Go to Post There will inevitably be enough unintentional failure in any endeavor we take on that adding intentional failure on top of that seems unnecessary. - Jared Russell [more]
Go Back   Chief Delphi > Competition > Regional Competitions
  #136   Spotlight this post!
Unread 16-04-2013, 16:54
Racer26 Racer26 is offline
Re: Wild Card 2013
Its not like matches are simultaneously happening on 2 fields. You interleave them. FieldA resets and gets the next 6 robots connected while FieldB plays. You would place them adjacent to one another.
2004 and 2006 Greater Toronto regional were done this way.
  #137   Spotlight this post!
Unread 16-04-2013, 16:57
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: Wild Card 2013
That'd be just as hard to scout.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #138   Spotlight this post!
Unread 16-04-2013, 17:43
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Wild Card 2013
How do teams even change their WPA key for each field in their division?
Not to mention that running matches twice as fast leaves half as much time between a teams' matches. But the travel time between the pits and field remains the same. Basically no time to do repairs.
  #139   Spotlight this post!
Unread 16-04-2013, 18:14
Re: Wild Card 2013
Both fields for a division run the same set of WPA keys, besides, we're the midst of a control system overhaul for 2015. They could easily plan for this capability.
When 1075 went to Atlanta in 2010 I don't recall match cycle times to have been an issue at all. They would get a bit shorter, but not 2x shorter, because you would have more teams
  #140   Spotlight this post!
Unread 16-04-2013, 18:27
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Q&A Dartboard Detractor
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Re: Wild Card 2013
As far as I understand it, we were only using 1 of several halls in the building housing the pits.
That's true... if you're talking about the Georgia World Congress Center. I believe only one of 3 giant halls were ever used for CMP, and I think the entirety of America's Center is used for CMP at the moment, but I could be wrong.
  #141   Spotlight this post!
Unread 16-04-2013, 22:34
Professional Stat Padder
Re: Wild Card 2013
One of the things I hate about the system is that when we won a regional, we didn't generate a wild card spot even though we're an original team and are qualified on that basis.
I think that HOF, Original, World Champion, and World EI winners should generate wildcard spots.
I also think there needs to be some way to give early season event-attendees wild card spots. A great example of this is 2791, Shaker Robotics. Shaker attended BAE Week one and did decently.
They then attended a Week 2 competition, WPI, and with their improvements managed to get the number one seed as well as become finalists. A number of factor prevented them (and us) from winning that regional, but their robot was top-notch. I think if they had the chance, they'd have more improvements at champs and be a force to be reckoned with.
But they do not, as they attended two early season regionals.
I don't know about Chairmans, EI, Rookie All-star generating a wild card spot if the team is already qualified. The criteria for that would be tough to judge fairly.
I also think that if a wild card spot would go unused, it should pass down until it IS used. Possibly to the next highest seed alliance captain, 1st pick, and so on.
(2015-Present)
  #142   Spotlight this post!
Unread 17-04-2013, 01:10
hiyou102's Avatar
hiyou102 hiyou102 is offline
hiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud of
Re: Wild Card 2013
This should also include the Einstein teams from last year. It would have been great to see 216 qualify at the Western Canada FRC Regional.
Team 4334 2012-2014
  #143   Spotlight this post!
Unread 17-04-2013, 01:20
PayneTrain's Avatar
AKA: Lizard King
Team Role: Mascot
Re: Wild Card 2013
For the 2014 season, no more than 23 teams will pre-qualify (barring... complications, or a CCA or EI winner being an original team or CMP winner), and there are currently 22 spots left until FRC reaches its target of 408 this year. Assuming those are all going to be waitlist teams, why not go ahead and say "any team qualified for CMP and wins an event gives up a spot".
Waitlist priority should also be given to finalist captains and first picks. It seems inconsequential on a large level, but a good thing to give to teams.
  #144   Spotlight this post!
Unread 17-04-2013, 01:39
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Wild Card 2013
I think it's an absolute necessity for early season regional finalists to get something out of wild cards. Maybe if a wild card goes unused in a later regional, it goes to whomever would have gotten it at an earlier event, had that team been generating wild cards already.
As towards passing cards down into the semifinals, I don't really know how it could happen. Would you give it to the highest seeding semifinal alliance captain that didn't win? The one who was beaten by the eventual regional champion? Both those methods could work but it ends up being almost luck of the draw (though, waitlist is almost definition of that already).
  #145   Spotlight this post!
Unread 17-04-2013, 10:07
Re: Wild Card 2013
I would pass it to awards before semifinals. More fair that way.
Maybe pass it to ID, EE, or IiC winner first.
  #146   Spotlight this post!
Unread 17-04-2013, 10:16
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: Wild Card 2013
Pre-qualification isn't the only method though--teams also qualify at 2 different times in the same event. Expanding the system, even into just pre-qualification wildcards, leaves no room for growth or a greater percent acceptance. Saying that anyone who's qualified and wins generates a wildcard would have put us over this year (assuming someone accepted).
You're correct that it's a fair and good thing to do, but I don't know how it's sustainable.
This is something a point system could help with. In the MAR point system, Shaker would have finished their 2 events with 89 points. The lowest points-qualifying team MAR sent this year got 77 in their first 2 districts. If wildcards had been reserved from Week 1 and fed into a list of competitors later in the season, 2791 probably would have been near the top of that list. But because of the regional they happened to attend, they didn't get that chance.
I think this whole 'line of succession' thing is begging for some FiM style data
  #147   Spotlight this post!
Unread 24-02-2014, 14:55
Basel A's Avatar
Basel A Basel A is online now
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Re: Wild Card 2013
Is there someone willing to compile this information for 2014? I don't have the time to do it myself this season.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
  #148   Spotlight this post!
Unread 24-02-2014, 15:07
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Re: Wild Card 2013
tl:dr, ....but do HOF teams create an auto wild card, if they should either win the tournament and/or EI?
Cant remember.
Just curious.
  #149   Spotlight this post!
Unread 24-02-2014, 15:10
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Re: Wild Card 2013
Cant remember.
Just curious.
Also, what about previous year Einstein?
2012 - 2015 : 624 CRyptonite
Team Website
  #150   Spotlight this post!
Unread 24-02-2014, 15:11
EricLeifermann's Avatar
EricLeifermann EricLeifermann is online now
That was a short break
FRC #2826 (Wave Robotics)
Re: Wild Card 2013
Cant remember.
Just curious.
They didn't last year, so I would assume they don't this year.
2012-2016 Wave Robotics Team 2826
