Go to Post It's our first time actually doing the math for all of our mechanisms and for some reason math actually works. - Ginger Power [more]
Unread 13-04-2013, 23:03
Owen Makin Owen Makin is offline
FRC #1972
Owen Makin is an unknown quantity at this point
Re: Troubleshooting Autonoumous
Well it looks very messy to me, because it seems there are many unnecessary while loops with no values being plugged in. Try writing down what you want the robot to do for how long and set up a timed sequence that executes everything as time progress .
Unread 14-04-2013, 13:37
Epicredeemer Epicredeemer is offline
FRC #1626 (Falcon Robotics)
Epicredeemer is an unknown quantity at this point
Well there is a reason for the way it is. It's my first year as programmer and I had, and still don't have, any idea as to how the timing works. But we ended up just letting the robot back up and stop. It would still be nice to know how to have it spin after for next time, though.
Unread 14-04-2013, 14:53
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
I would highly recommend going through some of the tutorials there are for labview online.
I haven't used labview in FRC for the past few years, but I found these guides immensely helpful back when I was using it:
http://www.frcmastery.com/
The guy that narrates these is very knowledgeable and covers a large number of beginner and advanced topics quite well. It would be to your bennefit to go through these guides and understand some of the concepts.
It looks like NI has put up their own set of instructions for 2013.
I quickly looked through, and a slight modification to this guide would probably help you do what you were looking for (driving back and then turning).
[EDIT] On closer look the auto mode "tutorial" isn't much more than some screenshots and isn't much of a guide. I'd suggest watching this video from frcmastery on the 2011 auto mode code. It should be helpful in understanding how to structure an auto mode to do what you want.[/EDIT]
If labview is something you're interested in learning more about, in preparation for future years, go through the guides linked above. Even the ones that don't sound like they will be relevant to something you need to know will likely teach you something new.
http://team2168.org
Unread 14-04-2013, 14:56
thank you very much for the advice and links. I think I will go and take a look at them.
Unread 22-05-2013, 20:22
Vision tracking
OK. I've gotten past the autonomous issues, but I now have another problem. My team's driver and shooter operator want me to put together a vision tracking system. I have no idea how to do it, so I could really use some help.
Unread 29-06-2013, 08:58
Re: Vision tracking
In addition to this, we have been having issues with our compressor. As soon as the robot turns on, the compressor either turns on or stays off, without being enabled, and it stays that way until the robot is turned off. We've tried changing the PWM, the spike, the PWM port on the digital side car, but nothing has seemed to work. And this issue came out of the blue. It was working at our last event, then when we went to get ready to go to an off-season event, there was a problem.
Unread 04-07-2013, 14:30
Re: Vision tracking
It might just be lazy terminology on your part, but a Spike does not connect to a PWM port. It connects to the Digital Sidecar pins labeled specifically for relays. Describe exactly where each wire goes so we know you've done it correctly. There should two wires between the Spike and the compressor, two between the Spike and the Power Distribution Board, and three between the Spike and the Digital Sidecar. Clear pictures would be ideal.
Unread 04-07-2013, 14:37
Re: Vision tracking
not entirely sure waht we did during that last competition, but after changing some stuff in the code and I dont know what on the robot, we got the compressor working properly again. now I just need to figure out vision tracking...
Unread 04-07-2013, 15:57
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Re: Vision tracking
Hopefully someone more knowledgeable than me can chime in, but my understanding is that unless you are experienced enough to code your own vision tracking, RoboRealm is the way to go. But, that is literally all I know about it, so unless somebody else comes along your on your own.
P.S. Keep up the good work. Its great that your asking questions. In my opinion the role of programmer is the most under-appreciated, abused, and difficult role on most teams... Someone remind me again why I decided to learn java over the summer?
Unread 04-07-2013, 16:35
ErvinI ErvinI is offline
AKA: Ervin Ibadula
FRC #0865 (Warp7)
ErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really nice
Re: Vision tracking
Team 341 released their vision tracking widget using OpenCV on the SmartDashboard which makes an excellent starting point for making your own vision tracking widget. It was very useful for us.
The paper can be found here.
