Go to Post Oh, for the love of cod, can't you see that Dave is messing with us just for the halibut? When the actual clue comes out, I'm sure we'll all be singing a different tuna. - Pat Fairbank [more]
Unread 14-04-2013, 17:24
nydnh01 nydnh01 is offline
AKA: Naresh Hing
FRC #1601 (Quantum Samurai)
nydnh01 is an unknown quantity at this point
Encoder For Cim Shaft
I would like to know if anyone has found an encoder that fits onto the shaft of the CIM Motor. The shaft is 5/16" in diameter.
Unread 14-04-2013, 17:43
Re: Encoder For Cim Shaft
It's actually 8mm, which is very close to 5/16.
US Digital sells several encoders that can be configured for 8mm. The E2 has bore options from 2mm to 10mm. The E6 has bore options from 2mm to 1 inch.
If you're looking for something to measure the speed of a shooter, an optical or magnetic sensor may be a better choice.
Unread 14-04-2013, 18:13
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
Assuming your goal is to measure the rpm of a wheel, one thing you may want to consider is using a hall effect sensor. My team used one this year on our shooter wheel and have had no problems at all, whereas we have burned out two encoders elsewhere on the robot.
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
