Go to Post I guess we're going amish this year. - Jon Anderson [more]
Unread 17-04-2013, 19:49
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Colson Wheels??
I'm trying to build a Colson wheel drive system but I need help!! How do I power them? What do I need to get it going? All help is appreciated!!!
Unread 17-04-2013, 19:51
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: Colson Wheels??
What size colsons are you looking at? How many wheels per side?
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: Colson Wheels??
WCP products has two options, live axle and dead axle.
To use with the kitbot (dead axle) you'll need the hubs and two bearings for each wheel.
Unread 17-04-2013, 19:52
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
Re: Colson Wheels??
WCProducts has some good products to help you get started. They make both live axle and dead axle hubs for colson wheels.
Edit: Everybody has the same idea! These must be really good.
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Last edited by ehfeinberg : 17-04-2013 at 19:54. Reason: Some people are ninjas...
Unread 17-04-2013, 19:53
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Re: Colson Wheels??
http://wcproducts.net/wcp-00052/
http://wcproducts.net/wcp-00053/
Depending on whether you go live axle or dead axle, one of these will become your best friend.
Basically, Colson wheels have no hub when you buy them, so either you have to machine your own, or buy these.
Unread 17-04-2013, 20:30
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Re: Colson Wheels??
i'm gonna be the weird guy and say you should get your colsons from battlekits.com
http://www.battlekits.com/robot_whee...th%20Sprockets
i've used these before on non first robots and i highly recommend them.
robutt marketspace has a good selection of colson wheels without hubs or sprockets.
http://www.robotmarketplace.com/prod...on_wheels.html
My Instructables
Unread 17-04-2013, 22:06
Cash4587's Avatar
AKA: Cooper Cash
Re: Colson Wheels??
I'm looking at using 4" and 3 on each side. Depending on the amount of traction they give, I would then go up to 4. I was going to drop the center one an 1/8th of an inch. Then I belt drive them from a live axle (which I now see that WCP is the best option). Let me up load a picture of what I have so far.
Unread 17-04-2013, 22:15
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
Re: Colson Wheels??
We're using 6 6"x1.5" and really like them. We are finding, however, that both the WCP hubs and the ones we made ourselves can shift a bit over time. The next batch will have a shallow thread cut in them or be knurled. We also used an indexing head, narrow slit saw and horizontal mill to cut a diamond pattern to improve traction. The centre wheels are dropped about 1/8"
Unread 17-04-2013, 22:27
Cash4587's Avatar
AKA: Cooper Cash
Re: Colson Wheels??
Here is what I have so far. Hope you guys like it, I've been using Solid Works for about 3 weeks now.. Constructive criticism is always welcome.
Unread 17-04-2013, 22:32
NXTGeek's Avatar
NXTGeek NXTGeek is offline
AKA: Malachi
NXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to behold
Re: Colson Wheels??
Attachment 14644
Attachment 14645
You'll need a way to tension the chain. Here's one way:
2013 -Team 3476
Champion (Fall Classic)
Champion (Battle at the Border)
Finalist (Indiana Robotics Invitational)
Newton Division CHAMPIONS (Worlds)
Wild Card as Finalist Alliance Captain (Inland Empire -> Worlds)
Innovation in Control Award (Inland Empire)
Industrial Design Award (San Diego)
Semifinalist (San Diego)
2012 -Team 3476
Champion (San Diego -> Worlds)
Excellence in Engineering Award (San Diego)
2011 -Team 1425
Engineering Inspiration Award (Portland Autodesk -> Worlds)
Finalist (Portland Autodesk)
WFFA (Tim BD, Portland Autodesk)
Finalist (Seattle Olympic)
Entrepreneurship Award (Seattle Olympic)
Unread 17-04-2013, 22:41
Cash4587's Avatar
AKA: Cooper Cash
Re: Colson Wheels??
Oh, no chains, I will use 1 belt per side within the rail that are wrapped on either side of the center wheel, Like so:
Those small circles are roller bearings for the belts that can be adjusted up and down.
Unread 18-04-2013, 00:46
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Colson Wheels??
I wonder where you got that idea.
Unread 18-04-2013, 01:41
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Colson Wheels??
Attachment 14647
http://www.chiefdelphi.com/forums/sh...29&postcount=9
be careful
Unread 18-04-2013, 22:36
Cash4587's Avatar
AKA: Cooper Cash
Re: Colson Wheels??
Originally Posted by PAR_WIG1350 View Post
Would math have to be done in order to perfect this design or what? how can it be done effectively?
Unread 20-04-2013, 01:38
NXTGeek's Avatar
AKA: Malachi
Re: Colson Wheels??
From my brain (?). I designed this during the first week of build season.
2013 -Team 3476
2012 -Team 3476
2011 -Team 1425
