Go to Post Surprise! There is no ideal alliance. As soon as you think you have a winning strategy, someone WILL figure out how to beat it. - Tom Bottiglieri [more]
Unread 06-01-2002, 22:24
Matt Hadley Matt Hadley is offline
#0400 (Blue Dragons)
Matt Hadley is an unknown quantity at this point
FIFA OFFICIAL SOCCER BALL REGULATION SIZE AND WEIGHT
ENGLISH
Circumference - 27-28 inches
Diameter - 8 3/4 inches average
Weight - 14-16 oz
Pressure - 0.6 – 1.1 atmosphere (8.5 lbs/sq in 15.6 lbs/sq in)
METRIC
Circumference - 68-70 cm
Diameter - 22 cm average
Weight - 410-450 g
Pressure - 0.6 – 1.1 atmosphere (600 – 1100 g/cm2)
Unread 07-01-2002, 00:06
Elgin Clock's Avatar
FRC #0237 (Black Magic)
The PUMA Link or The other PUMA in robotics
I have a habit to always look for hidden connections/meaning in things so don't blame me for going off on to far of a tangent.
Ok well maybe I'm grasping a little far to find the connection here but PUMA is also a manufacturer of an industrial robotic manipulator arm....We actually have one sitting in a classroom at the college I go to. I don't know exactly how old it is but I think this is a cool coincidence?
http://iel.ucdavis.edu/intro/Puma560.html
Unread 07-01-2002, 06:34
Fortunately (or unfortunately) it is just a cool coincidence.
One is a German company
Puma Ag Rudolf Dassler Sport (BB: PMMAY)
Puma AG Rudolf Dassler Sport designs, develops and markets high quality footwear, apparel, equipment and other sports-related accessories. Their logo is a PUMA a.k.a mountain lion. http://www.puma.com/
and the other is a Programmable Universal Machine for Assembly ("PUMA")
Pumas are probably the most common robot in university laboratories and one of the most common assembly robots. Designed by Vic Schienman and financed by GM at MIT in the mid-70's, the Puma (Programmable Universal Machine for Assembly) was produced for many years by Unimation (later purchased by Westinghouse and sold at a loss later to Staubli, a Swiss company) These robots and their progeny are found in many university labs.
Staubli Unimation, Inc.
201 Parkway West
Hillside Park
Duncan, SC 29334
tel: 803.433.1980
fax: 803.486.9906
Staubli Unimation Ltd
Unit G, Stafford Park 18
Telford, Shropshire, TF3 3Ax
UK
Unread 07-01-2002, 09:07
Erin Rapacki's Avatar
Erin Rapacki Erin Rapacki is offline
General Manager
Erin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond repute
Send a message via AIM to Erin Rapacki
donations
I have played soccer for every year of my life since I was five. I grew up in a soccer playing family, and through the years have gained a numerous amount of size five soccer balls. If your team doesn't want to spare a few hundred dollars for balls, consider this; take donations from friends or other students who would be willing to loan you a soccer ball or two. All size fives should be similar enough in size and pressure to work fine in the robot design. Also, you may be able to ask your school if you can use the team's soccer balls, but I think it is unlikely that the athletics departmet will let you take them. They are on a tight budget too and I bet they won't want to take any risks of having them destroyed. Also, the soccer team may not appreciate having you take them either. You may be able to ask your town's parks and rec department for donations if they have a soccer league in the fall and spring, but the same circumstances may apply. Ask around your school and friends for loans, that may be the best and least expensive way.
erin
Unread 07-01-2002, 09:52
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Ball Pick
Actually the ball we are using is the NEO CAMPO not the TEAM NEO.....dont know if there is much different except for the name......
http://www.chiefdelphi.com/forums/pi...rrow=4&trows=3
Purdue Alumni
Cummins, Inc.
Unread 07-01-2002, 12:57
D.J. Fluck
Posts: n/a
If i am not mistaken, the only difference between the campo and the team neo is the inside material and the panel count.....I used to use that ball when I played soccer...well at least it was a yellow puma ball and I dont think there are too many different models...
Unread 08-01-2002, 00:42
Alan Ing Alan Ing is offline
None #0368 (Kika Mana)
Alan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond repute
We still haven't received our kit.
I'm a bit confused as to which model PUMA ball is the correct one for this years game. Is it the PUMA CAMPO CAT NEO?
Sorry for asking, but I don't want to make a mistake ordering them since they are a bit pricey. How many do you think a team needs? 10?
Unread 08-01-2002, 09:13
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
WARNING! BE CAREFUL!
Most of the internet sites I visited about the PUMA socker balls listed the CAT NEO as being in stock, HOWEVER, in size 3 only!
Also, our soccer expert tells us that sockerballs have several surface textures/characteristics and that there are 4 (I think that's he said) that are tightly regulated. The Puma balls that we are using have a "PU" surface.
Out sports equipment supplier informed us that Puma is sold out of the size 5 versions of the CAT NEO model and won't begin production until May.
Bottom Line:
We ordered a different soccer ball that is size 5 with the "PU" surface.
Ed Sparks
MECH TECH FRC-3959
2002 game prediction contest!!! Ken Leung Rumor Mill 41 31-12-2007 18:18
What changes to this year's game...? DougHogg General Forum 16 20-04-2003 15:35
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
Game Idea archiver 2000 3 23-06-2002 23:27
Fresh from the forum Ken Leung CD Forum Support 3 15-01-2002 22:22
