Go to Post It doesn't matter to me where a FIRST local event is held, I'll be there! - Barry Bonzack [more]
Unread 11-04-2013, 23:41
Re: Using Discs to Block Full Court Shooters
Originally Posted by Grim Tuesday View Post
Looks like a good one for Q&A. Posted:
Q623:
Do DISCS under the active control of a ROBOT count towards the limits defined by the PLAYING CONFIGURATION? STARTING CONFIGURATION?
You little... Spoilsport!
In all seriousness, I think this would have been a pretty good YMTC topic, and definitely a good one for Q&A to answer. IMO, right now, there is nothing forbidding this strategy. After Q&A speaks, there may be an interpretation or rule to do that--but if they don't put one out now, there may be some few disc-type blockers popping up this weekend from alert competitors.
Unread 11-04-2013, 23:48
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Originally Posted by Woolly View Post
Well, hey, if you already have the discs at 90", what would it take to be able to kick them out into the pyramid goal reliably?
Probably the difficulty in getting a colored disc into a stable gripper from a hp slot rather than preloading it by hand prematch. That would be a decent engineering deal rather than a morning addition
Academic Student (Forever)
Unread 12-04-2013, 00:03
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
I've taken your signature to heart!
Though given how slow the GDC has been with Q&A this late in the season, the YMTC option may be the faster one
Unread 12-04-2013, 00:06
foote stepped in
AKA: E. Foote
FRC #0868
Only issue I can think of is if the disc you're holding breaks, Refs might not like you destroying game pieces.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 12-04-2013, 00:10
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
The best solution I can think of off-hand would be to put a claw on a lead-screw, and having some way of relaxing the claw just enough that you can kick the Frisbees out with a pneumatic cylinder without dropping the them.
Which sounds like a modified Logomotion bot, not a modified Ultimate Ascent bot.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 12-04-2013, 00:14
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Since there's no rule that says discs count as part of the robot for certain purposes, there's no good reason to believe that this is an exception. (Do discs count as they're being ejected? Do they count when they're in the goals?) It should be 100% permissible.
And as for next year, if FIRST wanted to kill all the interesting, unexpected strategies, they might as well simplify their effort and just make the next game robotic dressage. I trust it won't come to that.
Unread 12-04-2013, 02:13
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
I object to this thought. We should let tall full court shooters roam free - they are, after all, a thing of beauty!
In all seriousness, though...
I don't see using a disk to effectively increase your height as being an issue. However, you had best have a good grip in it as most FCS will send their disk with some power. Other solutiosn might be easier to pull off.
However, if you increase the perimeter, you would have to be careful about bumps in the protected feeder zone. I suspect that contact with the held Frisbee would still be considered a violation of G30 as it would violate the spirit of a protected zone.
Unread 12-04-2013, 09:51
pfreivald's Avatar
AKA: Patrick Freivald
I think that FIRST tries very hard to prevent chokehold strategies in their games, and that the rules were written with full-court shooters and blockers for those shooters in mind.
So (a) I believe this would be 100% legal, and (b) I don't think that the GDC would look at it and think, "Oh, no! We missed something!"
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 12-04-2013, 12:14
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
This brings up a good question, who is destroying the disc? The robot holding it, or the robot shooting discs at it at a very high velocity? I think the burden falls on the full court shooter to not shoot at things that they shouldn't shoot at.
Then G18-1 exists...
Unread 12-04-2013, 13:16
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
I know what you mean about how the Field Reset Crew doesn't like Frisbees being destroyed.
Unread 12-04-2013, 15:55
zmeves's Avatar
zmeves zmeves is offline
AKA: Zach Meves
FRC #3847 (Spectrum)
Team Role: Driver
zmeves is an unknown quantity at this point
And could have been our chance to block some of your shots at Razorback...but alas your shots cleared our noodle tips.
I well remember being afraid of you blocking our shots
-Zach Meves
FRC #3847 Spectrum
Unread 15-04-2013, 15:30
AKA: Simon Bohn
Q&A is in:
Q623 Q. Do DISCS under the active control of a ROBOT count towards the limits defined by the PLAYING CONFIGURATION? STARTING CONFIGURATION?
A. No. No.
Not surprised but I wish I had thought of the idea earlier and made a robot designed to be 70" in the opponent's auto zone. Also a robot that ferries discs.
Unread 15-04-2013, 15:46
foote stepped in
AKA: E. Foote
FRC #0868
Since you get three frisbees at the start, you could try and wedge the third frisbee in between the first two, and increase your effective height even more.
