Go to Post A drag racer can have all the output torque in the world, but it does no good on ice. - Paul Copioli [more]
Unread 06-10-2002, 14:54
Hailfire Hailfire is offline
AKA: Jason
Hailfire has a little shameless behaviour in the past
Send a message via AIM to Hailfire
Programming Languages
Is C++ also used in the competitions? Or not?
Unread 06-10-2002, 15:19
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Depends. Not on the bots, but some people have made dashboard programs, databases, and Palm scouting apps in C.
Jeff Waegelin
Unread 06-10-2002, 15:41
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Same as above. All we use in the comp is PBASIC, but most of the little utilities people have written are either in C, C++, or VB. PBASIC is useless for anything other than robots.
Unread 06-10-2002, 17:27
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
yeah, me and dan just finished our really cool (and completely unneeded) dashboard program. it's probably the first of it's kind. C++ to grab the data, Flash to show the data. so our program looks much cooler than all of yours (or so i'm told). the only problem is that the program seems to start grabbing incorrect data from the robot after a while, but i'm atributing that to the fact that the battery voltage was at about 8.6 or so when we noticed that. the strange part is that it always did the same pattern, just sometimes it took longer to screw up then other times. very strange :/.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 06-10-2002, 17:42
El Jefe de 148
If you get your program working right, could you post it in the white papers? I'd be interested in something like that. If you prefer to keep it to yourselves, though, I won't mind too much.
Jeff Waegelin
Unread 28-01-2003, 23:36
JonathanE JonathanE is offline
#0619 (CA Robotics)
JonathanE is an unknown quantity at this point
Send a message via AIM to JonathanE
I also would like to see some C++ source for a dashboard viewer. I have no experience with the Windows API or any of Microsoft's APIs... This would help a lot, since I am expecting to have to write a dash viewer this year...
Also: What types of data are people storing in database programs for scouting? I have heard several references to teams writing programs in VB to run on their Pocket PCs that they can take around to scout for alliances... What is the purpose of this? I am guessing that teams would record what the functions of the other teams robots were, etc...
Jonathan E
Team Co-Captain
Team Mentor - Strategy / Design
Student Lead Programmer
Student Lead WebDev
3D Animation Lead and Mentor
Student Lead Electrical / Control
CA Robotics - 619
Charlottesville, VA
Unread 29-01-2003, 09:20
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Here you go:
http://www.bontragers.net/first/FirestormDashboard.zip
I'll warn you that I really haven't touched that code since 2000. The format has changed slightly but that's just a relabeling of one of the data elements. I used to have a web page with some more information about it but I can't find it. I hope that's helpful in some way.
Matt
Unread 29-01-2003, 21:10
#0619 (CA Robotics)
Thanks a lot! I will attempt to convert it to 2003 standards. The only change that was made was the change from p1_wheel to p1_x on one of the bits, I think.
Jonathan E
Team Co-Captain
Student Lead WebDev
CA Robotics - 619
Charlottesville, VA
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Any programming buddies? Anton Abaya Chit-Chat 6 10-02-2002 22:14
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
pbasic programming punarhero Programming 4 21-01-2002 23:32
