Go to Post Once you go to your first (FIRST) competition... thats when you fall in love with it. - Jaine Perotti [more]
Unread 20-04-2013, 01:29
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
April Absurdity 2013
I had the privilege of participating in a March Madness bracket this past march and with the recent success of the "Make your champs predictions!" thread, I think the concept carries over excellently to FRC. As such, I decided to create April Absurdity, the FRC version of March Madness.
For those unfamiliar, March Madness is based around the NCAA college basketball tournament and participants in a pool attempt to correctly predict how far each team will make it and who will win the tournament. The same holds true for the FRC implementation. Download the PDF, fill it out and turn it in by the deadline (below) and you are entered into the pool. The winner gets bragging rights. Here are the important things to know from the rules in the pdf, if you want to see them before you download:
  • You may enter either a division or the full bracket. However, to fill out a bracket for Einstein, you must fill one out for all divisions
  • The deadline is Thursday at 1 PM, before qualification matches start
  • To submit a bracket, send the filled out .pdf to aprilabsurdity@gmail.com or drop by 639's pit in Archimedes and hand it in
  • There is a 15% bonus for submitting it before Looking Forward posts so get going!
  • I will be entering one myself so I promise not to look at any brackets in the aprilabsurdity gmail until after the deadline at which point they will be posted in this thread
  • Make sure to put your name (and Chief Delphi name) down on the first page so you can be credited
Points are awarded in the following fashion, per team that makes it to the following point:
+1 pt for correct quarternalist
+3 pts for correct seminalist
+6 pts for correct divisional nalist
+12 pts for correct division winner
+18 pts for correct Einstein nalist
+24 pts for correct World Champion
For some logic on why the points are what they are, they are not quite exponential to encourage making bolder choices early on. However, they are significant enough to highly reward someone who picks correctly in the high tier.
Bonuses are granted for the following:
+1 pt for correctly predicting the number of matches a matchup will go to
+4 pts for correctly predicting where an alliance captain will seed
+10 pts for correctly predicting a full alliance (one time bonus)
+15 pts for correctly predicting a backup bot (+5 pts each for the following: backup bot called, backup bot replacing a certain robot in the alliance, and the identity of the backup bot; each may be obtained separately)
+15% bonus if the bracket is submitted before the annual Looking Forward post(s)
The alliance system slightly complicates things from a standard bracket but to make the system simple, if team 123 makes it to the semifinals, you will get the points for it, regardless of whether they are on the alliance you predicted they would be on. In other words, points are awarded based on the amount of correct semifinalists (or however far in the tournament you are) you have. The only exception to this is the 4 point bonus granted to predicting an alliance captain's position (ie I predict 456 will be captain of the 7th alliance; they are) correctly, and that is a one time bonus.
I will probably have a couple paper copies available for the taking in 639's pit (Archimedes) Thursday morning for people who want to fill one out on the spur of the moment but I would highly recommend doing it ahead of time, if only to get the 15% bonus.
Click here to download the .pdf file that you fill out - Right click>Download. I suggest Foxit PDF reader, the fill in boxes show up in bright orange. This will not work if you fill it out in Chrome and then right click>save as. You must download the file first.
Finally, if you are planning to submit a bracket, please post about it in this thread. Since the submission is not through Chief Delphi, I see the potential for this thread to fall to the bottom quickly. So post about if you are going to submit and post when you do.
Unread 20-04-2013, 01:43
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
Re: April Absurdity 2013
This is a great idea, definitely doing it.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
Unread 20-04-2013, 02:07
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
I would be a lot more interested if the submission deadline was after the match schedules come out. At this point, predictions are entirely luck based. Whoever can best predict winners with the match schedule available is a far more talented person than the person who gets lucky and guesses which top robot had the ideal match schedule.
Unread 20-04-2013, 02:11
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Agreed with this sentiment. Those who do brackets well every year are the ones that do their research. Also, my MATLAB skills are getting rusty.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 20-04-2013, 07:50
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
When I made the make your predictions thread I only did Division winners because I thought people wouldn't want to take the time to do all of this. I clearly underestimate FIRSTers
I'll try to do this later today. Thanks for putting it together!
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 20-04-2013, 07:58
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Sounds awesome.
May I suggest an alteration to the scoring system as follows:
+1 Point for each correctly picked team regardless of which seed they are slotted.
+2 Points for each time your correctly picked team advances.
+5 Points for each time your correctly picked team advances/wins on Einstein.
+3 Points for each correctly picked team in the correctly picked seed.
+6 Points for each correctly picked team in the correctly picked seed advances.
+10 Points for each time your correctly picked team advances/wins on Einstein.
+10 Points for selecting a correct alliance. (+6 points if that alliance is also in the correct seed.)
+10 Points for correctly calling for a backup robot in that match. (You are allowed only 5 "call for backups" in the entire bracket.)
Set the deadline to thursday @ midnight. This allows us to fill out brackets now and really have fun with it. It also makes it a heck of a lot easier on you to calculate the scores.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 20-04-2013, 09:18
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
WHen I first saw the thread title, I was sure it was going to be about the 8.5" of snow we got here in the twin cities two days ago... but this is a pleasant surprise! I'll definitely be filling out a bracket!
2016: Lake Superior WFFA
Unread 20-04-2013, 09:20
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
The Curie Curse continues! they are the only division without Code Red's logo
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 20-04-2013, 10:35
Joon Park's Avatar
Joon Park Joon Park is offline
Joony13
FRC #0639 (Code Red Robotics)
Team Role: CAD
Joon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud of
When Simon (GrimTuesday) and I were discussing the deadline, we decided that the hard deadline must be before qualifications begin, because once seeding starts you now have access to that information.
Because this is the first year, we'll see how things go, and members of 639 will hopefully continue the April Absurdity next year with improvements from lessons learned.
Team 639: Code Red Robotics
2013 Robot: The Red Raptor
2013 Archimedes Division
2013 Buckeye Regional Winner
2013 Buckeye Spirit Award
2013 FLR Spirit Award
2012 Newton Division Finalist
2012 FLR Semi-Finalist, Engineering Inspiration Award
2012 DC Quarter-Finalist, Industrial Design Award
2011 FLR Quarter-Finalist
2011 Boston Quarter-Finalist, Imagery Award
2010 FLR Quarter-Finalist, Innovation in Control Award
2010 Philladelphia Semi-Finalist, Gracious Professionalism Award
Unread 20-04-2013, 13:28
AKA: Simon Bohn
Update to the document: Fixed two copy errors and updated the prize to make it more clear what you've won.
As for time due and scoring, I think those are linked quite well. The scoring system I chose is nearly exponential which means that if a team you've chosen to go deep does, it greatly helps your bracket. Points are barely awarded for picking quarterfinalists correctly compared to picking Einstein bots right. What that means is that honestly, no matter the final seeding, the person with the more correct choices later on will do better. However, it is not completely exponential to make it still possible to win overall on a solid bracket with the wrong winner (s).
Also, you have access to the match schedule Thursday morning so if you really do your homework, you can modify your bracket in the five hours you have.
I'd be willing to talk more about making the deadline something like Thursday midnight but my goal in this was for this to be more of a pre-championships game, to keep us busy while we wait, not one that everyone does Thursday night in their hotel rooms.
Unread 20-04-2013, 13:41
nicholsjj's Avatar
nicholsjj nicholsjj is offline
AKA: John Nichols
no team (Devil Bots)
nicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant future
That took longer than I thought even without using major stats. This was fun but it became extremely difficult due to the amount of great teams this year. Newton felt the most top heavy and Curie felt the most even, but that just might be the way that I'm looking at it. Mine is almost guaranteed to be wrong.
A few neat Einstein points on my bracket.
3 HOF teams.
3 Canadian teams.
2 Michigan teams.
2 California teams.
2 Missouri teams.(A little bit biased )
4 returning Einstein teams.
Winning alliance: 118-1114-3284 Keeping a blue banner in the show-me-state
2011-FRC Team 3862, Team Captain
2012-FRC Team 3862, Strategy Mentor
2013-FRC Team 3885, Programming Mentor, Razorback Regional, Curie Inspector
2014- FRC Team 3885, Programming Mentor, Arkansas Regional, Newton inspector
2015-??? Teacher Murphysboro High School
“They call it coaching but it is teaching. You do not just tell them…you show them the reasons.”- V. Lombardi
Unread 20-04-2013, 13:52
EricDrost's Avatar
Eleven to MidKnight
Sounds awesome anyways, good luck guys.
Unread 20-04-2013, 13:59
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
I'm so in! Awesome idea.
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
Unread 20-04-2013, 15:19
Dragonking's Avatar
Dragonking Dragonking is offline
AKA: Aaron Cannon
Dragonking is just really niceDragonking is just really niceDragonking is just really niceDragonking is just really niceDragonking is just really nice
It won't let me save the form.
Because of this I can't send a completed form. What should I do?
Unread 20-04-2013, 15:25
bardd's Avatar
That loud guy
AKA: Bar Danino
Are you using Foxit reader or Adobe reader?
If you're using Foxit, save with a different file name.
If you're using Adobe, may god have mercy on your soul. Download Foxit, copy everything, textfield by textfield.
Learned that the hard way.
Builld leader 2013
Mentor 2015-...
