Go to Post Maybe we can start a FIRST team on Mars. - Karibou [more]
  #31   Spotlight this post!
Unread 11-04-2013, 23:41
Michael Hill's Avatar
Re: Methods of shifting gears
Originally Posted by lukedude43 View Post
AM shifters are dog sifters
I don't think dogs appreciate being sifted
  #32   Spotlight this post!
Unread 11-04-2013, 23:44
lukedude43 lukedude43 is offline
Doer of stuff and things
AKA: Luke Reinert
FRC #4030 (NullPointerException)
lukedude43 will become famous soon enoughlukedude43 will become famous soon enough
Haha you're probably right
  #33   Spotlight this post!
Unread 12-04-2013, 01:07
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Pretty much the history of dog gear shifting in FIRST and the origin of Andy-Mark.
http://www.chiefdelphi.com/media/papers/1306
http://www.chiefdelphi.com/media/papers/1360
http://www.chiefdelphi.com/media/papers/1432
http://www.chiefdelphi.com/media/photos/19082
Team 45's 2003 gearbox is probably one of my favorite gearboxes. The PDF was released when I was learning to drive. So I was crazy about cars then. The 2003 gearbox is what taught me what a dog shifter was in a manual gearbox.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
  #34   Spotlight this post!
Unread 12-04-2013, 01:52
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Originally Posted by fb39ca4 View Post
Has anyone tried using a shifting bicycle hub? The kind that bikes without derailleurs use?
Being an amateur bike mechanic whose rebuilt a few Sturmey-Archer 3-speed hubs and knows way more about them than I probably should, I can speak on the question. (Long post ahead!)
Most hubs will not work for a drive train. This is because they are designed from the start to only be driven in one direction; the frewheeling ratchets are actually part of the internal shifting design. In essence, such hub has a single planetary stage and locks/unlocks the ratchets to make the planetary run 3 speeds (x:y, 1:1, y:x). Newer designs pushed the concept to 7 speeds (shimano nexus for example) and even 14 speeds (rohloff speedhub, well over the $400 limit @ ~$1000 per hub). However, most FRC robots need a bidirectional drive, so this isn't going to work out.
However, there are fixed gear planetary hubs... the modern Sturmey archer S3X comes to mind. What I don't know is whether such hubs maintain the selected gear ratio in reverse.
What I'd be most concerned with would be getting the input and outputs meshed into a FRC capable drivetrain... The non-fixed versions used to and still come in a format for tricycles where one of the hub flanges is replaced with a 2nd sprocket (to go to a sprocket on the rear axle); however, I'm pretty sure the S3X doesn't come in that format (you'd have to do a gut swap with another hub shell or do some other custom setup)
Shifting could also be tricky; at least the modern designs use an even pull setup (the cable distances between shifts is consistent). Older (pre-2000) sturmey archer hubs had a small gap between 1st and 2nd and a huge gap between 2nd and 3rd, with a neutral zone in between (get the cable tension too loose and you'll hit it in 2nd under load). In addition, shifting must be done with the input at rest (at least with the non-fixed hubs)
Last, these hubs are lubrication picky. They are usually lubed with oil (I use generic ATF)... and many hubs (older ones especially) could fling oil if overfilled or really old (sheet metal oil caps). Not exactly FRC legal. One could in theory run it on grease but my experience has been that these hubs don't like being run with grease.
My advice: offseason it if you really dare. It won't be an purely COTS solution, but to be honest, much more can be learnt from a non-COTS drivetrain when it comes to offseason projects.
