Re: Integrated WCD "Warp drive" chassis
its lighter as you don't need the blocks and it leaves a little more space inside the robot. You also don't have to worry about wires getting caught in it as much.
You might want to consider some way of tensioning chain
I noticed that the vexpro chassis doesn't have any way of tensioning the chain and I'm hoping the relatively large sprocket surface will prevent the chain from slipping. If it becomes a big issue I will probably add a sliding delrin slider or implement something like the rockbox.
While definitions of WCDs vary, virtually all include cantilevered wheel shafts and sliding bearing blocks for chain tensioning.
I designed a similar system (technical term/name for this style of drive is 'nested tube', see notes about WCD above) in 2011 when I was on 816 and it worked reasonably well, although servicing it was a complete pain - or at least when servicing anything out of the norm. Here are some pictures:
Frame: http://www.chiefdelphi.com/media/photos/36107 Completed Chassis: http://www.chiefdelphi.com/media/photos/36163 Some general specs: Drop Center 6WD 6" AM Plaction Wheels, Roughtop Tread AM Super Shifters, Standard Gearing Direct Drive Center Wheel, #35 Chain to outer wheels. That drive didn't have any method of tensioning* and we never had any issues with the chain tension through two regionals and the off season. The drive only ever had one major failure that I can remember - the tread on one of the wheels came off and lodged itself in between the wheel and the tube.... Other wise, aside from needing to swap out the roll pins in the Super Shifters for 4-40 screws (or the other way around, it's been a while) the drive was solid. * The Chains were 'dead spaced' meaning that they were spaced on exact center to center distances. #35 chain is really easy to dead space as it's a bit more forgiving to misalignment and weird tensions, #25 is a little more difficult, primarily due the tighter tolerances on tension and misalignment. (341's drive this year has a total of 6 #25 chain spans that have been dead spaced, no issues yet *knock on wood*) Another note on dead spacing in drive applications, I only recommend doing so if one of the wheels is direct driven from a transmission. If one wheel is direct driven and all other wheels are chain driven a lost chain shouldn't render the entire drive useless for the rest of the match. |
WCDs also typically direct drive the center wheel off the transmission. This means that both chains must fail to lose both additional wheels. Will you able to quickly replace wheels on this chassis? (WCD cantilevering speeds up wheel replacements).
#7
Each module is only about 60$ of parts without the shifter and we can machine it in our school so if we were to implement it in a comp bot we could just build backup modules. The wheels shouldn't be that tricky to replace, once the chain is removed you just slide it out of the bottom.
#8
You can use a calculator like this one to figure out exactly how far apart your sprockets should be to perfectly take up the slack in the chain.
#10
With a CNC Plasma, I would consider doing drivetrains similar to 610. They have very nifty flat plate drivetrains, and is probably much easier to access and service. They cut their's on a CNC router.
http://www.chiefdelphi.com/forums/sh...&highlight=610 http://www.chiefdelphi.com/forums/sh...&highlight=610 |
#11
#13
A wood panel under the workpiece is one of the easiest ways to do it, plastic is a good substitute, but a bit more expensive. For accuracy, it's common to have the router face a small amount of material off of the top to true it to the spindle. You can also get a vacuum table, but that is also more expensive. |
#14
You can see it in one of the images of there pdf http://team610.com/wordpress/wp-cont...-Edition-4.pdf it's a small picture though. It looks like some sort of a vacuum table with plastic relief?
#15
Not a vacuum table, those strap clamps are definitely doing the holding. I think they just have a sheet of plastic (the black part) as a backing.
