Go to Post GP makes us all on one and the same team. They understand that in order for any of us to succeed, we need to help out where we can. It is why you will see so many other teams helping a team with a failing robot, buggy software, team strategy, etc. - Al Skierkiewicz [more]
Unread 08-04-2013, 17:32
danruff5 danruff5 is offline
Hobbiest Programmer
FRC #4525 (Rambot)
danruff5 is an unknown quantity at this point
Re: Troubleshooting motor controllers
The only thing that i can think of is the Digital Sidecar not working properally. Is there a way that i could fix it.
Unread 08-04-2013, 17:37
Hobbiest Programmer
FRC #4525 (Rambot)
Thanks MichaelBielecki. The RSL is always solid.
Another this that could be causing this is chips. You can try to clean out the chips if you see any and try again.
I will try this now.
EDIT
I tried this and still no change.
you can try unplugging everything from the sidecar except for one motor controller.
Next this.
EDIT
Still no change.
Unread 10-04-2013, 15:58
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
We use this to generate a pwm signal to a motor controller. Great device to have to test the motors without hooking up the electronics.
http://www.servocity.com/html/dual_servo_driver.html
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 10-04-2013, 16:04
404'd's Avatar
404'd 404'd is offline
Lead contributor of sweg
AKA: Josh
FRC #0967 (Iron Lions (9-sits-7))
404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all
Originally Posted by danruff5 View Post
Thanks MichaelBielecki. The RSL is always solid..
You say the RSL is always solid, even while disabled it does not blink?
I would try swapping Sidecars if you have a spare.
Driving "Career":
2012 GKC: Quarterfinals w/ 6th seeded alliance | Wisconsin: Quarterfinals - 3rd seeded alliance captains
2013 GKC: Quarterfinals w/ 5th seeded alliance | North Star: Regional winners, 2nd seeded alliance captains
2013 CMP: Curie Semis w/ 2056 + 3990
Unread 10-04-2013, 16:07
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
IMO that $50 would be better served towards an arduino with a potentiometer. This gives you a tool with endless possibilities (including acting as a motor controller). Actually, AndyMark now has a shield for an arduino that can make it replace your cRIO for testing, which makes an arduino all the more valuable.
Unread 10-04-2013, 16:12
Or spend $0 and make one with an old junker laptop.
Hobbiest Programmer
FRC #4525 (Rambot)
This sounds AWESOME!!! Thanks for telling me!
We replaced the digital sidecar and now it works perfectly!
Thanks to everyone who gave suggestions!
Unread 10-04-2013, 18:30
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Great to hear that.
Could you open up the bad DSC and have a look inside? I'm sure I'm not alone in wanting to understand why a DSC that appeared perfectly functional wasn't actually working.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 10-04-2013, 19:31
Hobbiest Programmer
FRC #4525 (Rambot)
I have done that, I could not see any physical damage to the DSC.
Unread 10-04-2013, 20:06
Epicredeemer Epicredeemer is offline
FRC #1626 (Falcon Robotics)
Epicredeemer is an unknown quantity at this point
my team captain wants me to program our autonomous code to have it reverse and then spin 180 degrees. The only problem is that no matter what I put in as the motor values, the robot will either just reverse or it will start to do the harlem shake. Can anyone please take a look at it for me? C:\Users\Matt\Documents\autonomous c...r problems.htm
Unread 11-04-2013, 19:51
lcoreyl's Avatar
AKA: Milner
Wow, fantastic! We're always looking for cheap solutions using old "trash".
Unread 12-04-2013, 13:01
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
You might want to look at that URL you posted. It's going to be kind of hard for us to look at something sitting on your computer.... And you might want to find a thread that's more closely aligned to your problem, or start a new one. More of the right people might see it.
Mentor http://www.teamtitanium.org/
Unread 12-04-2013, 13:12
See posts 17 thru 21 in this thread:
http://www.chiefdelphi.com/forums/sh...d.php?t=115970
Unread 12-04-2013, 13:22
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
I don't have one but I saw this and it looks kinda cool.
http://www.robotshop.com/seeedstudio-dso-nano-v2-1.html
http://www.robotshop.com/oscilloscopes-generators.html
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
