Go to Post The reason I care about it is that I don't want minorities (whether that's females or other racial minorities) to see the STEM world as only inclusive of majorities or men. - Monochron [more]
Unread 13-04-2013, 00:15
ice.berg's Avatar
ice.berg ice.berg is offline
Strategy Mentor & Drive Team Coach
AKA: Alex Bergal
ice.berg has a spectacular aura aboutice.berg has a spectacular aura about
Re: No Pneumatics?
Well before 2012 we didn't use pneumatics at all. But with our octomecanum system last year we were forced to use it. This year we use pneumatics for a whole ton of stuff: floor intake, octomec. system, and disc feeding. But the nicest part about it is sensors, or lack there of. In 2011 we had a whole variety of limit switches that would always break. Now with the pneumatics the systems can be made much simpler and more reliable.
The key is:
-Follow the rulebook the first time. Make sure all your fittings tubing etc. is all legal and COTS
-Do the soapy water check, spray down all your components while under pressure with soapy water and check for leaks otherwise they will be the death of your robot
-Off-board compressor with plastic tanks, we roughly measured that we could put 6~7 tanks on our robot before having an on-board compressor would be worth it
-Do the calculations for your actuators, make sure you arent overdoing it and using the minimum amount of air needed in order to actuate it under load.
TEAM 2512 DULUTH EAST DAREDEVILS
'12-'15: Strategy and Build Mentor
'15 Hopper Division Champions and Einstein Finalists thanks 987, 2826, 4265
'15 Minnesota State Champions thanks 3130 and 4215
'15 Northern Lights Chairmans Winner and Regional Finalists & Central Illinois Regional Finalists
'10-'11:Build Captain
'13 Midwest Champion '12 North Star Champion '11 Lake Superior Champion
Website Facebook Twitter Youtube Flickr
Unread 14-04-2013, 00:03
jar24 jar24 is offline
Manufacturing Engineering student
AKA: Jacob
FRC #5162
jar24 will become famous soon enoughjar24 will become famous soon enough
Re: No Pneumatics?
my team generally uses them every year but we ruled it out because of the weight that it adds, the space they take, and how fast it kills battery's and we did the best in our teams history.
Student
FRC team 468 Aftershock
2010 - 2013
FRC 5162 - The Big Red Theory 2013 - Present
FRC 5448 - The Cosmic Chaos Automationeers 2014 - Present
FTC 7837 - The Thunder Colts 2013 - Present
Alumni
FRC 468 - Aftershock 2010 - 2013
Unread 14-04-2013, 07:40
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: No Pneumatics?
On 562, my team as a student, we used pneumatics every year except for Lunacy. We had a couple successful robots, no regional titles, but those robots were very strong.
Since joining 3623 (and even before, during their rookie year) we have not used pneumatics. We were pondering whether to use them this year to hang, but considering our design and the weight penalty comparatively (Our robot was 89 pounds, IIRC) made using pneumatics just for one system impractical. We had no problems without it.
Think about using it year to year, but make sure you know how to use it and set it up correctly. I'd never be opposed, but think about usage.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 14-04-2013, 08:41
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Re: No Pneumatics?
We have not used pneumatics on a robot since 2004.
It's not that we are opposed to using them, we just typically haven't found the tipping point of enough mechanisms that would need that type of actuation to make the investment in weight, packaging, etc...to put a pneumatic system on one of our machines.
With not using them for so long, I think if we are seeing mechanisms differently such that we think a motor and gearbox would work better. I'm sure if we started using pneumatics, we would find plenty of uses for them.
For this year, we were planning on having them on the robot but ran out of space for almost everything. We scrambled to even find room for the battery and cRIO, so even a "passive" pneumatic system without a compressor was pretty much impossible for us. Corner climbing systems take up a lot of space.
-Adam
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 14-04-2013, 09:38
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: No Pneumatics?
We've used pneumatics every year (starting 2006) except 2009 for Lunacy. Pneumatics are great, they let you put the weight where you want it (the compressor can sit at the bottom center of the robot, or be moved to either end to help balance) and you can add lightweight actuators wherever you want, without having to hassle with gearboxes and extra motors and speed controllers....and limit switches, encoders, PID loops, and all that fun stuff.
Our Lunacy robot moved balls in and out with motors and rollers, it worked very well. That year we got by with only one encoder and PID loop, the rest of the motors were just run when needed.
In the end, it doesn't really matter whether or not you use pneumatics, you can make a great robot with them or without. You'll learn different things, depending on what you use. It's all good.
Unread 14-04-2013, 13:27
RonnyV's Avatar
RonnyV RonnyV is offline
All of the above
AKA: Ron Visser
FRC #4481 (Team Rembrandts)
RonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud of
Re: No Pneumatics?
We used them this year. Our rookie year, and I wished we would've used them more!
I really love pneumatics because of the speed/torque. And once it's airtight u don't have any problems at all.... like PWM cables coming lose during a game or something. Only down sides was your inches etc....
We as a Dutch team use different measurements etc.. gave us a set back from a round 1,5 week with stuff we needed to order.. but we got a great robot
And we're going to St. Louis and hopefully make it to our divisions eliminations!
Unread 14-04-2013, 13:44
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
Re: No Pneumatics?
There are a number of areas in which pneumatics out-perform motors (and, of course, visa-versa). Team 1640 usually uses pneumatic devices in our robots, but in two cases (2006 & 2012) we did not for weight-saving reasons.
Having the ability to utilize pneumatic actuators in our design process provides additional degrees of freedom to enable us to design the best robot that we can. More degrees of freedom increases design difficulty, but potentially (generally) improves the product performance. Having more degrees of freedom does not mean that you need to use them; this is part of the design decision tree which engineers need to make.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 14-04-2013, 15:30
Vikingtech2054's Avatar
Vikingtech2054 Vikingtech2054 is offline
FRC #5162 (The Big Red Theory)
Vikingtech2054 is an unknown quantity at this point
Re: No Pneumatics?
We have used pneumatic every year you team has existed, i think if you know how to use them right and for the right applications they work well. There much fast than motor but there mainly limited to two positions. Heres a link to our 2011 robot with a fully pneumatic arm and it was a very good robot. We won an event with it, one off-season event, two-time finalist (divisional Finalist) and semi-finalist at MSC.
Ferris State University-Manufacturing Engineering (BS)
FRC 2054: Student 2010-2013
FTC 6283: Mentor 2012-????
FTC 5980: Mentor 2012-????
FTC 7837: Mentor 2013-????
FRC 2054: Mentor 2013-????
FRC 5162: Mentor 2014-????
FRC 5448: Mentor 2016-????
FRC 5576: Mentor 2015
Unread 14-04-2013, 16:05
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Re: No Pneumatics?
Very interesting design, but I can't see any air storage tanks in the photos, how many did you have, and where were they located?
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 14-04-2013, 16:20
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: No Pneumatics?
I see 3 metal ones on this picture.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 14-04-2013, 16:25
Tommy F.'s Avatar
Tommy F. Tommy F. is offline
Yeah! Collages!
AKA: 7h0m45
FRC #1985 (Robohawks)
Tommy F. is just really niceTommy F. is just really niceTommy F. is just really niceTommy F. is just really nice
Re: No Pneumatics?
1985 has never used pneumatics on a competition bot. I would suppose that our main reason for not using them is the weight; I think this year is the only year we've fielded a robot under 119lbs. The other factor has been the size required for the tanks and actuators and cylinders. We also like the added bonus of being able to skip the pneumatics portion of inspection. And since we have hardly used them at all, we find it easier to have a motor can complete a task rather than having air complete it, but that's just us. We've seen plenty of teams be very successful with pneumatics in their designs, so do whatever your team is good at.
FTC 289, 290 & 291 :: FRC 1985
2013 St. Louis Regional Semi-Finalist (with 3411 and 4330), Industrial Design Award
2013 Queen City Regional Winner (with 379 and 447)
Unread 14-04-2013, 16:37
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Re: No Pneumatics?
Originally Posted by ZehP View Post
... a lot of our leaks were coming from off-square cuts on the ends of tubes. This caused them, when plugged into a fitting, to not form a perfect seal. We solved that problem this year with a pneumatic tubing cutter that makes it difficult to make a bad cut.
These are an absolute necessity. Perfect cuts every time!
The tubing cutter linked above looks to be similar to McMaster-Carr pn/ 8288A51. Does anyone know from experience if one of these works better than the other?
Richard Wallace
since 2003
Unread 14-04-2013, 17:31
CENTURION's Avatar
Re: No Pneumatics?
Right you are. With how often that arm would have been used in a match, would those three tanks really be enough to keep up with the air supply required?
I haven't used that design specifically, I believe this is the kind I have used. don't remember the brand, but it looks exactly like that one.
Unread 14-04-2013, 22:24
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Re: No Pneumatics?
I am a huge fan of pneumatics they provide a lot for a alittle. last year we had pneumatics adjusting our shooter, and we could not afford the weight to mount a compressor on board. this year we got the new compressor the light one and it is awesome.
Unread 15-04-2013, 09:32
Re: No Pneumatics?
We ended up actually buying 7 plastic air tanks that were about the same size as those ones and have used them for the last couple of years. I know it sounds like a lot but the robot was really simple compared to having a lot of motors. Mainly there was only four drive motors and 6 solenoids. Especially programming for teleop took like 20 mins which was very easy
