Go to Post It's often not the code you are focused on that causes problems, but the code you dismiss out of hand as "unrelated". - Mark McLeod [more]
Unread 14-04-2013, 23:09
gabrielau23's Avatar
gabrielau23 gabrielau23 is offline
FRC #2537
gabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nice
Re: 2054's look back at MSC
Originally Posted by GDG 2337 View Post
Our drivetrain is a custom version of AM’s 446 drive module using a mixture of AndyMark and VexPro parts. As stated earlier, 2 CIMs per side and 8 4” Versa Wheels. The center wheels are direct driven using a standard AM shifter through a 48/50/60 gear set, slightly slower than a standard 446, end wheels are chain driven. What probably set us apart is the longer octagon shaped drive base with 4” side rails and a full length belly pan. I nicknamed it “The Tank” due to its rigidity, which allowed for end wheels to have minimal rocker, increasing pushing power/stability without adversely affecting turning.
Just out of curiosity, how well does it push? (Feel free to brag). I'm just interested because historically in the MarVaDC area a 4 CIM drivetrain with traction (or plaction) wheels is nearly immovable or unstoppable when driving against another robot.
The higher I go up, the the faster the best times in my life (like build season) pass...so sad.
