Go to Post Speculate away! - IndySam [more]
Unread 30-01-2003, 16:40
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
M8 and the definition of "upright"...
To my mind, FIRST has never really defined "upright" very well either.
Is it upright when it is in the box or when it is driving round -- the Beatty machine comes to mind. If they mount it upright in starting position, it would only be upright for 5 seconds because after that it would be on its side!
Why is upright even in there?
If it is at a slight angle (say the axis of rotation of the motor +/- 2 degrees from true vertical) is that Okay? What if it was +/- 20 degrees?
Questions Questions.
Joe J.
Unread 30-01-2003, 16:58
Lewis Sussman Lewis Sussman is offline
#0095 (LRT-Upper Valley Robotics)
Lewis Sussman is an unknown quantity at this point
Now, I really love FIRST and what we do, but this is what drives me crazy. What's so hard about saying "exposed" if you mean "exposed," "visible" if you mean "visible." At this stage of the buildtime, you can't scrap your whole design plan and start over because the rulemakers at FIRST don't know how to use a dictionary. Please pardon my tone, but you all know how much we invest in this and how many people are affected by such vagaries. In my most humble opinion, such ambiguity is neither gracious nor professional. While I'm ranting, if there is a rules clarification with such potentially huge design impact made on the FIRST forums, I believe that it should be published in terms unambiguous as possible ASAP in a team update rather than remaining buried in the myriad posts that are sometimes tedious to follow. Team update #5 did not do this.
Sorry for the steam. I'm taking deep breaths.
Unread 30-01-2003, 18:44
pauluffel's Avatar
pauluffel pauluffel is offline
AKA: Paul Luffel
FRC #1127 (Lotus Robotics)
pauluffel is a jewel in the roughpauluffel is a jewel in the roughpauluffel is a jewel in the rough
Send a message via AIM to pauluffel
From what I"ve seen, this year"s light looks a bit dimmer than last year"s. I don"t have last year"s close by, so I can"t confirm this, but the new light looks dimmer, studier, and is a good deal quiter.
Unread 30-01-2003, 20:54
AKA: Dr. Joe
FRC #0088 (TJ2)
Hear hear....
Lewis & like minded folk...
...I agree with you fully. This has really gotten silly and sad.
Now we learn that upright means upright ALWAYS (except for going under the bar). This is a major new rule. One of last year's Champion (Beatty/Hammond --- oh yeah, Pepsi sponsored them too ;-) would be totally illegal as would any robot that does not remain itself upright during the match (I suppose a legalist may even argue that unless special precautions are taken, any robot climbing the ramp would not have its rotating light "upright" and would be illegal).
We are almost to WEEK 4 of a 6 week process. To require teams to make such a change at such a date is bad form. And to suggest that teams should have so called alternate mountings in case the one we designed in from the start is ruled beyond the pale is ...well... ...beyond the pale.
To make such new interpretations of rules that have been essentially unchanged from prior years without making much more noise about them is not right.
I call for a CLEAR and reasonable light rule. How about this:
1)
The light must be oriented in such a manner that it is expected to have its base pointing downward the majority of the match (more than 60 seconds).
2)
The light must be clearly visible from at least 7 of 8 "octants" (octant = a generalization of "quadrant", specifically, a 45 degree wide sector of a horizonal plane with its center on an theortical vertical line through the center of the bulb) for any horizontal plane higher than 2 feet off the ground.
3)
For brief periods of time (for example going under the bar, moving an elevator mechanism to lift a crate, etc.), the light may be partial obscured without violiating the spirit or letter of this rule -- which is to ensure that the audience can easily (and at almost every instant) determine the color designation of each and every robot on the field.
This seems to me like a rule everyone can live with.
As always, your thought are welcome.
Joe J.
Unread 30-01-2003, 21:19
Duke 13370's Avatar
Duke 13370 Duke 13370 is offline
C is for cookie...
#0862 (Team Lightning)
Team Role: Webmaster
Duke 13370 will become famous soon enough
Send a message via AIM to Duke 13370
Is the rounded half of the light labled anywhere as the top and the flat end ever labled as the bottom? -- Just a little thought.
---Lightning Robotics!---
Unread 30-01-2003, 22:19
AKA: Dr. Joe
FRC #0088 (TJ2)
Improved wording...
I realized that my second requirement for a light rule was not sufficient to define things fully.
I propose the following rule for comments:
1)
2)
For any horizontal plane higher than 2 ft, draw a circle 20 feet in diameter and centered about the point where a vertical line through the center of the bulb intersects the plane. The light must be clearly visible from at least at least 300 degrees around the circle and it must have no single "blind spot" larger than 45 degrees.
3)
Unread 30-01-2003, 22:58
Mullen's Avatar
Mullen Mullen is offline
FRC #0573 (Mech Warriors)
Mullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of light
hmm, what if the light, for the first 3 seconds(and in the "measuring box", were sideways but remained upright for the remaining portion of the match(1:57), would this be legal or would the light HAVE to be able to swivel to pass inspection..it doesnt seem that this has been looked at by first, but getting it under the bar has
2002-2003 : 573 Mech Warriors: Student
2005-2007 : 1504 Desperate Penguins: Mentor
2012 - 2016 : 573 Mech Warriors: Mentor
Unread 31-01-2003, 11:21
AKA: Dr. Joe
FRC #0088 (TJ2)
60 seconds is a majority...
I think that it should not matter what orientation your light is in in the box or at the start of the match.
The thing is that you should meet the visibility criteria (essentially always) and the base down most of the match.
That would be enough for me.
Joe J.
Unread 31-01-2003, 13:55
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
I like your wording Dr Joe. It is probably too late this year to enforce it, though I believe our robot complies. It even has a measurable criteria to make it easier to enforce.
In an earlier post I said the Light had to be "exposed". It was rightly pointed out that that word is not used in the rules. It was however, used in some of the responses from FIRST on the FRC group. I have been given to understand that these responses are to be regarded as "official" interpretations of the rule and that unlike last year (when if it wasn't in the Rules it was ignored) they are to be taken seriously.
In my question, which they declined to post, I pointedly asked that some codification be incorporated into the Rules through an official update. They basically said the "interpretations" on the FRC group ARE official and there was no need to do so. I hope they change their minds on that, the no need part that is.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 31-01-2003, 14:00
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
When they say visible, it's rather vague. If you can see the color, I don't see why they should need to see the entire light. It's pointless...
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 31-01-2003, 14:30
Let me echo what you have said, Chris. The team updates have in the past been the final word on substantial additions, changes or clarifications to the original rules. The forum in the past has been the place where Q&A happens, and seems to generate material for the updates. In my observations, in the forum sometimes questions are misunderstood and answered one way, then reasked and answered the opposite way. Knowing this, it makes it difficult to proceed with, say, a major design or manufacturing plan on the basis of an answer given in the forum. When the update comes out, one would hope to be able to have a greater level of confidence in the permanence of the ruling. If what you are saying is true, we will all need to sit by our computers watching the forum responses as they come out (and there is no particular schedule for this as there is for the updates), making sure we don't miss some important point. I don't know about you, but we're pretty busy here trying to build a robot.
Unread 31-01-2003, 16:51
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Originally posted by pauluffel
Another important thing to note, you can"t have the light come into contact with the bar. It has to move down before it touches the bar (so you can"t have it on a spring hinge where it will be pushed down by the bar).
Just wondering. Where you read this??? Was our slight plan
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 01-02-2003, 11:40
Erinn888's Avatar
Erinn888 Erinn888 is offline
#0888 (Glenelg)
Erinn888 is an unknown quantity at this point
Send a message via AIM to Erinn888
Justin.
I asked first on the jive site about light visibility and light touching the bar. The response was that the light cannot touch the bar, but it can be flipped, turned, shoot into space for all they care as long it is back ontop of the robot after the bar is cleared and does not touch the bottom bar.
The link friends:
http://jive.ilearning.com/thread.jsp...3432&q=#343 2
Unread 17-02-2003, 15:04
OddOne OddOne is offline
OddOne is an unknown quantity at this point
Send a message via AIM to OddOne
In our design, we stuck the light on the top of an arm mechanism that uses a pivot action to move up and down. This means the light will vary between +\- 30 degrees depending on the position of this arm. This is actually the most visible spot for it, because you can see the entire light from 360 degrees around...From what I read and what I want to understand, this is legal becuase the light is pointing downward to most of an extent (I consider it to move past downward at 45 degrees) and there is an unobstructed view of it.
Which brings to mind...we tested the light and does it seem weak to anyone else? Last years was a lot brighter compared to this years...
Unread 17-02-2003, 15:40
Lord Nerdlinger Lord Nerdlinger is offline
Lord Nerdlinger has a little shameless behaviour in the past
So does the word "exposed" occur in any manual or team update? or is it just the forums where people have coined the term?
B/c if it's visible in the manual, and visible in the updates, in our robot it's gonna be visible.
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
What color light is better on your robot Rob Colatutto General Forum 24 11-09-2002 20:33
About the light that need to be seen from four side archiver 2000 3 23-06-2002 23:01
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
How many posters does it take to change a lightbulb? Brandon Martus Chit-Chat 7 22-02-2002 19:48
