Go to Post As far as I am concerned, the quality of an electronic device is directly proportional to the number of blinky lights on it. - EricVanWyk [more]
Unread 11-04-2013, 14:02
Michael Hill's Avatar
Re: Methods of shifting gears
Originally Posted by Dad1279 View Post
Could use a window motor/cam linkages to shift both, or a faster motor with a leadscrew.
Dealing with pneumatics isn't that difficult. Don't need an on-board compressor.
I realize pneumatics isn't difficult, but it's A LOT of overhead weight (even without on-board compressor). You'll need at least the manual relief valve, emergency relief valve, pressure gauge, storage tank, solinoid, tubing and your actual pneumatic cylinder. That's quite a bit when all you want to do is shift!
Unread 11-04-2013, 14:28
Andrew Lawrence
Posts: n/a
I suggest looking at Team 254's shifters on their website (www.team254.com)
Here's their 2012 transmission: http://media.team254.com/2012/08/gearbox.jpg
Also, a bit unrelated, but did you use to have a MC server?
Unread 11-04-2013, 15:47
FRC #1836 (MilkenKnights)
The question is if the extra weight is worth the extra performance. Pneumatics means faster and more reliable(imo because there is little chance to shear a dog gear) shifts. In addition to that, pneumatics can be very useful for simple, 2 position operations, can be used as springs, and can be actuated after the buzzer. This gives pneumatics tremendous versatility. I personally think pneumatics gives enough benefit to outweigh the price.
Unread 11-04-2013, 17:10
I realize that. I've used pneumatics on every robot I've been associated with building. I've just seen a lot of teams staying away from pneumatics because of either difficulty or weight.
Unread 11-04-2013, 18:00
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by fb39ca4 View Post
Has anyone tried using a shifting bicycle hub? The kind that bikes without derailleurs use?
The biggest issue with derailleurs is that it is a single direction gearbox, and most FIRST applications are bidirectional.
___________________
- Tennyson, Ulysses
Unread 11-04-2013, 18:33
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
He means something like this
As to the OP's question, I can think of 3 successful team-built shifting gearbox types (this excludes the planetaries in the Dewalts and drill transmissions):
-Mesh shifting ("Crash" shifting) - Sliding gears to mesh. The Killer Bees 4-speed design linked earlier is a mesh shifter, as were many early FRC shifting transmissions. They are relatively to easy to build, and with a large pitch gear and slightly more backlash they can work fairly well. While not space efficient it is possible to have a 3 or more speed mesh shifter with a single mesh. The 4-speed is essentially 2 2-speeds in series as this design is more space efficient. As the paper describes, we really wanted a 3-speed but the 4-speed was easier to build. Note that 2 2-speeds in series requires a double swap shift for 2<->3 shifts and that is not usually a 'good' shift to perform (if it's not perfectly synchronous you'll end up in 1st or 4th for a short period of time).
-Dog shifting - Sliding a dog to mesh. In this case, the two gears in question ride on the common shaft via bearings, and the mechanical coupling to that shaft is provided via the dog. The dog meshes with one gear at a time to pick a gear ratio. The dog design is limited to 2 gear ratios per dog. You can get 4 speeds by designing 2 2-speeds in series or having multiple dogs on a shaft (this would usually, but not always, require the ability to shift a dog into neutral)
-Ball shifting - Balls sit in cups of the shaft and are pushed out to engage the gears riding on the shaft to engage a gear. This design is capable of any number of gears in sequence adding only another pair of gears and balls and slightly lengthening the shaft, and can shift sequentially very easily. It is impossible to shift non-sequentially (each gear you step through must engage to let the plunger pass by it). For a 2-speed design like the Vex Pro this is irrelevant.
There is also the theoretical option of the planetary transmission. An automotive planetary uses planetaries and lockup/drive clutches to select a power path through the planetaries (which elements are connected to the input and which are grounded). Good designs allow jump-shifting nearby gears with a single clutch-to-clutch shift (exchanging one clutch for another). A drive or lockup clutch in an FRC application could be a part of a dog, mesh, or ball shifter, or a lockup band.
Kettering Motorsports
Unread 11-04-2013, 19:12
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
I've designed and built a few ball shifting transmission in the past. I really dig the new Vex Pro models that are out. They've got many of the 'wanted' features I've recognized over the years, but never implemented. Kudos to them for a solid design.
Linked are two pictures.
1) Project cover page listing team members and showing completed drive base.
2) Shifting detail on the transmissions. The large exploded view is a bit crap (my apologies), but the other simple illustrations outline function showing the shifting shaft, plunger shaft, shift gears, and ball bearings.
I'm happy to share any specific details if anyone is interested in developing their own ball shifter.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 11-04-2013, 21:23
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
CVT anyone?
http://en.wikipedia.org/wiki/Continu...e_transmission
Not entirely practical for FRC applications but it certainly would make an interesting design project to see if you can make it work.
Unread 11-04-2013, 21:26
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Originally Posted by A_Reed View Post
CVT anyone?
Imagine having one of these on your robot. http://upload.wikimedia.org/wikipedi...xtroid_CVT.jpg
All opinions are my own.
Unread 11-04-2013, 21:36
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Originally Posted by joelg236 View Post
190 did a toroidal CVT with power take-off in 2002. (Search the forum for more information, e.g. this thread.)
Unread 11-04-2013, 22:24
The Thunderchickens did a planetary CVT in 2002 and published a whitepaper: http://www.chiefdelphi.com/media/papers/1361
Unread 11-04-2013, 23:19
lukedude43 lukedude43 is offline
Doer of stuff and things
AKA: Luke Reinert
FRC #4030 (NullPointerException)
lukedude43 will become famous soon enoughlukedude43 will become famous soon enough
thanks to everyone for all the information it's been incredibly helpful. Something that I didn't realize I left out is that this is a project to help me learn solidworks and because off that i'm gonna go with dog shifting just because of the easier design. Also if by some chance we actually made this instead of just buying some AM or VEX shifters, dog shifting would be easier for my team to do because they would be our first machined parts and it seems much easier to design than a ball shifter.
Unread 11-04-2013, 23:24
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Unless you have a really, really good reason, stick to COTS gearboxes.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 11-04-2013, 23:28
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Make sure you do it in the off season. Before COTS 2 speed gearboxes were available are team wasted a lot of time making 2 speeds that were mediocre. I'm not sure how well the AM shifters shift but our dog shifters take quite a bit of tuning to shift in a useful fashion.
2016: FRC 865 Mentor
Unread 11-04-2013, 23:32
AKA: Luke Reinert
AM shifters are dog sifters
