Go to Post So measure not by the masses, but by the sparks that you generate. - Kims Robot [more]
Unread 19-04-2013, 13:00
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Indiana FIRST Championship Event - May 18
New for 2013, IndianaFIRST is hosting a State Championship. The invited team list is based on qualifying points similar to FiM, MAR and Minnesota. Ranking points are based on a teams best event but only one event. The only real difference in our point system is that points were awarded for RCA, EI and RAS.
There will 24 teams competing. The event plan is to play "Exhibition" matches in the morning, then have alliance selections, and then the Elimination tournament. Alliance captains are based on the ranking points as listed below. The Exhibition matches will allow teams to see each other play.
The event is May 18 at Pery Meridian High School in Indianapolis.
EDIT - There was an error with 4008 and 1760. The updates are below. The correction puts 4008 at 27 and 1760 at 28.
Rank Team Points
1 1741 74
2 868 71
3 234 67
4 71 64
5 829 49
6 447 44
7 1024 41
8 4824 38
9 3947 36
10 3147 35
11 1018 35
12 4545 34
13 1747 33
14 3301 33
15 1646 31
16 3940 29
17 135 28
18 3936 27
19 1501 27
20 461 25
21 2197 19
22 3176 19
23 3487 18
24 4781 18
25 4791 16
26 4690 16
27 4008 15
28 1760 15
29 3565 14
30 4272 13
31 292 12
32 45 12
33 4070 12
34 4485 12
35 2867 12
36 3494 11
37 1720 10
38 1529 10
39 2360 10
40 3865 10
41 4211 10
42 4580 10
43 4846 9
44 4103 8
45 4081 8
46 2171 6
47 3559 6
48 4058 6
49 4234 6
50 3180 5
51 2909 4
52 4760 0
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Last edited by Chris Fultz : 21-04-2013 at 21:44. Reason: correct team point error.
Unread 19-04-2013, 13:09
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Indiana FIRST Championship Event - May 18
Awesome! I'm glad to see another state following in MN's footsteps
Out of curiosity, what's the rationale for using a team's best event? Here in MN, the decision was made to use every team's first event, in order to eliminate any benefit a team would have from playing at multiple events. Personally, I can see the argument either way... last year, my team didn't make States because we blew it our first event, but we did well our second.
2016: Lake Superior WFFA
Unread 19-04-2013, 13:15
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
The reason we went with best event is because this is a robot competition, and we wanted the 24 best robots in Indiana. This is the pilot year for this program, and we wanted the most 'bang for our buck' from a spectator standpoint. If this model doesn't work for some reason, we can always change it in the future.
It should be noted that the criteria for ranking teams is based on the FiM/MAR/MN models, but we also assigned points for RCA and EI.
Hi!
Unread 19-04-2013, 13:18
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
I find the usage of ranking for alliance captains interesting. Is the intent of this to make the event one day.
Unread 19-04-2013, 13:45
Mentor, LRI, MN RPC
It should be noted that the criteria for ranking teams is based on the FiM/MAR model, but we also assigned points for RCA and EI.
Sounds good to me!
Here in MN, we don't award points for RCA or EI... Instead we give 10 points for submitting for Chairman's, regardless of which regional you submit at. They started that in order to provide an extra incentive to submit and help teams progress overall.
Unread 19-04-2013, 13:56
SThompson76 SThompson76 is offline
FRC #0868
SThompson76 is an unknown quantity at this point
Will the Alliance selection be the standard FRC setup?
Unread 19-04-2013, 14:34
PVCpirate's Avatar
PVCpirate PVCpirate is offline
FRC Data Nerd
AKA: Anthony Jennings
FRC #1058 (PVC Pirates)
PVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud of
If they're following Minnesota's lead, it will be a 4 alliance tournament, 1vs4, 2vs3, winners play for the title.
My accomplishments with 1058:
2010 - Granite State Regoinal Winners, Galileo quarterfinalists, IRI quarterfinalists
2012 - GSR Chairman's Award winners
An incredible four years I will never forget
Unread 19-04-2013, 14:36
Rookie Year: 1942
To answer a few of the questions -
We used the rankings for Alliance Captains so we could do a 1 day event.
During May, adding another day out of school for students was going to be a challenge. We also knew that doing any type of qualification matches needed 8 - 10 matches to be effective, so we decided to use the rankings. The "exhibition" matches allow the alliance captains to see robots in action that they may not have seen during the season.
Alliance selection will be 1-8, 8-1. Our only difference is that if you are not an alliance captain at the time you are picked, you cannot decline. (For example, if you are #9 and expecting to move up, you still have to say yes).
8 alliances of 3 robots. No backups.
Chris Fultz
Unread 19-04-2013, 15:14
CLandrum3081's Avatar
CLandrum3081 CLandrum3081 is offline
Alumni? Wait, what?!
AKA: Catherine Landrum
FRC #3081 (RoboEagles)
CLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond reputeCLandrum3081 has a reputation beyond repute
This is awesome!
Even though 3081 will not be competing at state champs this year, last year was incredible. Inaugural tournaments are always exciting and special. Have fun!
A state championship brings in a lot of statewide attention - just what FIRST needs!
FRC Team 3081 John F. Kennedy HS RoboEagles
2012: Rookie, person who does anything everyone else is too lazy to do, de facto scouting lead
2013: Co-Captain and Build Lead who still does anything everyone else is too lazy to do
2014: Co-Captain (AGAIN?!) and Scouting/Strategy/CAD/Pit Representative who has finally learned how to delegate tasks to others responsibly
2012 MN Land of 10,000 Lakes Regional Champions (with 3747 ChaoTech and 525 Swartdogs)
2012 Inaugural MN State High School League 2nd Seed Alliance Captain and Runner-Up (with 3747 ChaoTech and 2232 Deus Ex Machina)
2013 Ehm.... not much! Attended Northern Lights and 10K
2014 Attended Wisconsin and MN Land of 10K Lakes Regionals
Unread 20-04-2013, 01:29
stephenmcd71 stephenmcd71 is offline
FRC #0071
stephenmcd71 is a name known to allstephenmcd71 is a name known to allstephenmcd71 is a name known to allstephenmcd71 is a name known to allstephenmcd71 is a name known to allstephenmcd71 is a name known to all
NO BACK UPS WOW THIS IS GONNA BE FUN........Just curious what will happen if a robot malfunctions will it be 2v3 robots
Unread 20-04-2013, 08:28
Logan Byers Logan Byers is offline
Roaming Mentor & Referee
no team (Team Indiana)
Logan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud of
Where can we sign up to volunteer (if volunteers are needed)?
Unread 20-04-2013, 09:21
Mentor, LRI, MN RPC
And that's where this really differs from the MN event! I was told by the VC that I was volunteering here at the MN event back in November
Unread 21-04-2013, 21:41
Rookie Year: 1942
if a robot breaks, it becomes 3 v 2.
but a broken robot can return to another match if it gets fixed.
There will be a link for volunteering.
here is the updated IndianaFIRST website.
http://www.indianafirst.org/pages/state
Chris Fultz
Unread 21-04-2013, 21:45
Rookie Year: 1942
There was an error in the original ranking list.
Check the first post for the correction.
Team 4008 and 1760 moved up in the rankings.
Chris Fultz
Unread 30-04-2013, 17:08
Carolyn_Grace's Avatar
Carolyn_Grace Carolyn_Grace is offline
Build bridges not walls.
AKA: Carolyn Beyer
FRC #1024
Carolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond repute
I'd like to ask that every team that registers for this event please volunteer one personnel if you haven't yet. This is not a requirement to compete, but we are still in need of field reset crew and referees especially.
If you're interested, please sign up to volunteer via the link below:
Indiana State Championship Event Volunteer Signup
Thank you!
"It is change, continuing change, inevitable change, that is the dominant factor in society today. No sensible decision can be made any longer without taking into account not only the world as it is, but the world as it will be." -Isaac Asimov
