Go to Post ...before we ship the robot, they have to make me understand how it works. - Beth Sweet [more]
Unread 13-04-2013, 18:31
bs7280 bs7280 is offline
FRC #3734
bs7280 has a spectacular aura aboutbs7280 has a spectacular aura aboutbs7280 has a spectacular aura about
Help Identifying part
Hello! The team that I am on is looking to build a swerve drive module in the off season as a proof of concept/learning experience. I have noticed a part that would be very helpful to us that I have seen in some photos online, but I can not find it anywhere. I have (crudely) circled in the attached photo.
Any help identifying/locating the part would be very much appreciated and would greatly help our off-season build.
Edit: To Clarify, we don't need the exact part (though it would be nice), but the name of this type of part and where to get it would be great as well.
Unread 13-04-2013, 19:05
Patrick Flynn Patrick Flynn is offline
Patrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond repute
Re: Help Identifying part
That is a swerve module sold by 221 robotic systems. I'm not sure if they will sell that specific part independently. But I would recommend getting in touch with them. Their very helpful people.
http://www.team221.com/order.php?cat=5
Unread 13-04-2013, 20:37
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I'd probably best describe the part as a swerve module rotation bearing block. The creators of the system probably have their own, different name. This type of part is extremely specific to FRC, and I doubt that you'll be able to find ones outside of FRC suppliers like AndyMark and 221 Robotics Systems.
Generally, the CD community is a lot more helpful if we know your goal. Is this to build a swerve drive in the offseason?
EDIT: Apparently I can't read, yes, they are building a swerve drive.
-Plutarch
Unread 13-04-2013, 20:47
T^2 T^2 is offline
FRC #5499
Apparently so.
Unread 13-04-2013, 21:02
FRC #3734
If we can not find a specific part like this, anything else that will allow us to attach the wheel module to the frame while allowing the gear for rotation being attached (obviously) would be just as helpful
Edit: clarification
So I was able to design a swerve drive module like above, where one gear is attatched to the shaft, which will power the wheel. The other gear would be attatched to the frame of the module, allowing for rotation. The tricky part was attatching the whole module to the frame without messing up the rotational gear
Unread 13-04-2013, 21:11
FRC #1836 (MilkenKnights)
You might want to start looking at CADs of swerves. 973 ran a mechanically solid swerve and posted their CAD. Basically you want a large ball bearing for radial loads, a thrust bearing, and some kind of gear/pulley/sprocket for rotation
Unread 14-04-2013, 00:27
FRC #3734
Im having trouble finding it? do you know where it would be?
Unread 14-04-2013, 01:05
nerdherdmember's Avatar
nerdherdmember nerdherdmember is offline
#letsdothis
AKA: Harrison (That kid with the blue hat)
FRC #0422 (Mech Tech Dragons)
nerdherdmember is a jewel in the roughnerdherdmember is a jewel in the roughnerdherdmember is a jewel in the roughnerdherdmember is a jewel in the rough
According to the product page on 221 systems, they are using an oilite bronze bushing. Although a specific McMaster-Carr part number was not listed, something that fits the dimensions of your designs can surely be found on McMaster-Carr. I wish you the best of luck in your swerve project. Don't be afraid to post here for more help if you need it, and be sure to post the final results to show what you've done at the end of the offseason! My team isn't quite ready for swerve at the moment, and I always get a little bit jealous watching non-tank drive robots glide around the field effortlessly, although our WCD wasn't too shabby this year.
Unread 14-04-2013, 01:47
FRC #3734
I found another picture that had an interesting looking mounting solution:
What are the black things near the top of the frame of the module that look like they rotate?
What is the larger "Case" or shaft around the smaller shaft that powers the wheel?
Unread 14-04-2013, 02:01
#letsdothis
Those appear to be lazy susans.
Unread 14-04-2013, 02:03
Their CAD can be found here: http://www.chiefdelphi.com/media/papers/2567
The one you want to download is emperor swerver
Unread 14-04-2013, 02:04
Those are what some folks would call a lazy susan. I've also seen them called turntables. In essence, it's a very large-diameter ball bearing. Similar to what you circled earlier, only much flatter.
Most folks would call that a sleeve, and it's a second shaft that rotates the wheel.
BTW, there are more types of swerve modules than coaxial, if you wanted to try to locate some pictures. 3928 did some last year where the motor was inside the wheel; I think 16 has done some where the motor is in the module.
Unread 14-04-2013, 02:11
FRC #3734
Here is another photo of another teams swerve drive with a nice mount found here
similar to the team 221 product, but would love to know where this came from, as it is way better of a solution than what we would have probably done.
Unread 14-04-2013, 18:56
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
You can find details about ours here.
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
Unread 14-04-2013, 19:02
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
As others have said, those are lazy susans. I would be hesitant to use them in a swerve drive. If you put any significant side load on them (Which can happen very easily on the field), I've seen the bottom and top halves of them pull apart and warp, which ruins them very quickly.
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
