Go to Post Supporting a FIRST team, only paying 10 bucks, and possibly winning a segway... what could be better! :) - Tom Bottiglieri [more]
Unread 14-04-2013, 22:20
rKramer rKramer is offline
3157 Lead Programmer (Student)
FRC #3157 (Iron Lancers / Eastridge Robotics)
rKramer is an unknown quantity at this point
Re: Old 2009 Kwikbyte DS
Originally Posted by DonRotolo View Post
A PC power supply is a special kind of switching supply: it requires a certain load on the main power output to regulate properly. Most likely that is the 5 V output, so be aware.
Thanks for the reply.
That is true, however the power supply I used is from 2001 (still works fine, barely ever used it), and I was under the impression that those old ones didn't require a load. If I'm wrong, I suppose I could stick a resistor between 5v and common to solve that, right?
Also, I still haven't figured anything else regarding the DS itself, yet. Gonna do some more research tomorrow.
