Go to Post Engineering is all about trade offs. You can design yor system to do A, B or C easily. Combining A abd C or A and B or B and C requires some effort. Combining A, B and C should be near impossible. - Mike Betts [more]
Unread 17-04-2013, 16:34
shawnliner shawnliner is offline
FRC #3753 (BulahBots)
shawnliner is an unknown quantity at this point
Charter Bus Luggage dimensions
So we are trying to rebuild our pit to fit in the luggage area under a charter bus. Does anyone have reliable measurements of this area? i realize their may be some play, but with an idea we could plan for worst case. As it is now we don't even have a place to start.
Thanks in advance.
Shawn
Shawn Liner
Coach
Team 3753
When I learn, I win. If I can win too, that's gravy.
Unread 17-04-2013, 16:40
rbrown1 rbrown1 is offline
AKA: Rex Brown
FRC #1730 (Team Driven)
rbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant future
Re: Charter Bus Luggage dimensions
I would contact your bus company. Some of the buses have 3 lower compartments with solid walls separating them. Other have the 3 compartments but separated by a strut system which will allow for long pipe.
Unread 18-04-2013, 11:53
Alex Wilcox's Avatar
Alex Wilcox Alex Wilcox is offline
Engineering Student
no team (Carleton University FIRST)
Alex Wilcox is an unknown quantity at this point
It totally depends on the model of the bus unfortunately - Out team actually has to make sure that the bus we get is one of the taller ones because we have made stuff to fit the compartments. The only consistent measurement is the width, highway coaches are 102 inches wide so you can usually get an 8 foot item across inside, but there are usually gas struts and latches in this area that may prevent larger items from packing at 8 foot width. 7' 6" should guarantee a fit side to side.
Front to back, the compartments are usually 4' or greater, but this depends on the bus. Height is the biggest variable, Prevost X3-45 coaches are the tallest and others are shorter from there.
Call them and ask for dimensions, and then be aware that there may be other obstacles, such as power inverters and wheelchair lifts, or bus related stuff (tools, lav fluid, cleaning supplies) mounted or stored underneath as well.
Unread 18-04-2013, 15:00
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
It might also be worth checking if another team from your area is taking a trailer and would be willing/able to take some of your stuff for you.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
