Go to Post The game hint is never late. Nor is it early. It arrives precisely when it means to. - Oblarg [more]
Unread 13-04-2013, 00:51
DjParaNoize-'s Avatar
DjParaNoize- DjParaNoize- is offline
DjParaNoize- is an unknown quantity at this point
RGB LED Help
I've Got Some Addressable RGB LEDs (Strip) (WS2801)
I Need help hooking them up to my arduino I've tried example codes but they seem to have an error or don't work
Unread 13-04-2013, 00:52
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Re: RGB LED Help
What is the error?
2016: FRC 865 Mentor
Unread 13-04-2013, 00:58
Re: RGB LED Help
Originally Posted by mman1506 View Post
What is the error?
CODE:
// walking r-g-b
for (int j = 0; j < 3; j++) {
memset(leds, 0, NUM_LEDS * 3);
for(int i = 0; i < NUM_LEDS; i++ ) {
switch((i+j) % 3) {
case 0: leds[i].r = 200; break;
case 1: leds[i].g = 200; break;
case 2: leds[i].b = 200; break;
FastSPI_LED.show();
delay(300);
ERROR:
expected unqualified-id before 'for'
Please excuse me For I am Somewhat New to the coding
Unread 13-04-2013, 01:02
Re: RGB LED Help
Resource:
http://davidbu.ch/mann/blog/2011-09-...led-strip.html
Unread 13-04-2013, 01:04
ttldomination's Avatar
Sunny
Re: RGB LED Help
Looks like an issue with function structure.
Is your code in main()?
Is your function header correct?
Additionally, it's often a good idea to google your errors. There's rarely an error that StackOverflow hasn't seen.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 13-04-2013, 01:13
Re: RGB LED Help
- Sunny G.
im honestly confused .
lets just start from the beginning and code this.
Ok What I want to do first is just power the LEDs
Unread 13-04-2013, 01:27
Sunny
Re: RGB LED Help
I personally do not know how to work with arduinos/LEDs, I suppose someone else could help you out there.
But seriously, Google.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 13-04-2013, 01:30
Pendulum^-1's Avatar
Pendulum^-1 Pendulum^-1 is offline
AKA: Jim Grove
FRC #1915 (Firebird Robotics)
Pendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nice
Re: RGB LED Help
I got a set of this light strip from adafruit. Tutorial was great.
http://learn.adafruit.com/digital-led-strip
Go to the menu on the left side of the page, read through the code, wiring, troubleshooting, etc.
Took me a bit of homework to get mine working, but it now works like a champ. I simply used their example code from their Arduino library (see the code page), and modified it to get the behavior I wanted.
Jim Grove, Mentor
firebirds1915.blogspot.com
(2007-2017) 1915, McKinley Tech HS, Washington, DC
(2009) 2932, Mid-Pac Institute, Honolulu, HI (Rookie Season)
(2011) 2425, Hillsborough HS, Tampa, FL
(2013-2015) 4464, College Park, MD, 2013 Rookie All Star Winner and 2014 Regional Champions, Washington, DC
FIRST is not rocket science. But it is like drinking from a fire hose.
Unread 13-04-2013, 01:40
Re: RGB LED Help
currently reading this info
Unread 13-04-2013, 02:23
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Re: RGB LED Help
Adafruit's tutorials are the way to go.
If you haven't used an Arduino before, it's C, but they hide main(). You use setup() once to set up, then loop() for every loop. Make sure you download the LED libraries (Adafruit will point you the way) and put them in the Arduino \libraries. The LED library has examples of simple code to give you an idea how to light up.
Hardware tip: If you power the LEDs separate from the Arduino, make sure you run a ground wire between the two. Otherwise it'll be exciting lighting but not remotely what you want. (It won't ruin them, btw.)
Software tip: I forget the exact command, but if you're using Adafruit's library, if you don't do ".show" before the end of loop() the LEDs won't update.
Unread 13-04-2013, 03:02
Re: RGB LED Help
Thanks you guys got it working!
Unread 30-07-2013, 02:57
kathy82's Avatar
kathy82 kathy82 is offline
Junior Member
kathy82 is an unknown quantity at this point
Re: RGB LED Help
ToDo:
Download the Library from here(https://github.com/adafruit/Adafruit-WS2801-Library) to use this script!
Function:
Changes the color between /Black (off)/Red / Green / Blue /White) with a delay of 1 Second.
BTW, I got my ws2801 led pixels from http://www.lightingnext.com/12mm-ws2...ed-pixels.html
