Go to Post I'm absolutely certain there are simpler ways of accomplish the same things. I'm simply not the best that FIRST has to offer in this regard and part of what drives me to keep going is the desire to get better at achieving an elegant solution with as few superfluous processes as possible. - Madison [more]
Unread 29-01-2003, 16:34
Erinn888's Avatar
Erinn888 Erinn888 is offline
#0888 (Glenelg)
Erinn888 is an unknown quantity at this point
Send a message via AIM to Erinn888
Lightbulb light visibility
We know that the light has to be visible 99% of the time and the top 4 inches have to be visible, but can we fold over the light after the match has started so we can go underneath the bars at the sides of the fields? Or can we have the light sink into the robot as we go underneath the bar and have it reappea after we are under the bar. We understand that the light has to be mounder upright, but can we fold it over after we started or not? If so, do we have to fold it back up?
Any input greatly appreaciated.
Unread 29-01-2003, 16:45
Jay5780 Jay5780 is offline
no team (Aztechs)
Jay5780 will become famous soon enoughJay5780 will become famous soon enough
To me this is rather vague, but I saw this\ on the forum.
Jay
Unread 29-01-2003, 16:46
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Yes, FIRST was very clear that the light may be retracted when going under the bar but should be visible and exposed at all other times. They will allow a "reasonable" amount of time for the light to be retracted and extended. They indicated something on the order of 3-4 seconds, as 99% of 120 seconds would only give a little more than a second for the light to be inside the robot.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 29-01-2003, 23:13
pauluffel's Avatar
pauluffel pauluffel is offline
AKA: Paul Luffel
FRC #1127 (Lotus Robotics)
pauluffel is a jewel in the roughpauluffel is a jewel in the roughpauluffel is a jewel in the rough
Send a message via AIM to pauluffel
Another important thing to note, you can"t have the light come into contact with the bar. It has to move down before it touches the bar (so you can"t have it on a spring hinge where it will be pushed down by the bar).
Unread 29-01-2003, 23:19
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
If your bot has clear lexan sides, and the light can be 100% visable thru the lexan 100% of the time, FIRST wouldn't care that the light isn't on top of the bot....would they?
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 29-01-2003, 23:26
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
They're rather picky about things of that sort.. I wouldn't take any chances with that because you wouldn't want to have to remodel your robot right before a competition starts..
I still remember having to rip off a window motor at VCU last year because it was illegal..
Unread 29-01-2003, 23:45
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
On our 2002 robot we have our light mounted on a chunk of polycarb inside our robot... and our robot is encased in polycarb...
We got through all inspections with no problem whatsoever. The referees could see it fine.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 30-01-2003, 00:12
Harrison's Avatar
Thats the bot I was thinking of when I was thinking of putting it inside this year...hehehe
Thanks!
Harrison Ruess
UOIT '08 Alum
Unread 30-01-2003, 00:17
HolyMasamune's Avatar
HolyMasamune HolyMasamune is offline
41246017 O-('_'Q)
AKA: Y C
None #0840 (Aragon Robotics Team)
HolyMasamune is on a distinguished road
Send a message via AIM to HolyMasamune
Re: light visibility
Just a reminder, I think it says in the rulebook that the light has to be right side up, which means you can move it up and down but you can't turn it on its side.
Unread 30-01-2003, 11:15
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
Ask FIRST.
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 30-01-2003, 12:41
Generally Useless
According to Update 5 the top 4" of the light must be "exposed".
I attempted to post a question on the FRC (Jive) group asking A) if having the light in a robot with transparent sides was acceptable and B) if it wasn't acceptable would the rule be enforced. Achieving the required exposure was basically going to put us back at square one in terms of frame design and I didn't want to redesign our frame for nothing.
The moderator declined to post my question, probably because of part B. However numerous other people have since suggested the same thing and been told NO. Transparent sides are not acceptable. Even a transparent protective cover is not acceptable.
Exposed means exactly what it says.
A moderator did respond to me personally and say that "any team that does not have it's light exposed will be assessed two minor penalties". As I recall three minor penalties = a DQ. So while you could technically compete, the slightest misbehavior on your part would result in a DQ.
As a team, we decided that in the interests of Gracious Professionalism and because complying with the rules is "the Right Thing To Do" that we would ensure that we met the requirement. We will not try and scrape by or just take our penalty and compete anyway.
We have resolved our issue by figuring out a very elegant retraction mechanism. It kept us from having to redesign our frame. I'm not sure if you can do the same or not, our mechanism depends on a feature of our robot I have not seen discussed here, so I'm keeping quite for now.
Since the response from FIRST was a private message, it was obviously not meant for public consumption. If it was they would have used the FRC group. So I will not post it here without getting clearance from FIRST. But I thought you all should be aware of the major points.
You should also be aware that last fall I volunteered to be a technical judge at one of the competitions. I won't tell you which one, but I will tell you that I will be packing a 6" scale.
Consider yourself warned on this issue....
"Who is John Galt?"
Unread 30-01-2003, 14:34
Lewis Sussman Lewis Sussman is offline
#0095 (LRT-Upper Valley Robotics)
Lewis Sussman is an unknown quantity at this point
I rechecked update #5 and could not find anything about the light that uses the word "exposed." Here is the exact wording:
"A momentary “loss” of visibility of this beacon is allowable; however, 99% of the time FIRST requires that the top 4” of the light be visible."
To me, this means exactly what it says. You need to be able to see the light. Am I missing something? Is there somewhere else that says "exposed?" If not, doesn't "visible" mean if you can see it, even through a transparent medium, it's visible?
What do you all think?
Unread 30-01-2003, 15:09
Lewis, http://jive.ilearning.com/thread.jsp...06f736564#2785
Unread 30-01-2003, 15:11
Christine_364 Christine_364 is offline
#0364 (Team Fusion)
Christine_364 has a spectacular aura aboutChristine_364 has a spectacular aura aboutChristine_364 has a spectacular aura about
Yeah, on the FIRST forum, they have verified that you can lower and then raise your light while going under the bar, but having your light inside of a lexan covered robot isn't acceptable.... see the links here:
http://jive.ilearning.com/thread.jsp...t=90&trange=15
http://jive.ilearning.com/thread.jsp...65&trange=1 5
Of course, the same question that had been posted a couple of days earlier was answered with an 'you probably won't be able to get away with it.... the judges will probably make you change it, so have a plan to retrofit the light to a more acceptable position if you are instructed to do so at a competition...'
But the later posts most definitely say NO to having it inside of a clear robot..... in their words, "Exposed means exposed, not covered by a clear box."
<sigh>
Unread 30-01-2003, 15:50
Go Badgers!
#0093
Then I suggest you familiarize yourself with the rules.
Rule M8
Robots must use the rotating light provided in the kit to display their alliance color (red or blue). The light must be mounted upright on the robot so that the color is always visible from a distance of at least 100 feet. The light should be mounted to allow easy changeover of the colored lens before matches. See Section 3.2.2 for Rotating Light wiring information, also see Rule C26.
Team Update 5: PAGE 18, RULE M8,
There have been numerous design questions relative to the installation/placement of the rotating light. The purpose of M8 is to insure that your drivers, the referees, the scorekeeper, and the judges can identify your robot and that the audience has some idea of who’s who; and to make sure that it is installed to enable EASY CHANGEOVER OF THE LIGHT LENSE.
From the FIRST Forums (Jan 17, 2003)
Question:
If the rotating light was submerged within the body of a robot that had all transparent sides so that the beacon could be seen in all directions at all times, would that satisfy the intent and spirit of the update to rule M8? In other words, can the light be visible through the sides of the robot?
Answer:
Most likely, the light visibility would be somewhat diffused by the transparent body.
The intent is for the judges and referees, as well as the public, to easily recognize your robot. It is important that the judges be able to easily identify your team so that they can give you proper credit toward the non-competition awards. We would like to see consistancy in visibility of the rotating light. Rule M8 say that the light must be "always visible". This can be left for interpretation. It will be the Tech Inspector's call as to whether the light is sufficiently visible if you use your scheme. You should have an alternate scheme ready if your original scheme does not pass inspection. You may have to demonstrate your scheme to the inspectors during the Thursday trial matches to get their judgement.
Nowhere does it say the light must be "exposed". It only says "visible". In fact, only the top 4" must be visible at all times. Last year the components of our robot were rather low-profile, so the light was higher and was able to always be seen. If you can do this with your robot, then I'd say go for it.
It's hard to say, though. I haven't seen this year's light in action compared to last year's. Is this year's light brighter than the light last year? Any objective opinions/testing?
However, rules do change from year to year. I could be wrong, and FIRST could be "cracking down" on "illegal light usage". I, however, highly doubt they're going to pull out a scale marked to the hundredths of an inch, and measure your light visibility. FIRST has done stranger things though....
In the end, if a critical mechanism depends on the light not being on the top of your robot, I wouldn't risk it just in case FIRST makes up their minds. If you want to "test the water", then run your robot through a practice round with the light mounted visibly inside the robot, and ask the judges if they have any complaints/concerns.
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
What color light is better on your robot Rob Colatutto General Forum 24 11-09-2002 20:33
About the light that need to be seen from four side archiver 2000 3 23-06-2002 23:01
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
How many posters does it take to change a lightbulb? Brandon Martus Chit-Chat 7 22-02-2002 19:48
