Go to Post Just fill your wheels with depleted uranium - EmileH [more]
Unread 14-01-2003, 10:15
Ralph Lambert Ralph Lambert is offline
Mentor - Team 1094
None #1094 (Channel Cats)
Ralph Lambert will become famous soon enoughRalph Lambert will become famous soon enough
Securing Drill Motor Coupler
We are in the process of building up the drill motor drivetrain per the picture provided by FIRST. It appears that the coupler will unscrew from the drill transmission when turning in one direction. Has anyone had a problem with this? If so, how did you fix it?
Unread 14-01-2003, 10:26
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
there are two left hand screws that are provided. They screw thru the coupler and into the drill shaft. If you don't do this it will unscrew. I forgot to install them and we had that problem right off the bat.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 14-01-2003, 13:09
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
BTW treat those left hand screws like gold and be sure to get spares. If you don't, you will need them. When was the last time you saw a left handd screw at your local Home Despot?
If you don't need them at a competition, they will probably have a very high trading value, so keep an eye on yours.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 14-01-2003, 15:02
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Definately agree here. While inventorying our kit, I took these, put them in a little plastice bag and wrote "If you don't know what a left-handed screw is, don't even think of opening this bag". Or something to that effect.
Getting replacements for these is a royal pain, especially on short notice, and without them you're going to have to find some other way to connect the drills.
Unread 17-01-2003, 17:00
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
Not only did I not find any left-handed screws in our kit, but I am at a loss for where they screw into. I do not see any threaded holes on any of the drill motors or the couplers. Would somebody please take the time to explain what they are and where they go?
Thanks in advance!
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 17-01-2003, 17:47
They are small black screws with a blue spot on the shaft. If I remember correctly, they were inside one of the drill mount/coupler bags. Or maybe it was the actual drill bag?
Anyway, if you look at the output shaft of the gearbox, you'll see that it's hollow. The left-handed screw goes in the inner hole. The Aluminum hex piece that screws onto the outside as a hole in it that this screw goes through. It's not threaded, but it is a clearance hole.
--Rob
Unread 17-01-2003, 17:50
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
forget the couplers, well be making our own output shaft after were done prototyping.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 18-01-2003, 09:40
Addict
Thanks! They were right in front of my face the whole time!
Mark Pettit
Unread 23-01-2003, 23:54
Bash-a-rat Bash-a-rat is offline
#0059 (Ramtech)
Bash-a-rat is an unknown quantity at this point
Send a message via AIM to Bash-a-rat Send a message via Yahoo to Bash-a-rat
Ugh.. okay... Um... I have a little question that may be hard to answer... Our team is trying to get longer left handed thread screws, but we need the specs for the screw so we can go get it. These lil boogers really are hard to find... And I couldn't have said it better than this: treat em like gold. We checked the manuals in the kit, etc... If you have the specs or know where to find them, please PM me. Thanks.
"Oops, you broke it."
Unread 26-01-2003, 22:01
Dick Linn's Avatar
no team (Synergy)
One thing I thought we'd do is to drill through one of the flats on the aluminum coupler (without the left-hand screw in place) and 1/2 way through the threaded drill shaft, then use a roll pin to help prevent it from unscrewing. If done correctly, it would not significantly weaken the threaded part on the drill, yet would serve as a backup to the left-hand screw and the friction of the aluminum shaft adapter threads. I hate to think of using a serious type of Lock-Tite in case I have to get that puppy apart.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 26-01-2003, 22:06
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Similarly, we are putting a flat onto the drill output shaft and then pinning our coupler alongside the flat.
We'll use the threads to couple the motor to our shaft, and the pin ought to prevent it from unscrewing.
--Madison--
...down at the Ozdust!
Unread 26-01-2003, 22:22
If you use the left-handed screw properly, you do not need to pin anything. In fact, most hand-drills use this same system for attaching the Chuck to the output shaft, and they don't even have that blue spray on their screws! As far as I can tell, the blue stuff acts vaguely like Ny-Lock, making it nearly impossible for the screws to work themselves loose.
A note: make sure the Aluminum piece is as far down as it can turn and that the left-handed screw is flush with the top of the aluminum. It takes a LOT of power to get the left-handed screws the last .5-.25" down, but you need to do it. We destroyed two allen wrenches doing it, but I assure you they aren't going anywhere.
Unread 30-01-2003, 02:42
Alvin Alvin is offline
Alvin is an unknown quantity at this point
Anyone know the specs for those left-handed screws, or where they might be found? I don't seem to be able to find them in the kit, unfortunately, so I might need to try to purchase some.
Unread 30-01-2003, 06:32
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Skill Bosch Left Handed Screw
Unread 07-02-2003, 21:21
AKGirl AKGirl is offline
#0374 (IceBreakers)
AKGirl is an unknown quantity at this point
Talking Thank You
If not for finding this we would have come up with a much scarier plan, so thanx
AKGirl
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
Securing hex shaft to drill output D. Gregory Technical Discussion 6 24-01-2003 14:05
