Go to Post Free food attracts us like flies. It's the one sure way to get us to meetings. - Mark McLeod [more]
Unread 12-04-2013, 11:44
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
FMS discovery not working?
In Seattle and Calgary, the "DriverStation.getInstance().isFMSAttached()" method was not properly detecting FMS.
Documentation in wpilibj
     * Is the driver station attached to a Field Management System?
     * Note: This does not work with the Blue DS.
     * @return True if the robot is competing on a field being controlled by a Field Management System
I know we've been red before. It did not work when we were. Any ideas? Was this overlooked during a driverstation update or something?
All opinions are my own.
Unread 12-04-2013, 11:50
Jared Russell's Avatar
Taking a year (mostly) off
Re: FMS discovery not working?
By "blue DS" I believe they are referring to the 2009-style "little blue box" driver station, not the alliance color.
Unread 12-04-2013, 11:53
AKA: Joel Gallant
So then it should have worked regardless of our alliance?
Unread 12-04-2013, 12:00
We had some code that ran when isFMSAttached returned true this year that didn't work at the Los Angeles Regional. We never had a chance to determine if it was the isFMSAttached or something inside, and ended up ripping it out.
I hope to play with it with FMS Lite during the offseason.
Unread 12-04-2013, 12:01
yes
Unread 12-04-2013, 12:03
AKA: Joel Gallant
We did the exact same thing. I have a feeling it is something about the FMS.
Unread 12-04-2013, 15:21
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
We had a problem with the FMS where our joystick controls (we tried this with logitec joysticks and an xBox controller) were both reversed and backwards when connected and fine when not. What exactly do you need isFMSAttached used for?
Unread 12-04-2013, 15:26
AKA: Joel Gallant
To adjust what data to send on the smartdashboard for competition. Don't want to get any lag.
Unread 12-04-2013, 16:03
We turned our camera LEDs on and off based on a dashboard button. We wanted to make sure they were always on at the field, in case someone forgot to hit the button.
Unread 12-04-2013, 16:30
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Same here. Our code which ran the shooter wheel all the time when we were on the field didn't work.
Unread 14-04-2013, 13:57
I just tested isFMSAttached with FMS Lite and it worked. Not sure if there is something different in real FMS.
