Re: 30 Point Climb Times
6 of one, half dozen of the other. In the end, it probably does not matter that much. |
The Cheesy Poofs climb takes 6.40 seconds and can be seen here. Although I'm not sure how often this is successful in competitions. I think they've done some 10's and 20's with it though.
3467 is 18 seconds with a quick 1 second lineup time.
I found it a very quick climb! I timed it & your are correct with the 18 seconds plus 1 second line-up. Loved being down on the field at PTR for field reset. Got to see & feel the energy from all the great teams.
The two fastest 30 pt climbs that I know of are 1114 (at roughly 11 seconds) and 254 (at 6.4 seconds as seen in their teaser video). Team 67 also has a fairly fast climb that is similar to 1114's.
67 and 1114 both have the capacity to then shoot/dump in 4 colored discs into the pyramid goal, while 254 does not. The main other issue with 254's is the location on the pyramid, which does not allow for any other side-climbers to make 30 points. |
#7
a 30 point climb is an incredible feat by any team. but in my opinion, it is only worth it if you can do it under 20 seconds. otherwise you can out score them. but still a 30 point climb is incredible to watch.
#8
Even assuming a 10-point, after-the-buzzer climb, it would take 2 additional disc cycles to outscore a 30-point climb. How many teams can complete two full disc cycles in 20 seconds?
#9
Mostly FCSs, though a good couple of pyramid shooters can run out too.Climbing faster means you can play defense on another climber longer. If a 10-pointer is trying to slow down a 30-pointer, the faster the latter is the more likely the are to make it up in time. A 30-on-30 would be even more interesting...like playing chicken. |
#10
I know 1511 can climb and dump all within 30 seconds, but they do score 4 colored discs and have never had a tumble or near fall off the pyramid.
