Go to Post My teams robots have been good, bad and ugly BUT they were all beautiful because they were there. - JohnBoucher [more]
Unread 14-01-2003, 21:23
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
C++/VB Direct3D Mesh Importing Help
I am trying to create a new dashboard program that is 3d using DirectX 8.1 but I'm having a lot of trouble. I was hoping that someone would be able to help me code a Direct3D interface in either C++ or VB that could import a .x mesh (converted from a .3ds) and rotate it as well as possibly make parts of it light up. If I can get this program working, I am planning to make it readily available to all teams. I hope someone can help me (I would prefer VB since I know it better but I know that you can do more in c++ so either will do). Thanks.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 14-01-2003, 22:30
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
That's a HUGE question. Just getting a spinning cube takes many, many, many lines of Direct3D code. How far along are you? Do you know any DirectX?
Anyway, gamedev.net has some excellent DirectX tutorials and examples that you could look at.
BTW, what exactly are you going to make 3d?
Unread 14-01-2003, 22:31
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
yes gamedev.net is an awesome place...
also check out www.pscode.com . there's some really useful stuff on there if you don't rip it off and actually learn from it...
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 14-01-2003, 22:39
I've checked out gamedev and pscode and have used them for quite a while. As to rbayer's question, I've done a small bit in DirectX before (simple polygons with a tiny bit of rotation) using c++ and a bit more using vb. I once tried to import a .x mesh by way of the SDK tutorials but it didn't work correctly. I wasn't sure if it was my code, the .3ds file, or the mesh conversion... I would like to get it working though...
Unread 28-01-2003, 23:30
JonathanE JonathanE is offline
#0619 (CA Robotics)
JonathanE is an unknown quantity at this point
Send a message via AIM to JonathanE
If I am reading this correctly, then if you can spare the time to write all the DX code, that would be a truly AWESOME dashviewer.
Are you talking about a rotating 3D model of your bot, with trouble spots or motor actions or sensor hits lighting up in their positions?
Waaaaayyyyy cool, man.
Sorry, I don't have a clue how to do it, but go for it!
Good luck!
Jonathan E
Team Co-Captain
Team Mentor - Strategy / Design
Student Lead Programmer
Student Lead WebDev
3D Animation Lead and Mentor
Student Lead Electrical / Control
CA Robotics - 619
Charlottesville, VA
Unread 29-01-2003, 04:43
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
There are some great DX 8 tutorials at http://www.andypike.com/tutorials/directx8/. All of those tutorials are good, but the one you are looking for is "Loading Complex Models" where he loads a .x file of a spaceship model he made in milkshape and rotates it with 3 different viewports.
Unread 29-01-2003, 18:58
You got it!
That was where I started. I actually figured out the mesh loading but I'm having trouble modeling a low polygon robot. I'm doing it in Inventor, importing to 3DS, then exporting to .X. I want to make it completely open source and open it to all teams who want to use it. My new problem is that the dashboard port seems to be giving me weird input to the serial. I used the old viewer and it worked fine but the numbers I get are rediculous (negatives, etc)... Hopefully I can figure it out soon and I will upload the first version to our website (http://www.mvrt.org/team555 <--Under construction). I'm going to start a new thread on ideas for the 3D aspect. Please post any ideas you have.
omniwheels on steel mesh mickjagger Technical Discussion 14 26-01-2003 22:45
Which wire mesh will be used? Jacqui Sutton Rules/Strategy 1 07-01-2003 00:51
