Go to Post As for Dave and the stairs, just ignore him like the rest of the FRC GDC does... ;) - Rich Kressly [more]
Unread 16-04-2013, 21:56
Justin Shelley's Avatar
Justin Shelley Justin Shelley is offline
FRC #3885 (Shockers)
Team Role: Driver
Justin Shelley is on a distinguished road
Send a message via MSN to Justin Shelley
Re: Drive Wheels
Originally Posted by Wing View Post
After using both AM plaction and vexpro traction wheels now, I'm confident in saying that I love the vexpro traction wheels. I don't know what performance boost we would get from using the versa wheels over the Traction wheels with extra grip SBR black roughtop from McMaster, so I think we'll be sticking with these champs.
I have heard a lot of good news about the vexpro products, and have been considering using both the vexpro ball shifter and the vexpro traction wheels
Unread 16-04-2013, 21:57
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Re: Drive Wheels
We had a lot of success with colsons this year. We were able to hold our own against teams running rough and wedge top. We did not even add grooves to our wheels. We are going to have to try a higher torque pushing gear with grooved colsons next year.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 17-04-2013, 09:06
Team Role: Driver
Re: Drive Wheels
What size wheel did you use?
Unread 17-04-2013, 09:27
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Drive Wheels
Over your 2 regionals this year, how much rubber wear did you experience? Do you have pictures of a new wheel vs your worn wheels now? Is there any different in diameter between the worn & new wheel ?
GitHub
Unread 17-04-2013, 09:41
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
Re: Drive Wheels
As for wheels, I still think Colsons are king. They're incredibly easy to use with hubs from: West Coast Products. We use 4" wheels with our own tread cut into them.
Unread 17-04-2013, 09:53
Re: Drive Wheels
3929 also had a great experience with Colsons this season. 4" Colsons in a 6 wheel WCD had minimal wear after two district events.
https://sphotos-b.xx.fbcdn.net/hphot...81089086_n.jpg
10/10 would use again.
Unread 17-04-2013, 10:05
sodizzle's Avatar
sodizzle sodizzle is offline
AKA: Brandon Sidoti
FRC #1023 (Bedford Express)
sodizzle is a jewel in the roughsodizzle is a jewel in the roughsodizzle is a jewel in the roughsodizzle is a jewel in the rough
Anyone using custom wheels? I was wondering what advantages custom wheels give. I've seen quite a few strong teams using 3D printed wheels and cnc'd aluminum wheels.
Proud alumni of 1023
http://www.chiefdelphi.com/forums/ximage.php,qtype=sigpic,auserid=64794,adateline=13  93953662.pagespeed.ic._coysrOV9p.jpg
Unread 17-04-2013, 10:15
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: Drive Wheels
It would be hard to beat the performance vs cost and ease of use of VersaWheels. It doesn't get much cheaper than $5 per wheel, and they're easy to connect to the (also inexpensive) hubs, bearings, and sprockets. I wonder if Vex will investigate different polymer materials for their tread since some teams have somehow managed to wear it down. Our team wore down the two front tires after two competitions, but we will be able to spare the $10 to replace them at the Championship. We've been very happy with the traction we get - we ended up slowing the drive down, because it took a bigger gear ratio than expected to get them traction limited.
Has anybody compared traction and durability between AndyMark 4" FIRST Wheels and 4" VersaWheels?
Unread 17-04-2013, 12:28
Head Mentor
Re: Drive Wheels
We used the 3.5" wheel.
I will try to get some picture later but there was hardly any wear. I remember blue specs of carpet embedded into the wheel . We had spares but we never found a need to swap them. This years drive train was a collaboration with 766. They drove their robot a lot harder (our robot spent half the match climbing), I will ask them to measure their wheels.
Unread 17-04-2013, 15:28
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Re: Drive Wheels
We thought about using Colsons this year (we really wanted too), but could not figure out how to make a dead axle hub that worked for a 1/2" diameter shaft.
The hub wall thickness get's really thin trying to make room for a 1/2" diameter bearing.
We could have gone with 3/8" steel axles, but did not want to make that drastic a change to our wheel mounting setup.
We ended up using the 4" VEX Versa Wheel, which has been great in all situations outside of driving up the pole for climbing, when we were spinning our wheels on the tape.
We think we fixed that issue by paring a 3.875" blue banebot wheel next to the rear Versa wheel, that seemed to have given us enough traction to start the pole climb.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 17-04-2013, 20:59
Kestin Goforth Kestin Goforth is offline
FRC #5406 (Celt-X)
Kestin Goforth is an unknown quantity at this point
Re: Drive Wheels
Last year, 1503 used pneumatic wheels in an 8WD config and we found that our drop was not as much as we needed. By over-inflating the inner wheels and under-inflating the outer ones, we had a much better time turning. Though if you do this, be careful not to inflate the inner wheels too much or they can puncture much easier.
Unread 17-04-2013, 21:08
Re: Drive Wheels
330 ran a 6WD all pneumatic (with drop) back in 2006. That lasted less than one event before at least one pair of pneumatics was swapped out for KOP wheels. (I forget if it was one or two, but I know the front wheels were swapped.)
Unread 17-04-2013, 21:19
saikiranra's Avatar
saikiranra saikiranra is offline
UCI
AKA: Saikiran Ramanan
saikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond repute
Re: Drive Wheels
We originally went with 3 inch *citation needed* Colson wheels, until we realized that we could use a small bag of zip-ties to prop up the robot (way less than a quarter inch of clearance between the ground and our chassis). We quickly CADed up some nice looking wheels and CNC Milled them out of aluminum. We also riveted on some nice, black rough-top tread for more gripy-ness. It worked and looked great!
2014 - Current: Team 3476 Electronics, Programming, and Scouting Mentor
2011 - 2014: Team 696 Student and Drive Coach
