Go to Post What's so bad about Matt? I mean, if the guy can explain PID so that even I can understand it, he can't be all that bad... - Billfred [more]
Unread 21-04-2013, 23:05
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Re: FIRST Behind the Design Book 3.0 (plan)
Originally Posted by Coach Norm View Post
LED lights on the robot that responsive to the sounds in the stadium. They flash and turn colors with the beat of the music. The LED panels were custom made and utilized a feature of the CRio that is not used by many.
Could you share which CRio feature this is?
Mentor http://www.teamtitanium.org/
Unread 21-04-2013, 23:19
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
We used a manual mill and manual lathe to build most of the parts of our robot, as well as a water-jetting sponsor for important yet obscure parts (transmission plates/brackets, funny shaped gears). Lots and lots of iterative CAD modeling and packaging went into the design of our climbing mechanism, but that is a process that is not easy to document!
Unread 21-04-2013, 23:58
Turtleinator's Avatar
Turtleinator Turtleinator is offline
FRC #1816
Turtleinator is an unknown quantity at this point
Team 1816 The Green Machine in Curie has cool stuff for you to see!
Our robot this year utilizes, and won the rockwell automation inovation in control award for:
-3D printed "augers" (helixes) That hold and index frisbees when in a triangular pattern.
-Ornate water jetted baseplate for the frame of the shooter.
-Fully automated vision control system with point and shoot accuracy.
-Fully CAD-ed robot
-3D models with moving parts to show off the robot.
Come to our pit and any of our team members can give you more detailed information, or ask for Kevin. You can also look at our website www.edinarobotics.com for a picture of the robot.
Unread 22-04-2013, 09:41
friskywombat's Avatar
friskywombat friskywombat is offline
AKA: Ben Berry
FRC #2468 (Team Appreciate)
friskywombat is an unknown quantity at this point
We use the DI/O ports of the sidecar, one each for red, green, and blue, and a custom circuit for the LEDs.
2013 Alamo Regional Champions (with 4063 & 2789)
-Engineering Excellence Award
2013 Hub City Regional Semifinalists (with 4694 & 1750)
-Chairman's Award
2012 Dallas West Regional Finalists (with 1429 & 4045)
-Entrepreneurship Award
2012 Alamo Regional Quarterfinalists (with 245 & 2969)
-Judge's Award
Unread 22-04-2013, 16:08
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
Here is the response from my programming mentor Joe H:
The implementation in San Antonio (Alamo) was using the cRIO's FPGA and RT processor to implement the Bling.
The FPGA was responsible for reading back buffers of timed audio data
using DMA from the analog input channel that had a microphone
connected.
The RT processor then performed DSP on the audio to identify the power of the Bass portion of the signal (128 Hz - 32 Hz). It also used some sinusoids to slowly sweep between target colors.
Once the color was chosen for that time, the FPGA was told to change
the 3 (red, green, and blue) DIO PWM signals that were driving the 3
channels of the LED panels. The FPGA continues to generate this duty
cycle until the next color is chosen by RT.
The digital outputs have FET buffers on them to allow the PWM signal
to control the relatively high current LEDs.
Hope this helps,
-Joe
FRC 2468 Team Lead 2008 - Present
Win The Day!
Unread 22-04-2013, 18:26
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
FIRST Team 1086: Blue Cheese would love to show you what our students have designed and built this year. You can find us in the Galileo Division.
A quick list of features:
-- Light weight "Legendairy" octocanum drive train. This earned us the Engineering Excellence Award at the Chesapeake Regional.
-- Innovative use of a double rocker arm four bar linkage.
-- Lightweight and durable sheet metal frame cut on water jet and powder coated.
-- Full student designed and created CAD model.
A quick animation that points out a few of the features.
Unread 22-04-2013, 20:50
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
2046 Galileo
In house
CNC milling
3D printed parts (though not as many as intially planned to to design changes)
Done by a student at his employer/our sponsor
Water jetted polycarbonate
CNC milling
CNC lathe
We also have a laser cutter but no robot parts were made with it this year though we did use it to make buttons.
I'll second the sentiment that you must check out 1899's laser cut plywood robot, it's a thing of beauty.
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Current list, for reference:
Archimedes
20......manufacturing (waterjet, CNC & manual lathe, bridgeport, welding, broaching)
78......manufacturing (3D print, waterjet, CNC mill)
1902
2468....manufacturing (HDPE shooter) control (sound-responsive LEDs)
3310....manufacturing (CNC lathe, laser cut, CNC bender, CNC mill, TIG weld) and control (cRio-driven LEDs via Java, PIDs, limit switches & IR sensors)
Curie
359
1816....manufacturing (waterjet, 3D models with moving parts) and control (automated aiming)
2168
Galileo
222.....manufacturing (3D print)
125
842.....manufacturing (3D print, waterjet)
1086....manufacturing (octocanum, four bar, water jet & powder coat sheet metal)
2175....manufacturing (3D print, manual mill & lathe, laser cut, waterjet, CNC plasma cutter)
Newton
1640....manufacturing (polyurethane mold, laser cut, CNC & manual mill, manual lathe, MIG weld) and control (swerve code, prox sensors & limit switches, vision processing, driveable swerve display)
1741....control (shooter angle)
1899....manufacturing (plywood frame)
Not Attending
100?
696
Looks like I need to schedule myself more time off to look around!
Unread 22-04-2013, 22:47
Vince's Avatar
Vince Vince is offline
FRC #0236 (Techno Ticks)
Rookie Year: 1994
Vince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond reputeVince has a reputation beyond repute
Thanks for the great suggestions and summary.
We are also be looking for control/sensor applications, as well as detailed CAD work (as well as any simulation, say for climbing or shooting mechanisms), so more leads in those areas will help as well.
We appreciate everyone's assistance finding case study leads.
Unread 22-04-2013, 23:15
AKA: Norman Morgan
Archimedes
1902
Curie
359
2168
Galileo
125
Newton
Not Attending
100?
696
For 2468, I would add the string Potentiometer. It is probably better than the other items you list for us although the LEDs are a favorite of the students. We use the POT to adjust the angle of shooter deck as well as PID control on the shooter wheel using an optical sensor.
Win The Day!
Unread 22-04-2013, 23:30
kenavt's Avatar
kenavt kenavt is offline
AKA: Colin S
kenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond repute
I think this is a simple and effective sensor for arm and elevator applications. I know that we and 1718 have installed string pots as well, and this is 2337's second year doing so.
As for other interesting software features prevalent in FRC, the rise of using the cRIO's FTP server to send autonomous scripts that are read by the robot to quickly tune autos and then switch between them is a useful feature.
Plus, I know teams that are also using configuration files of robot constants (such as PID constants) that allow quick constants changing and, thus, tuning. It trumps having to rebuild and redeploy code every time something needs to be changed. We are utilizing both of these this year - I'd love to talk about these, or the string pot, at Championship this week.
University of Michigan Computer Engineering '17
FRC 2337 student alumni (2010-2013)
Unread 23-04-2013, 00:12
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team 696 did some mathematical modeling of frisbee flight using Matlab if you're looking for something of the sort.
Unread 23-04-2013, 00:29
ticoloco12's Avatar
ticoloco12 ticoloco12 is offline
AKA: Will
FRC #0207 (Metalcrafters)
ticoloco12 will become famous soon enoughticoloco12 will become famous soon enough
Send a message via Yahoo to ticoloco12
Team 207 prides itself on it's manufacturing. We're an official chapter of SME (society of manufacturing engineers) and thanks to that and some serious hard work, we've been doing some really cool stuff. Every part on the robot that's not from the KOP is either machined or 3D printed in house by the kids. design work is pretty insane too. These kids use Solidoworks to high-end industry levels. We were a part of the first book and would love to be a part of the next. There is a whole team component dealing with documentation of our design process as well so we have some great stuff for you to see!
Keep the Hawthorne High School of Manufacturing and Engineering in mind! We won't be at nationals this year, but we are easy to reach...
Unread 23-04-2013, 02:46
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
1983 will be bringing pamphlets and paperwork in collaboration with our Water-jet sponsor OMAX.
Please stop by and grab the paperwork.
Talk to myself, or preferably ask for Liam in our pit.
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
Unread 23-04-2013, 03:44
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Archimedes
1902
Curie
359
2168
Galileo
125
Newton
Not Attending
100?
696
That felt very cool to be included in that list...
For those of you that don't know the back story, here's the quick (ish) summary. All season, I and a mentor had been arguing that a robot that could climb and dump for 50 points every match, as well as score a few in autonomous, could win the vast majority of matches. We believed that we didn't need an intake to do well and even win Davis. I could go into what caused this strategy to fail, and why the rest of the team seemed to hate it, but I'll largely skip that part of the story. The essential part is, that after three weeks of fighting, we ran out of time, and shipped a robot that really hadn't been properly tested or iterated. Our robot as shipped looked big and gangely, and was totally designed around a 30 point climb.
Unfortunately, even with all the iterations we added on at Davis, it didn't work. Basically, the travel on the climber was shortened by about two inches because of a last minute gearbox redesign, and we couldn't climb. At Davis, we had a robot that drove around and even shot a few discs, but really wasn't very good. We didn't make eliminations for the first time in maybe six years of competition. It was a big blow to the team.
When I went off to visit schools for spring break, those who had been dissatisfied with the robot we played with at Davis decided to do something about it. They spend their entire winter break designing a short shooter that was to be put on in place of the enormous climber at competition. They built it at our shop and a local hackerspace. In the end, we had a short little bot that could shoot from the front and back of the pyramid, and hang for 10, and it looked awesome because of the black powdercoat.
When we got to SVR, we spent the morning taking off the climber, and putting on this new shooter (which they called Mark II). By the end of the day, it was working pretty well, and we even went out to a few practice matches to actually practice (whaddya know?). It shot extremely straight, almost like a laser, and hung pretty well too. We got our three point autonomous working well too.
Friday and Saturday, we had a blast. We finally had a competitive robot. After not scoring more than one or two frisbees a match at Davis, we were suddenly scoring three or even four rounds a match plus auto. We ended up going 7-3-0 and seeded 12th, and would have gone 8-2-0 and ranked 9th or so if a screw hadn't come loose during one of our first matches. Here's my favorite match by far: http://www.youtube.com/watch?v=WAMQ8mJdsLk. We ended up getting picked first by Pink, which was another amazing feeling.
It was a wild ride, and a testament to the powers of iteration. We also did some cool stuff with awesome tools like sheetmetal punches and breaks, waterjet machines, CNC mills, welders, lathes, 3D printers, rivit guns, powdercoating machines, and much much more. Everything but the sheetmetal was designed, made, and assembled by students. I could go into more detail, but it's getting late.
It would be an honor to be included in a 2013 Behind the Design book, and I really think we have an amazing story to tell. Consider it.
-Plutarch
