Go to Post Driving without the trailer was quite fun, but driving with the trailer was just painful. - Paul Copioli [more]
Unread 15-04-2013, 19:28
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
pic: Sheet Metal WCD
Unread 15-04-2013, 19:31
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Re: pic: Sheet Metal WCD
Wow looks great. However, I have two suggestions. The top CIM looks like it could warp the plate backwards if it isn't thick enough. Also, I know personally that chain inside tubes is typically problematic, though not impossible. I would recommend all gears if going inside the rails, and even then, you need large access holes. A better alternative would be to let the chain be outside the rain, so you can tension it with ease and access it more easily.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 15-04-2013, 19:56
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
I would be concerned about warping or torquing the frame where the wheels are. We had some minor issues with using 2x1 inch 1/8 wall aluminum tube on our WCD this season, so just a precautionary
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 15-04-2013, 22:16
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
Great job!
Though I agree with the comments above. I would be worried about warping the frame as well especially sustains a strong impact. I would think about gusseting some of the corners as well as maybe adding a mounting point for the gearboxes on that cross beam. That way not all the load is just on that side plate.
just my 2cents
Unread 16-04-2013, 01:34
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
You might want to look into what it takes to put bumpers on a wcd.
Unread 16-04-2013, 07:42
Oh yes. Bumper mounting was a pain this year. It can be done with tube and a welder, but it will be more challenging with sheet metal
Unread 16-04-2013, 08:50
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
On my previous team, we prototyped a 'sheet metal coast drive' in the off-season of 2011 and did sheet bumper mounts and they can be tricky. There is a bunch of information in this thread: http://www.chiefdelphi.com/forums/sh...ad.php?t=98808
-Dustin Benedict
Unread 16-04-2013, 09:36
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is online now
AKA: Sean
FRC #2415 (Wired Cats)
I'm curious what type of issues you ran into with 2"x 1" tube. Was it 6061-T6?
Mentor 2415
Unread 16-04-2013, 09:43
We designed some very simple .090" bumper mounting brackets on 3929 based off of 2826's. They have simple 90* bends to form two tabs on the sides to rivet or bolt through. https://sphotos-b.xx.fbcdn.net/hphot...81089086_n.jpg
That drive also used 2x1 tubing and had 0 issues with the chassis as far as I know. Bellypan was integrated .090" pan into the front and back cross member. 10/10 would build again.
Overall, I must admit I enjoyed designing with 2x1 tube much more than with a pure sheetmetal frame. I felt that it simplified the design and was easier to have parts manufactured with a mix of tube+sheet.
