Go to Post By the way, a piece of advice to all those who haven't gone to Manchester for Kickoff before: Go. It's something you have to do at least once in your time in FIRST. - Billfred [more]
Unread 20-04-2013, 21:56
Re: "noodle hats" for Quals
Originally Posted by Jaxom View Post
Interesting; now I understand where you're going and how you're getting there. And unfortunately I have to withdraw my "I think we agree" statement, although "interesting discussion" applies even more. I never thought of a robot part being considered this way. The difference appears to be form vs. function. If the part is connected to robot B, it's clearly a part of that robot. Now, the question is if team A built it, but put it on robot B, is that function the defining factor of whose robot "owns" the part, or is the form -- where it's connected -- the defining factor?
As I noted before, A builds it and puts it on B's robot, which is quite normal. The defining factor is not that A builds it and puts it on B's robot. It is that A builds it, puts it on B's robot, takes it off of B's robot and puts it on C in the next match. After a few matches of that, then it's pretty obvious that Team A is the "owner" of the part, due to the form--where it resides between used and the "user" who it appears with most commonly--though in an individual match it's "loaned" to another robot to "own".
Your reasoning seems to be based on a matter of degree. You've already agreed that it's OK for a team to help another team build their robot, and that such fabrications are part of the helpee's bot. So if it's one bot, apparently it's OK to not call this part of team A's robot. If it's some number more than one robot using another team's fabricated part, that part somehow becomes part of the building team's robot. What's the right number? If I make the example more specific, does it change things? Said specific example would be when a team builds a blocker for one other, single, robot to use in a single match.
I think it's "in the eye" here. A team building a blocker for another robot, singular, to use in one or more matches (singular or plural) is building it for that other robot. Or a team building blockers, plural, for partners, plural (in toto, not necessarily in a single match), to use in matches, plural, with a ratio of 1 blocker to 1 team, would still be on the other robot.
But for a team building a blocker, singular, for other robots, plural, to use in one match and return so other robots, plural can use it... That's stretching it quite a bit. How far? I will take the GDC approach and go with "if a reasonably astute observer thinks there's something funny going on, something funny is going on".
I submit another factor for your consideration -- the definition of "use". All alliance partners use, in effect, other same-alliance robots' features. If my alliance's defensive bot relies on my team's shooter to score, that doesn't make our shooter part of their bot. Same thing with us using them to keep the other alliance's FCS from getting to the loading zone; their drive train clearly isn't part of our robot. Somewhere there must be a definition of "use" that crosses the line from my point of view to yours, but I have no idea where that point is.
Your shooter stays on your robot, does it not? Their defense robot does not change drivetrains, correct? In those cases, you make use of the entire robot, in toto, unseparated (we hope it's not falling apart). In the blocker case under consideration, the use of the part requires it to be removed from one robot and placed onto another. This, I think, would be the crossing of the line.
Another problem: If this part really *is* part of team A's robot then R05 says it must be weighed with that robot. Since it's not part of teams B, C, D, etc. robots, the weight of this blocker doesn't affect their weight. I *really* am interested in hearing how you explain this one.
I'll make a stab at it. The part is part of team A's robot overall, and passed inspection with them (unless they like a lot of red cards for non-inspected robot). However, because each other robot that carries it is making a modification, it must pass inspection too, with it aboard, and it is NOT exempt from size and weight, unlike the battery and bumpers. Team A does not have to reinspect (unless they made another modification), because they passed inspection with it aboard, but are not using it. The implications of this are that any team that makes a modification to carry the blocker for that one match must not unmake the modifications (that's been covered before), and Team A needs to be able to replace the blocker on their robot at any time.
I think that this would be a pretty interesting gray area to explore with the GDC, just sort of in casual conversation, and see what they thought about devices that showed up in one robot's matches that were not on that robot or held by the drive team. That should be entertaining...
