Go to Post Sustaining an FRC team is really hard! - Jared Russell [more]
Unread 29-01-2003, 18:25
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Illuminated Switches
I was reading through the IFI Operator Interface Guide just to freshen up and i came across a passage that said "Do Not use illuminated switches". Is this a Rule that we must follow or is this just a recommendation on the part of IFI?
Are the instructions in these manuals the official rules for the controllers and such?
Because as far as switches go in the manual it says we can use any switch in any quantity (i think its any quantity)....so can i use illuminated switches?
Why would using them be frowned upon by IFI?
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 29-01-2003, 19:21
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
There is a rule in the rule book that prohibits illuminated switches. I can't get into Hyperrules at the moment or I'd give you the reference (must be that silly firewall they have here at work).
There IS a technical reason for the rule, but you'll have to ask one of the electricals what it is. Hopefully Al S or Rbayer or one of those guys will explain it. This has been a topic of discussion before, but I think it's been a few months or does it just seem that way? I may be suffering the usual "Build Season Time Distortion Syndrome".
Christopher H Husmann, PE
"Who is John Galt?"
Unread 30-01-2003, 08:30
well if any other teams want to find out the reason i found an old thread that tells why
http://www.chiefdelphi.com/forums/sh...ted +switches
Thanks everyone.
Unread 30-01-2003, 11:46
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Stolen from The_Robot.pdf, page 14
3.3.2 Sensor Inputs on the Operator Interface
The +12 Vdc LEDs may be connected between +5Vdc and Ground or between an LED output
and Ground to serve as a visual indicator to the robot operators. This can be helpful during a
competition match when a robot operator may not have a good view of the Operator Interface.
CAUTIONS
Connect switches between a switch input and Ground. Do not use lighted switches with
the Operator Interface unless the light is disabled.
You can still use these LED outputs manually, and perhaps with even greater use, than an illuminated switch, because you can trick around with them in the programming, rather than just having them on or off in conjunction with a switch. Each LED output (except for the Basic Run LED) is shared between the LEDs physically inside of the OI and a pin on either one of ports 1 and 3.
'Code exerpt from the 2003 default code, 2.0 and 2.5 versions.
Output		7	'define Basic Run LED on RC => out7
Output      	8	'define Robot Feedback LED => out8  => PWM1 Green
Output      	9	'define Robot Feedback LED => out9  => PWM1 Red
Output      	10	'define Robot Feedback LED => out10 => PWM2 Green
Output      	11	'define Robot Feedback LED => out11 => PWM2 Red
Output      	12	'define Robot Feedback LED => out12 => Relay1 Red
Output      	13	'define Robot Feedback LED => out13 => Relay1 Green
Output      	14	'define Robot Feedback LED => out14 => Relay2 Red
Output      	15	'define Robot Feedback LED => out15 => Relay2 Green
Say you wanted to have the red PWM1 LED light up whenever you press the port1 trigger. Here's all you'd have to do, if my mind doesn't fail me entirely:
out9 = p1_sw_trig
In the default code for PBASIC 2.0 (2.5 doesn't need it, with the advent of the SELECT CASE statement, but that's very interesting, as well), they do some interesting things with the modulus operator, and MIN and MAX to make the various LEDs light up when the PWM1 or PWM2 values are (close to being) maxed or minned (is that a word?) out.
As a side note, during the WRRF's Programming Workshop, before Kickoff, one of the tasks for people to complete was to make a rate display for a PWM output, both forwards, using the green LEDs, and backwards, using the red LEDs. It was very fun to just watch what people were able to do with these LEDs, seeing as how I was staffing the event (with Ken Krieger (formerly of 192, currently of WRRF) in the lead, and Mark Whitehouse (formerly of 232 and 814) as a fellow assistant.
Fun stuff.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 30-01-2003, 13:55
The main reason is any illuminated switch is expected to be driven by a lamp output on the OI. Those outputs are only able to sink 10 ma (milli amps) which is fine for LEDs but way low for lamps. Additionally, any operator box would receive power through the OI and by making this rule, it will keep teams from blowing fuses or killing the OI. As of yet, FIRST is not allowing separate power for the operator interface. I concur that with all the variables that would result in failures, this is a good general rule for all teams.
See Robot Control System p. 12 @
http://www.innovationfirst.com/FIRST...ence_Guide.pdf
Limit switches Team168 Programming 8 10-02-2003 16:22
switches in order PBoss Programming 5 26-01-2003 22:02
Team selector switches on ISAAC Lloyd Burns Robotics Education and Curriculum 0 17-12-2002 08:32
I need help with the reed switches!!!!!!! archiver 2001 2 24-06-2002 00:40
Need help with custom switches archiver 2001 3 24-06-2002 00:35
