Go to Post Smokey the Fisher Price motor says only YOU can prevent rule infractions. - artdutra04 [more]
Unread 20-04-2013, 16:59
omsahmad's Avatar
omsahmad omsahmad is offline
FRC #1595 (Dragons)
omsahmad is just really niceomsahmad is just really niceomsahmad is just really niceomsahmad is just really niceomsahmad is just really nice
Problems with Vex Pro mecanum wheels
This year we chose to use the vex pro mecanum wheels (http://www.vexrobotics.com/vexpro/wh...m-wheels.html), but are disappointed with their performance. They travel forward backwards and rotate alright, but they strife VERY slowly. I understand moving sideways is slower, but this is moving maybe 40% of forwards speed. They are mounted properly ("X" on top) and are run by one CIM motor each, with a 9.87:1 gear ratio.
Does anyone know what might be the problem? On a side note, our practice robot has "homemade" mecanum wheels from a previous year, and it works well, so I assume the code is fine.
Unread 20-04-2013, 17:46
Re: Problems with Vex Pro mecanum wheels
Are the rollers completely free to rotate, or are they a little "tight"? The roller friction is the big variable in mecanum wheel performance.
Unread 20-04-2013, 17:59
omsahmad's Avatar
FRC #1595 (Dragons)
They are loose.
Unread 20-04-2013, 20:46
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
We used them this year and were very satisfied. Of course it will be slower sideways, but I don't recall exactly how slow it is for us. (We also used 1 cim to each wheel, but I don't remember the gear ratio)
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 20-04-2013, 21:15
omsahmad's Avatar
FRC #1595 (Dragons)
The robot with our homemade wheels is also certainly noticeably slower sideways vs. forwards/backwards, but as slow as the vex wheels. I can't remember how the andymark wheels performed exactly, but I do recall they were better than these vex wheels.
http://www.youtube.com/watch?v=W0XN6iSvCXo
^This is the kind of speed I am hoping for...
Unread 21-04-2013, 07:55
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
While moving forward/back, your torque is the same as a normal wheel.
While strafing, your sideways torque is 1/SQRT(2) (~70%) of your normal torque since the wheels are driving at each other BEFORE the extra losses of friction in the rollers.
While on a diagonal, your acceleration is somewhere between 35-50% of your normal forwards acceleration since you're only spinning half of the motors and also half of your your robot is (essentially) on caster wheels.
Translating torque into acceleration has a lot to do with roller friction and robot weight. Additionally, unless there are specific dead zones for sideways & forward, the code is robbing the robot of torque needed to strafe at reasonable speeds (since no joystick is ever perfectly sideways for long).
GitHub
Unread 21-04-2013, 08:16
Our robot did not strafe as fast as the robot in that video, however wheel speeds will be different as well. We used the AndyMark wheels for a while before switching to the VexPro wheels. (Funny story, we changed them out Friday night at a competition, some of our other team members thought we were crazy... rightly so.) We like the VexPro wheels more than the AndyMark wheels because they seem to run smoother and are more solid. (Note: the AM wheels we have had already seen a fair amount of use, new wheels may act different.) As for speed I think the VexPro ones seemed a bit faster, but I'm only saying this from recollection, not fact.
Unread 21-04-2013, 09:53
What torque are you referring to in this context?
Unread 21-04-2013, 13:26
JesseK's Avatar
FRC #1885 (ILITE)
Torque available for acceleration.
GitHub
Unread 21-04-2013, 15:14
It's the reaction force of the floor on the wheel which causes acceleration of the vehicle.
In the ideal case of no roller friction or axial free play, and a non-compliant floor, the acceleration force in the strafing direction is the same as the accelerating force in the forward direction.
The affordable mecanum wheels used for FRC do not have thrust ball bearings on the rollers. The rollers have axial free play. The rollers have spinning friction (especially when loaded). The carpet is compliant. That's what makes the vehicle go slower in the strafing direction.
Unread 21-04-2013, 18:04
JesseK's Avatar
FRC #1885 (ILITE)
What do you mean by 'compliant'?
GitHub
Unread 21-04-2013, 18:11
omsahmad's Avatar
FRC #1595 (Dragons)
Ok that makes sense. We did dedue it had something to do with the spinning wheels.
Any recommendations to make it better?
Unread 21-04-2013, 18:50
Definition 3.
Unread 21-04-2013, 19:24
Glue the rollers to their axles and forget about strafing.
Unread 21-04-2013, 19:32
mr.roboto2826's Avatar
mr.roboto2826 mr.roboto2826 is online now
AKA: Niklas Olsen
FRC #0148 (Robowranglers)
mr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nice
Or this? http://www.chiefdelphi.com/media/photos/36998
First Updates Now Shows Producer.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
