Go to Post I heard that the only gift UFH wants on its birthday is an inbox full of nominations. :D - Brandon Martus [more]
Go Back   Chief Delphi > Competition > Championship Event
  #31   Spotlight this post!
Unread 16-04-2013, 17:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Power State Alliances at Champs
Originally Posted by JB987 View Post
Nevada...987 and clones (since we are only team from state going to champs this year).
Can you borrow your neighbors? We and 842 would be happy to help
  #32   Spotlight this post!
Unread 16-04-2013, 17:10
Joe195's Avatar
Joe195 Joe195 is offline
Mechanical Designer
FRC #0195 (Cyber Knights)
Team Role: CAD
Joe195 has a spectacular aura aboutJoe195 has a spectacular aura aboutJoe195 has a spectacular aura about
Originally Posted by MamaSpoldi View Post
I'd have to disagree... a CT alliance without 195 would not be our best. Also 178 is not currently listed as attending Champs. I know they won EI but maybe they opted out??
I would suggest:
175- 5 or 7 auto, gets 2-3 cycles or picks up, 10 point hang
230- 3 auto, 3-4 cycles, 20 point hang - adjustable FCS blocker (if needed)
195- 3 auto, FCS for 3 pt each (very accurate), 10 point hang
Really? Well I didn't check, I thought they were going because of EI too. But I'm factoring in being blocked, which means we can't be as consistent as you three. At least the pyramid you are always safe.
  #33   Spotlight this post!
Unread 16-04-2013, 17:15
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
PA:
341 - When everything is working, they're a top tier ground loader. Has scored 7 auton discs before.
225 - Difficult to block FCS with a super powerful drive train to bulldoze their way to the corner. Can shoot from the pyramid in a bind.
103 - Good scoring machine that has potential to run center line auto. Can also climb for 20 and dump.
HM: 222, 1218, 1640, 1708
VA:
116 - Consistent 3-4 cycle machine that can score from the wings of the pyramid.
422 - 3 cycle machine that can score from the wings of the pyramid
1541- 3 cycle machine that can score from the rear of the pyramid
HM: 1262, 1610
Not at champs: 612, 2363
  #34   Spotlight this post!
Unread 16-04-2013, 17:37
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
I would suggest:
236- 3 auto, 2-3 cycles, 30 point hang +20 point dump- tall enough to block an FCS.
195- 3 auto, FCS for 3 pt each (very accurate), 10 point hang.
Sorry Laura, Gotta go with the Ticks and their almost guaranteed 50 pts, plus what they can do in auto = 18, plus a minimum of 2 cycles = 24 for a grand total of 92.
  #35   Spotlight this post!
Unread 16-04-2013, 17:40
Littleboy Littleboy is offline
FF: The Yellow Alliance (TYA)
Littleboy has a spectacular aura aboutLittleboy has a spectacular aura aboutLittleboy has a spectacular aura about
Originally Posted by Joseph Smith View Post
33, 3539, or 2054 put in 7 in auton, then clean up the missed shots (around 10) by 67 before hanging for 10. If they run out of discs they can play defense. They then hang for 10 points. (82 pts)
If up against a FCS, 2054 would be the best of these 3 (ability to extend to 82"). Otherwise, I think 33 has the most consistent auton of them with the other 2 close behind.
  #36   Spotlight this post!
Unread 16-04-2013, 17:44
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Originally Posted by Hallry View Post
There are a few different groupings that could work. You could also switch out 316 for 25 (especially if they get their 30-pt climb going, or rework a 40-pt climb-and-dump like 103), and 11 for 1676. And if you wanted a full-court shooter, you could throw in 303.
If I remember correctly, 25 had their climb and dump working in Vegas (not sure if everything actually worked together, but it was all there) the week before the MAR Championship.
Originally Posted by Lil' Lavery View Post
PA:
Personally, I think given the opportunity, I'd go with 1640 over 103. 103 is definitely good, but I'm not sure if their style of play would compliment the FCS/Floor Loader Combination well. As I play through a 1640/225/341 scenario in my head, I just see it coming out very well. 1640's to navigate the field quickly and efficiently would leave more than enough space for both 225 and 341 to do what they need to do - and if 225 were to be blocked and/or defended, 1640 is more than strong enough to make up some of the offensive gap - not to mention that they have the ability to feed a floor loader from the opposite end of the field.
-Dustin Benedict
  #37   Spotlight this post!
Unread 16-04-2013, 17:55
JackS's Avatar
JackS JackS is offline
FRC #2791 (Shaker Robotics)
JackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond repute
CT: 195/2168 and then either 230/236 depending on alliance strategy.
NY: 20/4124/3173
MA: 125/126/1100
NH: 131/3467/1519
RI: 78/121/3280
[2009-XXXX] FRC Team 2791 - Shaker Robotics
Colgate University
'16
Last edited by JackS : 17-04-2013 at 01:06. Reason: Forgot 1153 wasn't attending CMP. Replaced with 1100.
  #38   Spotlight this post!
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Am I allowed to claim Missouri as a home state? Kansas doesn't have anyone qualified...
Academic Student (Forever)
  #39   Spotlight this post!
Unread 16-04-2013, 17:58
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Close enough.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
  #40   Spotlight this post!
Unread 16-04-2013, 18:38
Joe195's Avatar
Mechanical Designer
Team Role: CAD
NY: 20/4124/3173
MA: 125/126/1153
NH: 131/3467/1519
RI: 78/121/3280
Don't forget 3015 for NY
  #41   Spotlight this post!
Unread 16-04-2013, 18:47
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
MA: 125/126/1153
Looks like 1153 isn't signed up for champs right now, so I think that 1100 would be the best replacement. I am kind of disappointed that it is just a 3 pure cycler alliance.
  #42   Spotlight this post!
Unread 16-04-2013, 19:58
bnardone64 bnardone64 is offline
AKA: Brian Nardone
FRC #0229
bnardone64 is just really nicebnardone64 is just really nicebnardone64 is just really nicebnardone64 is just really nice
Team 1100 is bringing a floor pickup to St. Louis. I thought 125 also attempted a floor pickup but didn't use it at Boston.
  #43   Spotlight this post!
Unread 16-04-2013, 20:13
Mongai's Avatar
Mongai Mongai is offline
Indian Guy
AKA: Alec
FRC #0935 (RaileRobotics)
Mongai is just really niceMongai is just really niceMongai is just really niceMongai is just really niceMongai is just really nice
From Kansas: 1448 and 1710 would be a cool team. Excellent climber and fine shooting. If only there were more than two teams going to Champs.
  #44   Spotlight this post!
Unread 16-04-2013, 20:26
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Indiana: 868, 447, 234
868: a great cycler that dominated both events they went to and has a lot of potential
447: multi disk auton and fast cycling
234: an accurate and fast cycler
461 Westside Boiler Invasion
45 Technokats
  #45   Spotlight this post!
Unread 16-04-2013, 20:49
Justin Shelley's Avatar
Justin Shelley Justin Shelley is offline
FRC #3885 (Shockers)
Team Role: Driver
Justin Shelley is on a distinguished road
Send a message via MSN to Justin Shelley
This would be my choice of a powerhouse alliance for MO
1) 1986- 7 auto shots, 3-4 cycles, 30 pt climb. 108 pts
2) 3284- when not playing defense, 3 auto, 3 cycles, 10 pt climb. 64 pts
3) 1706- disk auto, 21 fcs at 80%, 10 pt climb, with 2 pyramid shots. 90 pts
1986 will do what they do, be amazing
3284 will put up 18 auto points and be able to push through almost any defense, and when they play defense they have a net that flips up to block FCS or they can block cycling bots with their 2 speed, high traction, 4 cim drivetrain. They can also protect 1706 from being blocked if need be, though I doubt that would be the case.
1706 will put up 18 auto points and then shoot three point FCS with 80% accuracy
