Drive Wheels
Our team used a 6wd pneumatic drive train this year. We had a horrible time turning but when sideways we were practically unmovable.
I was wondering what other teams have had the best luck with in terms of traction and mobility. Thanks for any and all help/info |
Re: Drive Wheels
Many teams have great luck with similar conditions which you described. With your 6WD, did you happen to lower the center pair of wheels at all?
With your question, many teams have been having great success with the new vexpro versa wheels. Teams also have great success with colson wheels. |
Re: Drive Wheels
3397 was more maneuverable than pushy, but we could push in a pinch. |
Re: Drive Wheels
We lowered our middle wheels like you're supposed to in a 6wd WCD drivetrain but for some reason it didn't help out much
Re: Drive Wheels
If you insist on pneumatic tires, you must have (very) dropped center wheels to turn well at the wheel's specified pressure.
Re: Drive Wheels
How much was the drop? I saw you were going with pneumatic wheels this year, and, if the drop was not big enough, it could cause turning problems.
#7
Re: Drive Wheels
With Pneumatic wheels you might have to lower the center wheel more because the weight of the robot will cause your center wheel to squish (and lower the rest of the robot), thus eliminating some of the drop you added. If you also were to deflate your outside wheels slightly, you should also notice a increase in mobility. Edit: looks like the people above me came to the same conclusion Last edited by ehfeinberg : 16-04-2013 at 21:22. Reason: Some people are just ninjas... how do I get trained in this art? |
#8
Re: Drive Wheels
this will be fixed for off season |
#9
Re: Drive Wheels
Re: Drive Wheels
Just so other teams don't run into the same conclusion, what exactly was your drop? 1/8th? 3/16th?
#11
Re: Drive Wheels
I'll measure tomorrow to be for sure but I believe it was about 3/16th of an inch
#12
Re: Drive Wheels
What off-season events are you going to? I would love to see you guys at some!
#13
Re: Drive Wheels
very likely will be at cowtown also ![]() |
#14
Re: Drive Wheels
Awesome! We should be attending CTTD, and, if you get me info, Farmington is close enough to St. Louis that we could make our way down there fairly easily. PM me the details when you have them figured out, we would love to attend!
#15
Re: Drive Wheels
After using both AM plaction and vexpro traction wheels now, I'm confident in saying that I love the vexpro traction wheels. I don't know what performance boost we would get from using the versa wheels over the Traction wheels with extra grip SBR black roughtop from McMaster, so I think we'll be sticking with these champs.
