Go to Post Sloppy thinking leads to sloppy designs... - Joe Johnson [more]
Unread 17-04-2013, 17:57
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Encoders (What's up with those?)
So our official season is done, but we are looking forward to some off-season events. In our attempt to remedy some weaknesses from the season we are looking to add an encoder to our shooting system. It is a miniCIM connected by ~.9 Gear ratio to a pneumatic wheel.
We have no idea what kind of sensors to look into, where to purchase them, or how to install them. Any help would be great. Thanks!
Unread 17-04-2013, 18:04
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Re: Encoders (What's up with those?)
We have never had much luck mounting US Digital encoders to flywheels. We also haven't had luck with using another motor as a tachometer. This year and last year for flywheels we used photoelectric sensors pointed at retro-reflective tape strips stuck to the wheels. We have 6 strips of the tape stuck evenly around the wheel this year. 6 ticks = 1 revolution. Our speed control has had quick responses and accuracy.
FIRST Team 1732- Hilltopper Robotics
Website, Facebook, Twitter, Instagram
Robotics Association at UW-Milwaukee
Website, Facebook
Unread 17-04-2013, 18:11
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Photoswitches are definitely the way to go. At the wheel speeds teams are using, finding encoders with shafts is difficult. Shaftless encoders like the US digital are a little touchy, and require decent tolerances too.
Optical sensors, on the other hand, will give you excellent speed control while allowing just about any alignment you feel like. There are a number of threads on this, however, so I suggest you search some of them out.
http://www.chiefdelphi.com/forums/sh...ht=photoswitch
Unread 17-04-2013, 18:52
How are you decoding the signal from the photosensor? i.e. Are you reading the number of counts, and dividing by elapsed time, or are you using getPeriod() to read the elapsed time between pulses?
What speed control algorithm are you using? PID, TBH, bang-bang, something else?
Unread 17-04-2013, 23:12
Ernst's Avatar
Ernst
AKA: Ernst
I wasn't involved with the programming. Sorry. I'll try to direct my team's main programmer to this thread.
Website, Facebook
Unread 17-04-2013, 23:19
propionate's Avatar
propionate propionate is offline
Team co-lead and LabVIEW programmer
AKA: Stephen
FRC #1732 (Hilltopper Robotics)
propionate is on a distinguished road
Fortunately, I just made a video this weekend explaining how it all works. (It was for the SpaceX FIRST application, hence the title).
http://www.youtube.com/watch?v=zzNLlAUbbcU
Edit: Might only leave this up for a little while. Watch it quick!
Unread 17-04-2013, 23:27
asteb27 asteb27 is offline
FRC #0293
asteb27 is an unknown quantity at this point
How did you measure how accurate you were?
Originally Posted by Tom Line View Post
Photoswitches are definitely the way to go. At the wheel speeds teams are using, finding encoders with shafts is difficult. http://www.chiefdelphi.com/forums/sh...ht=photoswitch
We have encoders in the 10,000 rpm range. I know some teams are running faster than 10k rmp, but plenty (like us) are running much slower than that.
I've used both of the following with no problem
http://www.digikey.com/product-searc...256&vendor=136
http://www.usdigital.com/products/en...otary/shaft/S1
Unread 17-04-2013, 23:34
propionate's Avatar
AKA: Stephen
No in-depth analysis. 0 to shooting speed is about one second. Recovery time between shots is about 300ms, accurate to within .2% speed (plenty close for what it's being used for). Barring human error, we can hit around 95% accuracy just from tests in the shop. On the field we're closer to 80 or 85% because of human error/flywheel wear and tear.
Unread 17-04-2013, 23:37
FRC #0293
I couldn't tell from the code (we use java), but do you actually measure rpm with this system? if you do, I'd be interested to see how it compares to a tachometer reading.
Any reason you use retroreflective tape? From what I could tell, you weren't shining a light at it.
Unread 17-04-2013, 23:39
Would you be interested in discussing this? If so, I have a few observations to make, and a few questions.
Unread 17-04-2013, 23:40
T^2 T^2 is offline
FRC #5499
We've used both this shaftless encoder and this shafted encoder from USDigital on our shooter this year, with a fair amount of success with each. The female encoders are definitely a bit more finicky. If you need help with mounting any kind of encoder, ask.
Unread 17-04-2013, 23:41
propionate's Avatar
AKA: Stephen
The photoelectric sensors are pulled into LabVIEW as encoders. The encoder VI then takes the counts/second and calculates the rate. So it isn't precisely RPM - would have to be scaled to account for the fact that there are six pieces of tape.
And we just found retroreflective to give the best response (in terms of distance the sensor could be from the wheel). Gave us more wiggle room, so to speak.
Unread 17-04-2013, 23:42
propionate's Avatar
AKA: Stephen
Sure, go ahead. The video length had to be 2 minutes or less so I had to skip a lot of details unfortunately.
Unread 17-04-2013, 23:59
OK here goes :-)
Is there a reason why you used the encoder VI, instead of the counter VI, for this non-quadrature sensor?
Why did you use 6 pieces of tape, instead of just one?
In an earlier post you said that your speed control is accurate to within 0.2% of point. What test equipment did you use to independently measure the wheel speed to make this determination?
Are your motors directly connected to the wheel, or are there gears or belts or chains between them?
What motor controllers are you using for the shooter motors?
What is the range of wheel speeds you are controlling?
Why did you need a custom PID? Did you try other methods (LabVIEW PID, TBH, bang-bang) and they didn't work?
Unread 18-04-2013, 00:03
Ernst's Avatar
Ernst
AKA: Ernst
OK here goes :-)
I can answer some of these. We have CTRE Talons controlling BaneBots 550s which drive 4:1 gearboxes.
Website, Facebook
