Go to Post "If a student CAN do it, a student SHOULD do it." - Mr. Lim [more]
Unread 17-04-2013, 22:41
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Re: Colson Wheels??
Originally Posted by NXTGeek View Post
You'll need a way to tension the chain. Here's one way:
Oh, no chains, I will use 1 belt per side within the rail that are wrapped on either side of the center wheel, Like so:
Those small circles are roller bearings for the belts that can be adjusted up and down.
Unread 18-04-2013, 01:41
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Colson Wheels??
Attachment 14647
http://www.chiefdelphi.com/forums/sh...29&postcount=9
be careful
Unread 18-04-2013, 22:36
Cash4587's Avatar
AKA: Cooper Cash
Re: Colson Wheels??
Originally Posted by PAR_WIG1350 View Post
Would math have to be done in order to perfect this design or what? how can it be done effectively?
Unread 20-04-2013, 12:50
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Colson Wheels??
It might be doable. There is a way to mathematically calculate the proper distances, but you have to ensure that you account for tension. Also, With two short wraps like that, the deflection needed to cause ratcheting is very low, The tension needed to avoid might cause parts to warp lead to binding. If somebody who has tried this disagrees, I would love to hear about your setup, but generally, this isn't done.
I suggest one longer wrap on one side of the pulley and idlers that guide the other side of the belt around the pulley.
Name:	belt config.png
