Go to Post Either way... woop! FRC is awesome! - Steven Smith [more]
Unread 21-04-2013, 00:45
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Methods Of Transferring Robot Onto Field?
Originally Posted by KingRandy View Post
We have the eye bolts, PVC pipe and rope. Where did you guys get your carabiners?
I don't know where we got ours, since I missed that particular shopping run, but I can provide suggestions.
Grainger definitely has some that should suit. Hardware stores or sporting goods stores that cater to climbers may be good sources also. Just check the max load capacity and be sure to allow a safety factor. The unmarked ones you tend to see in the sporting goods aisle at Target/Walmart are typically rated for about 5 lbs, so they're likely to fail spectacularly when you hang a 150 lb (including battery and bumpers) robot from 4-6 of them.
