Go to Post (OK, now that I have said this, just watch someone like Kevin Watson have a working solution by this Friday... :yikes: ) - dlavery [more]
Go Back   Chief Delphi > Competition > Championship Event
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
  #106   Spotlight this post!
Unread 22-04-2013, 15:23
M.O'Reilly M.O'Reilly is offline
AKA: Mike O.
FRC #4637 (BambieBotz)
M.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of light
Re: Archimedes 2013!!!
Unfortunately, I think performance this year depends greatly on match schedule (more so than years past).
3314 is a great shooter. The won the Bridgewater district as the #1 seed, but then they were on the outside of elims at MARC for who knows what reason. I can't explain that, except for poor luck of the draw at MARC.
Drawing from MARC, alliances that succeeded in elims did not focus on defense whatsoever. The only dedicated defenders were to block full court shooters, and it was extremely effective. I think an FCS that can't get under the pyramid even making elims is far fetched. It's too easy to stop.
If I had a 3 disc autonomous mode, I wouldn't trade it to stop the opposing alliance from getting an extra two discs on the center line. Perhaps after you shoot, but certainly not before.
  #107   Spotlight this post!
Unread 22-04-2013, 16:07
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
A journalism student traveled with our team to the 10,000 Lakes regional. Here is the video she made.
http://www.youtube.com/watch?v=CYHmgSzLcHU
  #108   Spotlight this post!
Unread 22-04-2013, 16:30
Link07 Link07 is offline
Volunteer
AKA: Andrew
Link07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant future
Not to take anything away from them(they did almost win two events), but 3314 also had a fairly easy schedule at Bridgewater, IIRC.
  #109   Spotlight this post!
Unread 22-04-2013, 16:38
k20002222 k20002222 is offline
AKA: Kevin Wright
FRC #0126 (Gael Force)
Team Role: Scout
k20002222 is an unknown quantity at this point
  #110   Spotlight this post!
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Originally Posted by Grim Tuesday View Post
OPR predictions are generally 81% correct within an event. With the number of improvements teams make between the regional and championship, I think it will sway close matches significantly.
Using OPR from each team's best district event, OPR predictions were 82.4% accurate for MSC.
I think it will probably be right around 80% for CMP as well.
  #111   Spotlight this post!
Unread 22-04-2013, 16:43
foote stepped in
AKA: E. Foote
FRC #0868
Originally Posted by nikeairmancurry View Post
I'll go about 81% correct. OPR calculations hover around that number.
As pointed out earlier that's within an event, using all match data to recalculate and fit what would've happened if OPR was 100% accurate.
Also, I would like to point out that OPR predictions using Friday's match data to predict Saturday performance at Crossroads was 16 for 24 (or 25 if you count ties being wrong), and Crossroads had a significantly higher average OPR than most other regional competitions, similar to what Archimedes is predicted to have.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
  #112   Spotlight this post!
Unread 22-04-2013, 17:36
AKA: Mike O.
That may be, but I think it speaks volumes about the style of game this year. With 100 teams and 8 matches it's going to be a dog fight to get in the top8, and EVERY autonomous shot matters. The 6-7 fantastic robots you see in this division may not have their fate in their own hands; that's up to the match schedule gods.
  #113   Spotlight this post!
Unread 22-04-2013, 17:44
stephenmcd71 stephenmcd71 is offline
FRC #0071
stephenmcd71 is a name known to allstephenmcd71 is a name known to allstephenmcd71 is a name known to allstephenmcd71 is a name known to allstephenmcd71 is a name known to allstephenmcd71 is a name known to all
Originally Posted by efoote868 View Post
Anyone want to guess the % of correct predictions at the end? I'm going to say it'll be about 65%.
Im hoping there wrong too.. and I would say around 75%
  #114   Spotlight this post!
Unread 22-04-2013, 17:49
Professional Stat Padder
This division just got WAY less predictable. I think if a non-favorite team seeds first (i.e. 3314 or 11 like the spreadsheet says) the field becomes wide open for some very interesting alliance selections. I expect multiple declines and potentially some powerful low seed alliances.
(2015-Present)
  #115   Spotlight this post!
Unread 22-04-2013, 17:57
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
Originally Posted by Joe Ross View Post
I used the preliminary match schedules to simulate the matches using OPR and then calculate the standings. I used each team's best OPR from Ed Law's spreadsheet for calculating their contribution to a match. I also used each team's world Auto, Teleop, and Climb OPR from Ed Law's spreadsheet for calculating the rest of the standings.
Don't like the predictions? Go out and prove them wrong
Is there a particular reason you used OPR and not CCWM?
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
  #116   Spotlight this post!
Unread 22-04-2013, 18:10
FRC #0071
With the preliminary schedule and the results that came with that I think every division is gonna have a fun, exciting, and down to the wire finals. I wish everyone good luck and safe travels on there way to St. Louis
  #117   Spotlight this post!
Unread 22-04-2013, 19:46
I wanted match scores that could be used to calculate reasonable rankings. Since CCWM is related to winning margin and not match scores, it wouldn't have been as useful. I've seen lots of people look at the accuracy of OPR predictions, but haven't for CCWM predictions. If someone has data that shows that CCWM predictions are more accurate, I might consider doing it for next year.
A slightly better way to get match scores would have been to add the alliance's OPRs and subtract their opponents DPRs, but that's a lot more work.
  #118   Spotlight this post!
Unread 22-04-2013, 21:50
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Originally Posted by the.miler View Post
In addition to our shooting game, no ceilings can hold us now! Team 846 has gotten the climb working, and we are continuing to work right now to shave precious seconds off it.
http://www.youtube.com/watch?v=0ls-stEVTN8
The next step is the same geometry, but we're not climbing for 30 on that test pyramid. We'll see what we can do on the field
Look out for our flashlight, improved shooting, floor pickup, and climbing game on the Archimedes field!
3173 will be keeping an eye on you guys at our end of season party this week!! Good luck to our captains from Boston, we hope that you guys have better luck at this competition!
Also, we felt bad that you did not have enough buttons to give you guys at the end of Boston, if you can tell us a way to send them to you we could mail them or something before CMP. And our head programmer picked you guys in our Fantasy FIRST draft last night
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
  #119   Spotlight this post!
Unread 22-04-2013, 22:15
Allen B.'s Avatar
Allen B. Allen B. is offline
FRC #0973
Allen B. has a spectacular aura aboutAllen B. has a spectacular aura aboutAllen B. has a spectacular aura about
973 won't jump in on the collab'd scouting at event, but we'd love to share in the picture hunt.
We have 80+ teams already, probably 30-40 of which could be better quality. I'm leaving for a trip now, but our scouts will take over from here and post an updated list of teams soon. Maybe even dump the current pictures in a publically available spot for everyone.
Here is a link to 973's collection of pictures; We are still looking for a few more.
  #120   Spotlight this post!
Unread 22-04-2013, 22:32
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Thanks a bunch for this.
Is there any way to put it in numerical order its a bit hard to use currently
