Go to Post Leave it to Cheif Delphi to make a thread go from discussing the imminent game hint to discussing what is the superior pizza topping. - BriteBacon [more]
Unread 14-04-2013, 08:23
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Re: pic: 2175 Wheel v2
Here is a part you can use for testing hex tolerances for 1/2" nominal shafting.
You can get the model here.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 14-04-2013, 16:38
nerdherdmember's Avatar
nerdherdmember nerdherdmember is offline
#letsdothis
AKA: Harrison (That kid with the blue hat)
FRC #0422 (Mech Tech Dragons)
nerdherdmember is a jewel in the roughnerdherdmember is a jewel in the roughnerdherdmember is a jewel in the roughnerdherdmember is a jewel in the rough
After looking through your picasa and thingiverse postings, would you clarify for me what constitutes removing support structure, and is "full support" an automatic option?
Unread 16-04-2013, 09:42
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
When you print many objects on a 3D printer like the Replicator, the printer needs to build up a support structure to print onto when a piece of the part would be up in the air. After the printed piece is done, this support structure needs to be removed from your part to get your finished piece. This is usually just breaking off the mesh type support system that gets printed.
Here is an example of a part with the support system still attached.
http://cdn.shopify.com/s/files/1/003...jpg?1286806837
Unread 16-04-2013, 10:12
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
The software we use to go from STL files to the X3G files that are used by the Replicator is "ReplicatorG" with the Sail Fish modification.
http://www.makerbot.com/sailfish/install/
Sailfish firmware adds velocity profiling to the Replicator, so it prints faster and with better quality. If you have two nozzles (we do), it also adds "ditto printing", which allows printing from both nozzles simultaneously. This lets you print two parts at once, if they are smaller than the spacing between the nozzles.
The options for rafts and support structure in ReplicatorG are tricky and finicky. Unfortunately, they don't always work as advertised, and you need to experiment with the settings and part orientation to get things to work right. The software uses the last settings as the default for the next part, so in that sense, it is "automatic", but I believe the installed default was with rafts and support structure turned off.
Todd F.
Photo gallery
video channel
Triple Helix mobile
