Go to Post I will test first 'cause you cannot learn unless you break something first! - Andy Brockway [more]
Unread 21-04-2013, 19:49
omsahmad's Avatar
omsahmad omsahmad is offline
FRC #1595 (Dragons)
omsahmad is just really niceomsahmad is just really niceomsahmad is just really niceomsahmad is just really niceomsahmad is just really nice
Re: Problems with Vex Pro mecanum wheels
Glue the rollers to their axles and forget about strafing.
LOL... Maybe we will try switching the wheels on Wednesday back to the Andymark one? We have to take the transmissions off to swap gears anyways.
Unread 21-04-2013, 19:59
Andrew Lawrence
Posts: n/a
I don't think he's joking around. I see no reason why a standard traction tank drive wouldn't be more advantageous for you to use instead of mecanums.
Unread 21-04-2013, 20:39
Sam_Mills's Avatar
Sam_Mills Sam_Mills is offline
FRC #4965 (FIRE)
Sam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond repute
Let the battle begin!
2013 MORT 11: Captain/Driver 60 - 19 - 1
2014-current FIRE 4965: Engineering Mentor
ewcp 2013-current
If you argue with math, you are going to lose.
Unread 21-04-2013, 21:03
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Make sure to check every roller, last year we had a strafing issue and it was because one roller was stuck. Our issue looked more like an intermittent speed issue is strafing.
I would also check if each wheel can rotate forward and backwards at full speed with the robot off the ground. Hopefully you have the encoders hooked up to each gear box to see the counts per second. At least this can sort out programing versus mechanical issues.
Just to be clear how loose our rollers are on our 2012 robot, the rollers will spin a couple time after flicking them.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 21-04-2013, 21:09
omsahmad's Avatar
FRC #1595 (Dragons)
That's fine, but we could just put real traction wheels on if we are taking the transmissions of anyways.
Unread 21-04-2013, 21:12
omsahmad's Avatar
FRC #1595 (Dragons)
Ok thanks, I'll test all of this out Wednesday. I would prefer to keep mecanum for this year.
Unread 21-04-2013, 21:16
Problem is, the rollers can appear to be free-spinning when not under load, and then bind up when they are loaded.
There is a lot of axial force on the roller under real-world operating conditions. It is prohibitively expensive to put high-quality thrust ball bearings on FRC mecanum wheel rollers. I've never seen the VEX mecanum wheels. What provision is in the design to react the high axial forces without creating excessive friction? IOW, what two materials are scrubbing against each other when the roller is axially loaded?
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Another potential problem with staffing is if your frame isn't square - ie, loads on the wheels have too much difference. We had that problem this year - we shimmed one gearbox and the staffing was fine after that.
Unread 21-04-2013, 21:31
Head Mentor
Yeah I was going to caution that a wheel unloaded will be different from a loaded wheel. My team never came up with a good test method for this.
I am sure you know this Ether, but so others can follow, I will be a bit more detailed. On the andy mark wheels, there is a bushing in the wheel. This rotates on a bolt. Between the wheel and hub plates are washers. If one is too zealous, one can tighten the bolts too much compressing the washers and wheels until the wont move. We had to play with this a bit because once the wheels are on the ground, the deflection of parts can create binding too. I think if its too loose, the hub plates could touch the roller. I forget how much it took to cause the failure mode, but gut tells me that situation required the bolts of be barely tighten.
I am guessing the Vex wheels are similar with a shoulder bolt or screw that supports the rollers. Thus i may be possible to over tighten the screw until the rollers bind. The roller would be compressed by the head of the screw and the hub ( plus a few washers in there).
Unread 22-04-2013, 12:46
pfreivald's Avatar
pfreivald pfreivald is online now
AKA: Patrick Freivald
We switched to VEX mecanum wheels for our octocanum drive this year, and had no issues whatsoever with their performance. (And the added maneuverability was very useful in lining up to the feeder slot!)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 22-04-2013, 21:09
omsahmad's Avatar
FRC #1595 (Dragons)
So I was thinking along the same lines as Ether as well,
But we have a 28"x28" robot with a center of mass right in the middle... So my thought was maybe the wheels just aren't as smooth, but apparently other are having good luck with them.
Unread 22-04-2013, 21:15
For a quick check, pick up on each corner of the robot and see if you can detect a difference. If the frame isn't square you should be able to tell.
Unread 23-04-2013, 01:25
omsahmad's Avatar
FRC #1595 (Dragons)
Oh sweet! I'll give that shot too. Thanks
Unread 23-04-2013, 09:12
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Also, your robot being 28"x28" doesn't necessarily mean your wheelbase is a square (but it may very well be or "close enough").
Unread 23-04-2013, 09:25
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
We are also using these wheels. We used them to make us always be pointed at the target when we have vision solutions if we choose to be. I have noticed that strafeing is rather slow too...
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
