Re: Integrated WCD "Warp drive" chassis
You can use a calculator like this one to figure out exactly how far apart your sprockets should be to perfectly take up the slack in the chain.
With a CNC Plasma, I would consider doing drivetrains similar to 610. They have very nifty flat plate drivetrains, and is probably much easier to access and service. They cut their's on a CNC router.
http://www.chiefdelphi.com/forums/sh...&highlight=610 http://www.chiefdelphi.com/forums/sh...&highlight=610 |
A wood panel under the workpiece is one of the easiest ways to do it, plastic is a good substitute, but a bit more expensive. For accuracy, it's common to have the router face a small amount of material off of the top to true it to the spindle. You can also get a vacuum table, but that is also more expensive. |
You can see it in one of the images of there pdf http://team610.com/wordpress/wp-cont...-Edition-4.pdf it's a small picture though. It looks like some sort of a vacuum table with plastic relief?
#7
Not a vacuum table, those strap clamps are definitely doing the holding. I think they just have a sheet of plastic (the black part) as a backing.
#8
At Metal Supermarkets a 6x37 sheet of 6061 0.125 would be $30, and a 6x37 sheet of 5052 would be $24. That is pretty cheap to me, considering you only need 4 sheets. Why 37", and what is your source? Last edited by Gregor : 14-04-2013 at 23:01. |
#9
#10
The top of our router's table has t-slots running down the length. In between the t-slots, the top surface has black Sintra strips glued to the surface. These came with our router, and we replace them around once a year. When we replace the strips, we face them down with the router to make sure the working surface is level. Whenever we cut a part on the router, the cutter goes through the part, and barely scratches the surface of the Sintra strips beneath. This does leave scratch marks on the Sintra, but not enough to warrant replacing them more than once a year. In hindsight, a vacuum hold-down table would've been a nice addition, but we've been able to do without. Cutting COMPLETELY THROUGH plate is easy. Cutting partially through thinner plate is an issue, because the middle section tends to lift off the surface of the table when clamped using the hardware above. |
#11
Over other plastics - yes - it turns out Sintra can be had for quite cheap, and we've started using it for some of our in-class projects and prototypes. Its surface properties are grippy enough to provide a nice clamping surface. Now we don't see the Sintra as a "sacrificial material" as we barely scratch the surface of it when we cut parts. As I mentioned before, these strips last us about a year before they get scratched up badly enough to be replaced. If you were considering using it for a true sacrificial material, where you're trashing the Sintra sheet every time you cut parts, then it's probably not going to be very cost-effective. |
#13
I can't remember any specific issues with sacrificial backing swelling, but I'm pretty sure we've had issues with it in the past. Don't read this the wrong way, coolant (especially mist coolant) is awesome, just swelling in the MDF backing can sometimes mess up milled parts. Also, that film of MDF dust and coolant mixed together that forms after a long day of milling is really gross... |
