Go to Post CD has a vast store of knowledge, information, and wisdom. Add to it. - JaneYoung [more]
Unread 20-04-2013, 20:32
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Re: Iterative Project
Do I just put the Drive system in the while loop to update it or everything.
Unread 21-04-2013, 21:07
Peragore's Avatar
Peragore Peragore is offline
CEO of Black Magic
AKA: Philip Mulford
FRC #3373 (Team Robohawk)
Peragore is an unknown quantity at this point
Yes.
The standard usage of Simple Robot is something like this:
public OperatorControl(){
   while (isOperatorControl() and isEnabled()){
    try {
         Thread.sleep(10L);
    } catch (Exception e){
       e.printStackTrace();
   //insert code here, to be called every time through the while loop
while (life){
  frcObsession = true;
  obs.ProgramAndObsess();
if (!life) life = true;
Unread 21-04-2013, 22:00
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
Ok thanks i will start working on this more
Unread 28-04-2013, 22:13
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Originally Posted by Peragore View Post
Yes.
    try {
         Thread.sleep(10L);
IterativeRobot should be used because of its usage data reporting and management. Using SimpleRobot for anything else than custom robot structures really shouldn't be used. Using thread sleeps shouldn't really be needed because IterativeRobot waits for new data from the robot which is the only time data should really need to be processed.
I'd also recommend looking into Command-based, it may look hard at first but once you get the hang of it its so much neater and easier to write.
