Go to Post No one would climb Mount Everest before climbing the hill in the park down the street. - RbtGal1351 [more]
Unread 21-04-2013, 21:49
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: 30 Point Climb Times
3467 is 18 seconds with a quick 1 second lineup time.
1058 PVC Pirates 2016 - xxxx
Unread 21-04-2013, 21:55
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
a 30 point climb is an incredible feat by any team. but in my opinion, it is only worth it if you can do it under 20 seconds. otherwise you can out score them. but still a 30 point climb is incredible to watch.
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 21-04-2013, 22:22
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
I found it a very quick climb! I timed it & your are correct with the 18 seconds plus 1 second line-up. Loved being down on the field at PTR for field reset. Got to see & feel the energy from all the great teams.
Mentor & Volunteer
Field setup, Field Supervisor & disassemble Suffield Shakedown 2003- present (2015)
Connecticut Regional Field setup, disassemble & FTAA 2009, 2010, 2011, 2012, 2013 (Field reset & Assistant Field Supervisor), Field Reset Pine Tree Regional 2013, Field Supervisor, setup & take-down at Groton & Southington Districts 2014, Field Reset Hartford District 2014. Field Reset Boston District Championship 2014. FLL Judge Fall 2014
Field Supervisor/Set-up & Take-down Waterbury & Springfield , Field Reset/Set-up & take-down Hartford N/E District 2015. Field Reset NE Champs 2015. FLL Judge Fall 2015.
Suffield Shakedown 2016, Field Super 2016 Stronghold Waterbury.
Unread 21-04-2013, 22:31
Bdf809's Avatar
Bdf809 Bdf809 is offline
Alumni, Former Design Captain
AKA: Ben Fitter
FRC #2046 (Bear Metal)
Team Role: CAD
Bdf809 is a splendid one to beholdBdf809 is a splendid one to beholdBdf809 is a splendid one to beholdBdf809 is a splendid one to beholdBdf809 is a splendid one to beholdBdf809 is a splendid one to behold
The two fastest 30 pt climbs that I know of are 1114 (at roughly 11 seconds) and 254 (at 6.4 seconds as seen in their teaser video). Team 67 also has a fairly fast climb that is similar to 1114's.
67 and 1114 both have the capacity to then shoot/dump in 4 colored discs into the pyramid goal, while 254 does not. The main other issue with 254's is the location on the pyramid, which does not allow for any other side-climbers to make 30 points.
2013 Regional Chairman's Award - Central Washington Regional
2013 Regional Winner - Autodesk Oregon Regional
2012 Regional Chairman's Award - Seattle Regional
2012 Regional Winner - Seattle Regional
Unread 21-04-2013, 23:14
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Even assuming a 10-point, after-the-buzzer climb, it would take 2 additional disc cycles to outscore a 30-point climb. How many teams can complete two full disc cycles in 20 seconds?
Unread 21-04-2013, 23:38
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Anyone that can should be out of discs by then anyway. Mostly FCSs, though a good couple of pyramid shooters can run out too.
Climbing faster means you can play defense on another climber longer. If a 10-pointer is trying to slow down a 30-pointer, the faster the latter is the more likely the are to make it up in time. A 30-on-30 would be even more interesting...like playing chicken.
Unread 22-04-2013, 08:44
karomata's Avatar
karomata karomata is offline
Rebellious Egyptian
AKA: Mo Elhelw
karomata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud of
I know 1511 can climb and dump all within 30 seconds, but they do score 4 colored discs and have never had a tumble or near fall off the pyramid.
Mo Elhelw
FRC 1511 Rolling Thunder 10th Season Team Captain
Check out this awesome scouting project I've been working over the past year called FMS Scouting:
http://www.chiefdelphi.com/media/papers/3002
If you're tired of needing 6 people to scout or just don't have the resources, FMS Scouting is for you!
"The FIRST rule of FIRST Robotics is always talk about FIRST Robotics"
"Life's not linear"
2014 Finger Lakes Regional Chairman's Award Winner
2014 New York Tech Valley Regional Engineering Inspiration Winner
2013 Boston Regional Winners with 125 and 126
2012 Connecticut Regional Engineering Inspiration Winner
2011 DC Regional Chairman's Winners[/size]
