Re: "noodle hats" for Quals
What if team A makes a blocker for team B because they are together for match 1, then team A takes a the blocker back and puts it on team C in match 18?
Not sure how to call that one. |
Team C would need to be inspected with the blocker on. Naturally, they'd have to pass. Otherwise, moot point, team C can't use the blocker. But the thing is, let's say that somebody notices that Team A is showing up, and every match they show up in, one of their alliance partners is carrying the same blocker. It's not inconceivable that somebody will figure out that Team A has the blocker, and is putting it on other teams' robots (with their permission, obviously). Is there a rule that would prevent it? I can't think of one off the top of my head. But there might be a way to rule that it's illegal. I'm thinking something on the order of the "each team can only bring one robot" rule combined with a narrowish reading of the Withholding Allowance rules and the "combined weight of mechanisms used in a modular system" rules would be enough to push it into the non-legal zone--but before going that far, the GDC members present would probably be asked to huddle up on the issue. |
If team A brought the blocker pre-constructed, that'd be part of their withholding. And, I think, part of the withholding of every other team that used it. So in this case team A needs to be carefully asking the right questions before they hand over the thing for installation. I don't think the GDC has anything to do with rules interpretation at the tournament. This one would belong to the Lead Robot Inspector of the tournament (or Division, at CMP) -- see 5.5.2 in the game manual. The LRI may consult with the lead LRI (Big Al) if he or she feels the need. How Al makes rulings for things like this, I don't know; I'm sure he has all the contacts he needs at FIRST HQ but I would have no idea how he uses them. Last edited by Jaxom : 20-04-2013 at 16:28. Reason: dang...gotta proofread better before hitting "submit" :( |
If I was to rule it illegal, this is how I would do it: Team A is supplying a part to multiple teams, the same part in fact (this is important). The question is, quite simply: Is it then part of Team A's robot, or the other teams' robots? Looking at the definition of ROBOT from the Manual, I could probably make a pretty strong case either way. If it is ruled part of Team A's robot (and the way I could rule it that way is that it is part of an electromechanical assembly that is designed to play UA, though it is separate from the rest of that assembly), then there are a number of ways to rule it illegal on the field or in inspection, the least of which is a T-foul (G13) and from there they go up to DQ/fix the robot. Of course, it could also be ruled that such a part is a part of all the other teams' robots, just supplied by another team. (It's not a COTS part, so it is thus a FABRICATED ITEM, thus no trouble over team as VENDOR.) Of course, this is a bit of a stretch to do, and I don't think that anybody would go that far unless there were significant complaints. |
) but I would want the LRI & Head Referee to know in case there are inquiries from other parties.Quote:
When teams help other teams, the parts tend to stay with one robot. Sure, there might be some exceptions, but it doesn't matter who builds that part. What we're discussing is the issue where the exact same part turns up on multiple robots throughout the event, and the same team is always on the field with it, irregardless of which robot it is actually on in that match. Who built it is not relevant for this discussion--let's actually assume that Team D (not attending the event) built it for/with Team A at the Magnolia Regional before elims, just to be on the safe side and eliminate the builders from the equation entirely. So: It's always on the field with Team A. Whether it's on Team A's robot or not, it's always out there. Is it part of Team A's robot, or part of their partners' robots that use it? Sure, for the match, it's part of the robot using it, and has to pass inspection on that robot. But for the competition, which robot is it a part of? Can you tell me, that for the entire competition, it is not a part of Team A's Quote:
Admittedly, this is a stretch. I'd rule it legal, but it's a judgement call, so I wouldn't say I'd make a similar decision if a similar situation would arise in 2014. |
#7
At least I was still with fruit.
Actually, what I was trying to do was dismiss "who built it" from the equation; you did that much more clearly. So I think we agree on this; who built the part is not really relevant.Quote:
I hope I'm staying within the fruit category again ; how about this: Team A has a problem with their digital sidecar, and borrows one from team B next door, who has a spare. Later in the day, they get their own replacement & swap out team A's part for the one that belongs to them. The next morning, team C needs a sidecar & borrows the same sidecar from team A. I don't think anyone would consider the sidecar part of team A's robot even if they are on the field at the same time as the sidecar, both times. I also don't think anyone would find any problem with that scenario whatsoever. If you think it's unrealistic for team B to swap out a sidecar twice, substitute whatever part you'd like.I know it's not the exact situation, but in my mind, at least, it's a relevant analogy. I don't think FABRICATION vs. COTS part makes any difference on the question of "to which robot does this part belong?" I don't really think we're disagreeing here, although I find it an interesting discussion that's helping me think about the rules a bit. Which is good, since I'm going to need them when inspections start in St. Louis. Which is now about 94 hours away. ![]() |
#8
This device is clearly designed as part of a robot to play the game Ultimate Ascent. It is not a ROBOT itself, but it is quite clearly part of one. I think we can agree on that. So, Team A has brought a ROBOT, which ROBOT has a part that is not necessarily mounted on Team A's robot although it appears in every Team A match, mounted on a robot. The question is, is that part still part of Team A's robot? Your answer is that for any given match, the answer is "No" (assuming of course that the part is not actually on Team A's robot). My answer is "Yes", because while it does not appear on Team A's robot in every match, they are the ones using it every match (though their partners are presumably quite willing participants). On a per-match basis, you are quite correct. Over the entire event, I think it becomes less and less arguable that this device is actually part of Team A's robot, when it appears on Team B, Team C, Team D, Team E, and so on, only when they are on an alliance with Team A (and in no other matches). Inspections are currently on a per-match basis. Quote:
The trick with Fabricated vs COTS is that a COTS item can probably be put on just about any robot that has a spot for it with no modification. Most robots would have spots for sidecars, cRIOs, Jaguars, Victors, Talons, batteries, etc. Those are all COTS parts. But if I have a robot with bumpers and you have a robot with bumpers and we need to swap for some reason, we probably won't be able to do that without modification, because chances are our Fabricated Items do not have the same mounting system at all. Fabricated Items tend to be custom for a particular robot (or two or three, for collaborations and practice robots), requiring some modification to robot or item to mount to another robot. I agree, this is a very interesting discussion. Maybe next year we'll see some resolution in the game design. (I also think it relates to the "win match or win tournament" meta-game discussions, where the right answer is "both!".) |
#9
Your reasoning seems to be based on a matter of degree. You've already agreed that it's OK for a team to help another team build their robot, and that such fabrications are part of the helpee's bot. So if it's one bot, apparently it's OK to not call this part of team A's robot. If it's some number more than one robot using another team's fabricated part, that part somehow becomes part of the building team's robot. What's the right number? If I make the example more specific, does it change things? Said specific example would be when a team builds a blocker for one other, single, robot to use in a single match. I submit another factor for your consideration -- the definition of "use". All alliance partners use, in effect, other same-alliance robots' features. If my alliance's defensive bot relies on my team's shooter to score, that doesn't make our shooter part of their bot. Same thing with us using them to keep the other alliance's FCS from getting to the loading zone; their drive train clearly isn't part of our robot. Somewhere there must be a definition of "use" that crosses the line from my point of view to yours, but I have no idea where that point is. Another problem: If this part really *is* part of team A's robot then R05 says it must be weighed with that robot. Since it's not part of teams B, C, D, etc. robots, the weight of this blocker doesn't affect their weight. I *really* am interested in hearing how you explain this one. I'm intrigued by your logic, but you haven't convinced me that a part not physically attached to a robot during a match can be considered part of that robot. This doesn't count parts that fall off, of course. Quote:
Does the fact that this exchangeable blocker actually fits on 12 different robots make it function like a COTS part?Quote:
Tangent: Quote:
#10
But for a team building a blocker, singular, for other robots, plural, to use in one match and return so other robots, plural can use it... That's stretching it quite a bit. How far? I will take the GDC approach and go with "if a reasonably astute observer thinks there's something funny going on, something funny is going on". Quote:
I think that this would be a pretty interesting gray area to explore with the GDC, just sort of in casual conversation, and see what they thought about devices that showed up in one robot's matches that were not on that robot or held by the drive team. That should be entertaining... |
#11
If we extrapolate this a bit...
We could propose a "generic blocker" as a strap-on in the queue line. :-) All that would be needed is for a bot to be weighed in with that blocker at inspection time as an "additional mechanism". Good to go. Hmm... probably need at least N>=2 of them, for each alliance, spares, whatever. We could even get a little sticker printed up for bots that had been certified "noodle hat capable"! Kind of like last year's "Nessie" stickers... |
#12
![]() Quote:
But I'd still like to see what they say.This is good; you've made me think about something I wouldn't have otherwise. Thank you. |
#13
Can someone with access to the Q&A ask this before it closes on Wednesday? We might get lucky and get a response.
#14
My assumption would be that teams B and C would need to get inspected/reinspected wearing it before using it. Some concern may be brought up about dual ownership of a robot component, but I'm pretty sure there is nowhere in the rules that says or implies that robots can't share. Inspectors would have a tough time justifying a decision to not let this happen.
