a 3D printer, it might be worth it for your team. If you don't, not a big deal. It's how you want to allocate your resources (like anything in FIRST).
On another note, one of the benefits can be an integrated pulley, such as 3928 had on this year's robot. I can't tell you how nice that looked for a team that was struggling to use belts for the first time on our drive train this year.
Unread 11-04-2013, 18:28
jar24 jar24 is offline
Manufacturing Engineering student
AKA: Jacob
FRC #5162
jar24 will become famous soon enoughjar24 will become famous soon enough
Re: custom wheels
we build our own omni and mecanum wheels, we have CNC's, we find that they are a lot stronger and are lighter also. plus it is nice being able to tell a judge that you created your wheels
Student
FRC team 468 Aftershock
2010 - 2013
FRC 5162 - The Big Red Theory 2013 - Present
FRC 5448 - The Cosmic Chaos Automationeers 2014 - Present
FTC 7837 - The Thunder Colts 2013 - Present
Alumni
FRC 468 - Aftershock 2010 - 2013
