Go to Post Glue it, screw it, bolt it, rivet it, weld it. If the design is flawed it will fail. - Gdeaver [more]
Unread 20-04-2013, 03:12
hiyou102's Avatar
hiyou102 hiyou102 is offline
hiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud of
Re: Make your Champs predictions!
Originally Posted by Gregor View Post
Until they meet a rookie with a pool noodle.
If FCS is well designed, it can beat a 60" blocker on it's own. An 84" blocker however requires some help from alliance partners. Even if the FCS is being blocked, some good ones can cycle as well. If a robot has a hastily attached 84" blocker that doesn't move that can mean they are trapped in their zone all match while the FCS is cycling.
Team 4334 2012-2014
