Go to Post Each year that I've been on the team I've thought to myself, "Man we lost some great seniors this year," and each year younger students have stepped up on their own to fill those leadership positions. - BJC [more]
Unread 12-04-2013, 14:57
FTC5096 FTC5096 is offline
AKA: Kim Daugherty
FTC #5096 (Monkey Madness)
FTC5096 is an unknown quantity at this point
[FTC]: Strengthening 3D printed parts
A local community college offered to 3D print the ring grabbers that we designed for this season. Although the grabbers are quite strong, we are concerned they may break upon an impact with another robot.
Is there a process that we can use to strengthen the grabbers? We wondered if there is a coating or dip that we can apply.
Unread 12-04-2013, 15:12
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: [FTC]: Strengthening 3D printed parts
Something Like plastidip?
You can also try to apply plastic solvent like metheyl ethyl ketone(with proper ventilation and respiration) on the surface of the plastic to weld the layers together more.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 12-04-2013, 15:18
AKA: Kim Daugherty
Thanks Kevin. Have you tried either of these approaches?
Unread 12-04-2013, 15:55
Imaginary Friend
AKA: Kevin Li
Team Role: Student
I have tried the MEK but no the plasti dip. We were using it to strengthen and waterproof our 3D printed nozzles.
Kevin Li
596 - Sciclones
Unread 12-04-2013, 19:48
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Not much help in terms of adding strength to the part, but do consider the printer orientation. The horizontal layers are stronger as there is entanglement within the layer as the abs is hot but much weaker due to less entanglement between the horizontal layers as they have cooled to some extent between passes. So think of it like a carpenter cuts a part out of wood which has grain.
Maybe you or the college has already considered that aspect. If not build them in two or three different orientations and see is one better than the other for your application.
Other thought is to build a metal shield of some type that doesn't interfere with ring grab and hanging but affords some level of protection from bumps in the field...
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 12-04-2013, 21:23
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
You could add some ribs to the design; some 45-degree ribs where the cup of the grabber meets that flange, and some 'U'-shaped ribs, or even a grid of ribs, around the cup shape would help.
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 16-04-2013, 18:47
Enderbot's Avatar
Enderbot Enderbot is offline
FTC #5484 (Enderbots)
Enderbot is an unknown quantity at this point
You could possibly try covering it in fiberglass fabric and resin. Keeps its shape when the core is broken.
Take crates and place them elsewhere. Basic ability.
Unread 16-04-2013, 21:51
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
I have seen products that use the 3d printed part as a mold to make a part. Cast the part into silicone then use another plastic to cast from it. (see http://justindunham.net/2011/08/maki...printer-parts/ )
You can coat the plastic in resin, possibly with some reinforcing such as carbon fiber, fiberglass or microspheres, but I would be sure (And test) the plastic wont react to the resins. Also if you don't do it neatly it will show...nothing some sanding and a coat of paint wont cover hopefully
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 17-04-2013, 11:43
AKA: Kim Daugherty
Thank you for the fiberglass recommendation. We will try it this weekend.
